here you go:
custom_fields:
info: &info_light
[[[ if (entity.state == 'on' && entity.attributes.brightness) {
const brightness = Math.round(entity.attributes.brightness/2.54);
const radius = 20.5; const circumference = radius * 2 * Math.PI;
return `<svg viewBox="0 0 50 50"><circle cx="25" cy="25" r="${radius}"
stroke="var(--active-color)" stroke-width="2" fill="none"
style="transform: rotate(-90deg); transform-origin: 50% 50%;
stroke-dasharray: ${circumference};
stroke-dashoffset: ${circumference - brightness / 100 * circumference};" />
<text x="50%" y="54%" fill="black" font-size="16" font-weight= "bold"
text-anchor="middle" alignment-baseline="middle">
${brightness}<tspan font-size="10">%</tspan></text></svg>`;} ]]]
styles:
custom_fields:
info: &circle_pos
- position: absolute
- right: 5%
- top: 10%
- width: 30%
maxym
April 3, 2021, 12:49pm
5396
epicā¦ thank you!
What does the syntax starting with & in your code?
it works for me without &info_light
and &circle_pos
. once entered and saved, after reopen those āthingsā disappeared being converted to:
custom_fields:
info: |
[[[ if (entity.state ...
Thank you
Those are yaml anchors, to be able to easily inject the identical code elsewhere below this code in the file, using
*info_light
You can leave them out if this is the only place you need it.
cdrom1028
(cdrom1028)
April 4, 2021, 5:57pm
5398
@Mariusthvdb Nice, I have been looking for good examples of YAML Anchors!! Is there a way to use YAML Anchors to set a couple Styles that I can recall other places? I reuse style configs constantly and making even a small change means I need to update tons of different placesā¦
Do it exactly like I did above, create the anchor on the fly using the & and inject it using the *
Of course , button-card has the templates possibility which is even betterā¦ you can use them globally in your config ( on button cards), while anchors can only be used in the specific file you create them
uvjim
April 6, 2021, 5:00pm
5401
I donāt suppose you had a chance to have a look any further did you? I spotted when trying this that the event handler was attached but the code in the handler never seemed to fire.
Proxlx
(Mark)
April 7, 2021, 7:21am
5402
Hi all!
Apologies if this has been covered in the past, Iāve had a good search but canāt quite seem to find the answer!
Iām trying to change and icon colour based on the state of 2 other entity attributes. I have it working with either but Iām trying to use a form of AND condition. Is this possible? Apologies I donāt have the exact code to sent here at the moment but in short looking to show the following.
media_player.lounge.attribute.volume_level is > 2
AND
media_player.kitchen.attribute.volume_level is > 2
return icon colour red otherwise return grey.
I know you can do this with templates but is it possible to do directly in the custom button coding? I understand the styling/icon colours/values. Any help much appreciated.
Kind regards
Mark
Lindansaren
(Johannes Enstrƶm)
April 7, 2021, 7:49am
5403
Hi, need some help. Is it possible to have a setup like this with the button card? With grid? Or absolute position?
The buttin should control a group of lights and sensor data for the specific room would be placed on the right hand side.
Hi everyone
Iām trying to learn how to configure the custom card. My setup is by using the grid, and four buttons.
The question at hand is how I add data for icon and text sizeā¦
cards:
- type: 'custom:button-card'
entity: light.tvroom_left
icon: 'mdi:floor-lamp'
template: light
- entity: light.tvroom_right
template: light
- entity: light.glaskulan
icon: 'mdi:circle-outline'
template: light
- entity: light.hallway_window
template: light
columns: 4```
delete
April 7, 2021, 3:42pm
5406
Yes, check out this example:
Hereās the code for the Home Assistant button card in the screenshot (btw I took out my popup yaml, but you can add your own if you like):
entity: sensor.processor_use_percent
show_name: false
show_entity_picture: true
show_icon: false
show_state: false
entity_picture: /local/mdi/ha.png
styles:
card:
- width: 'min(20vw, 80px)'
- height: 'min(20vw, 80px)'
- margin: 10px
- border-radius: 15px
- background-color: var(--primary-background-color)
grid:
- position: relative
icon:
- left: 5%
- top: 1%
- height: 28px
- width: 28px
- border-radius: 10px
custom_fields:
cpu:
- left: 5%
- top: 35%
- font-size: 12px
- line-height: 20px
- font-family: Raleway
disk:
- left: 5%
- top: 55%
- font-size: 10px
- line-height: 20px
- '--text-color-sensor': >-
[[[ if (states["sensor.disk_use_percent_home"].state > 80)
return "red"; ]]]
memory:
- left: 5%
- top: 75%
- font-size: 10px
- line-height: 20px
[[[ if (states["sensor.memory_use_percent"].state > 80) return
"red"; ]]]
ver_cur:
- left: 30%
- top: 0%
- font-size: 10px
- line-height: 20px
ver_ava:
- left: 30%
- top: 18%
- font-size: 10px
- line-height: 20px
custom_fields:
cpu: |
return `<ha-icon
icon="mdi:chip"
style="width: 14px; height: 14px; color: white;">
</ha-icon><span> <span style="color: var(--text-color-sensor);">${states['sensor.processor_use_percent'].state}%</span></span>`
disk: |
return `<ha-icon
icon="mdi:harddisk"
</ha-icon><span> <span style="color: var(--text-color-sensor);">${states['sensor.disk_use_percent_home'].state}%</span></span>`
memory: |
return `<ha-icon
icon="mdi:memory"
</ha-icon><span> <span style="color: var(--text-color-sensor);">${states['sensor.memory_use_percent'].state}%</span></span>`
ver_cur: |
return `<ha-icon
icon="null"
style="width: 12px; height: 12px; color: white;">
</ha-icon><span> <span style="color: var(--text-color-sensor);">${states['sensor.installed_version'].state}</span></span>`
ver_ava: |
return `<ha-icon
icon="null"
</ha-icon><span> <span style="color: var(--text-color-sensor);">${states['sensor.latest_available_version'].state}</span></span>`
tap_action:
action: fire-dom-event
browser_mod:
command: popup
title: Sensors
card:
type: vertical-stack
cards:
####### ADD YOUR OWN HERE IF YOU WANT######
This card is amazing once you start to learn it
maxym
April 7, 2021, 4:39pm
5407
Is there a way to get using javascript a value set in cardās name
attribute other than traversing this object?
I need to pass the name to popup card.
Does the entity variable pass down to custom fields?
Main Card has entity_id: vacuum.robovac
custom field i am using another card button to call a service, the below fails:
tap_action:
action: call-service
service: vacuum.start
service_data:
entity_id: entity
However if i define the entity directly on the custom field button card it works:
tap_action:
service_data:
parautenbach
(Pieter Rautenbach)
April 8, 2021, 11:49am
5409
I think you need to post the full button config (including all the nested custom fields).
Is the custom field itself a button card? Does the inner button card have an entity ID set?
Even so, I think from what Iāve tried before that the answer is no (even if the inner card has no entity
set.
Itās not specified how the inheritance works for variables but you could experiment with that. You could define e.g. my_entity
and set the parent cardās entity
from that and if it works, reference it also in the inner card. Just an untested idea.
eximo84
April 9, 2021, 10:12am
5410
custom_fields:
battery: |
var battery_icon = entity.attributes.battery_icon;
var battery_level = entity.attributes.battery_level;
return `<ha-icon
icon="${battery_icon}"
style="width: 24px; height: 24px;"></ha-icon><br />
<span>${battery_level}%</span>`
vac_status: |
var vac_status = entity.attributes.status;
return "Status <br />" + vac_status;
vac_fanspeed: |
var vac_fanspeed = entity.attributes.fan_speed;
return "Fan Speed <br />" + vac_fanspeed;
action1:
card:
aspect_ratio: 1/1
icon: 'mdi:play'
styles:
card:
- border-radius: 0
- box-shadow: none
tap_action:
service_data:
entity_id: vacuum.dust_e
action2:
card:
aspect_ratio: 1/1
icon: 'mdi:pause'
styles:
card:
- border-radius: 0
- box-shadow: none
tap_action:
service: vacuum.pause
service_data:
action3:
card:
aspect_ratio: 1/1
icon: 'mdi:autorenew'
styles:
card:
- border-radius: 0
- box-shadow: none
tap_action:
service: vacuum.clean_spot
service_data:
action4:
card:
aspect_ratio: 1/1
icon: 'mdi:publish'
styles:
card:
- border-radius: 0
- box-shadow: none
tap_action:
service: vacuum.clean_edge
service_data:
action5:
card:
aspect_ratio: 1/1
icon: 'mdi:magnify-scan'
styles:
card:
- border-radius: 0
- box-shadow: none
tap_action:
service: vacuum.locate
service_data:
action6:
card:
aspect_ratio: 1/1
icon: 'mdi:power-plug'
styles:
card:
- border-radius: 0
- box-shadow: none
tap_action:
service: vacuum.return_to_base
service_data:
entity: vacuum.dust_e
aspect_ratio: 1/1
show_status: false
triggers_update:
- all
styles:
grid:
- grid-template-areas: >-
". i i i i battery" "vac_status vac_status n n vac_fanspeed
vac_fanspeed" "action1 action2 action3 action4 action5 action6"
- grid-template-rows: 50% 30% 20%
- grid-template-columns: 16.6% 16.6% 16.6% 16.6% 16.6% 16.6%
Basically im just trying to avoid entering the entity_id multiple times in each service call. Not sure if the service_data can accept a variable.
parautenbach
(Pieter Rautenbach)
April 9, 2021, 12:22pm
5412
Try:
tap_action:
service_data:
entity_id: "[[[ return entity.entity_id; ]]]"
Ctek
(Bogdan)
April 9, 2021, 1:06pm
5413
Thanks for the snippet it is of great value (for further reference).
Can the circle be used to display a ādurationā?
For example i have a script that is run for 10 seconds, and the button is active on the whole period of the script run.
Can the Circle decrease or fill as time goes from 0 to 10 ?
And how can this be done? ( loop while state is ON -> decrease circumference ?)
I think it will be a great feature to use the circle as a duration indicator.
Thank you and best regards
Bogdan
yeah that seems totally possible, though I havent tested it yet.
You should replace the brightness const
with your timer entity, and replace that in the calculation
also, you would add it to the triggers_update:
field, though I would think it being in the template might already do that, not sure.
Assuming your entity has 20 max, I suppose you could do this:
custom_fields:
info:
[[[ if (entity.state != 0) {
const timing = Math.round(entity.state);
stroke-dashoffset: ${circumference - timing /20 * circumference};" />
${timing}<tspan font-size="10">sec</tspan></text></svg>`;} ]]]
and Ive tested it on a input_number as entity: the circle auto-updates
If you want the remaining time, simply reverse the calculation
Ctek
(Bogdan)
April 9, 2021, 2:32pm
5415
Thanks Marius, this is a great (almost complete) starting point !
Iāll try to add a timer to the script and then to get it into the button for the circle progress.
Thank you again and hope this will help others too.
Best regards
Bogdan
