Your code is fine:
Strange. What could be causing that error Iām getting about the picture card being a custom element?
I only put the template in the raw config under button_card_templates:
and adjusted the image path.
Gotcha. Iāll have to play around some more, then.
Found the solution which was easier than I thought. For those interested in the final code
AC_template:
triggers_update:
- sun.sun
icon: "mdi:fan"
variables:
sensor_humidity: " "
sensor_power: " "
AC_entity: " "
state:
- value: "off"
color: rgba(0,0,0,0)
- value: "cool"
color: deepskyblue
spin: true
- value: "heat"
color: rgba(255,0,0,0.6)
spin: true
- value: "heat_cool"
color: orange
spin: true
styles:
card:
- width: 110px
- height: 110px
- margin: 3px
- padding: 3px
- border-radius: 15px
- background-color: var(--primary-background-color)
- box-shadow: >
if (states['sun.sun'].state == "below_horizon")
return '-5px -5px 15px #2c2c2c, 5px 5px 15px #191919';
else if (states['sun.sun'].state == "above_horizon")
return '-5px -5px 15px #ffffff, 5px 5px 15px #ebebeb';
grid:
- grid-template-areas: '"i i temp" "i i humidity" "i i power" " set set mode" "n n n"'
- grid-template-columns: 1fr 1fr 1fr
- grid-template-rows: 1fr 1fr 1fr 3fr 2fr
name:
- font-weight: bold
- font-size: 13px
- color: var(--primary-text-color)
- align-self: middle
- justify-self: left
img_cell:
- justify-content: start
- align-items: start
- margin-top: -5px
icon:
- width: 70%
custom_fields:
temp:
- align-self: start
- justify-self: end
- font-size: 10px
humidity:
- margin-top: 10px
- justify-self: end
- font-size: 10px
power:
- margin-top: 15px
- justify-self: end
- font-size: 10px
set:
- margin-top: 15px
- justify-self: end
- font-size: 30px
mode:
- justify-content: end
- align-items: end
- font-size: 30px
custom_fields:
temp: >
return `<ha-icon
icon= "mdi:thermometer"
style="width: 14px; height: 14px; color: green;">
</ha-icon><span> <span>${entity.attributes.current_temperature}°C</span></span>`
humidity: >
return `<ha-icon
icon= "mdi:water-percent"
style="width: 18px; height: 18px; color: deepskyblue;">
</ha-icon><span><span>${states[variables.sensor_humidity].state}%</span></span>`
power: >
if (variables.sensor_power ==" ")
return " "
else
return `<ha-icon
icon= "mdi:power-plug"
style="width: 18px; height: 18px; color: red;">
</ha-icon><span><span>${states[variables.sensor_power].state}kWh</span></span>`
set: >
return `
</ha-icon><span><span>${entity.attributes.temperature}°</span></span>`
mode: >
if (entity.state =="cool")
return `<ha-icon
icon= "mdi:snowflake"
style="width: 25px; height: 18px; color: rgba(0,0,255,0.6);">
</ha-icon>`
else if (entity.state =="heat")
return `<ha-icon
icon= "mdi:fire"
style="width: 25px; height: 18px; color: rgba(255,0,0,0.6);">
</ha-icon>`
Try path ā/local/imagesā
Hi, I have been using this button card for years and now I am facing an issue, hope someone can help:
I try to show some buttons to toggle to a certain mode the air purifier, and also highlight the current mode button (changing the background color).
Thatās the code for the buttons (there are four in total), see image below:
color_type: card
color: lightwhite
entity: climate.xiaomi_miot_air_purifier
icon: 'mdi:fan-auto'
show_name: true
type: 'custom:button-card'
styles:
card:
- height: 50px
- background-color: |
if (states['climate.xiaomi_miot_air_purifier'].state == 'auto') return 'rgb(156,184,191)'; return 'lightwhite';
tap_action:
action: call-service
service: climate.set_preset_mode
service_data:
entity_id: climate.xiaomi_miot_air_purifier
preset_mode: Auto
Desired result:
But when I press more than a button without refreshing the page and the air purifier updates its state I get highlighted both the old state and the new one:
I also tried changing states['climate⦠with entity.state but the result is the same.
Any ideas?
There you go , Boom it worked
Is it Auto
or auto
Sometimes a kind of workaround helps by reversing the rules:
styles:
card:
ā¦
if (states['climate.xiaomi_miot_air_purifier'].state != 'auto') return 'lightwhite'; return 'rgb(156,184,191)';
Both presets (Auto and auto) are accepted by the component when using the service-call.
Tried reversing the rules, same result until a reload is forced: colored buttons are the states previously active plus the current one:
Where can I find more about that ātriggers_updateā? I think that may be a solution to issues I was having with multi-entity cards where only the primary entity would update the card.
Hi There,
I think the button card is great and very flexible.
Iām not a great programmer, unfortunately, but I have been able to make a reasonable switchboard using examples.
Now I am using a standard template and I would like to make the colors of the map, icon and map shadow variable.
Who can help me with that?
Thanks in advance
This is my template :
container:
color_type: label-card
color: dimgray
styles:
card:
- padding: 0
name:
- border-radius: 6px 6px 0 0
- padding: 2px
- width: 100%
- font-weight: bold
grid:
- grid-template-areas: '"i" "n" "buttons"'
- grid-template-rows: 1fr min-content min-content
custom_fields:
buttons:
- background-color: 'rgba(20,20,70,1)'
- margin: 0
- padding: 5px
jja_standaard:
hold_action:
action: more-info
aspect_ratio: 1/1
label: >
[[[ var bri = Math.round(entity.attributes.brightness / 2.55); if
(entity.state === 'on') return (bri ? (bri+"%") : '') ]]]
show_label: true
show_name: true
variables:
shadow_color: '#F9C536'
icon_color: ' '
name_color: ' '
styles:
card:
- margin: 5px 5px 5x 5x
- padding: 0px 0px
- '--paper-card-background-color': 'rgba(30, 30, 30, 1)'
- '--mdc-ripple-color': green
- '--mdc-ripple-press-opacity': 0.8
name:
- text-transform: uppercase
- font-size: 11px
- color: dimgray
- white-space: normal
state:
- font-size: 10px
label:
- font-size: 10px
state:
- id: value_on
value: 'on'
styles:
card:
- box-shadow: '0px 0px 10px 3px #F9C536'
icon:
- color: '#F9C536'
name:
- color: '#F9C536'
- font-size: 11px
Can it be possible that the preset
function influences this behavior?
Your board is super-nice!
I solved it this way (but Iām not sure if it couldnāt be done more tightly):
The variables:
farbschema_dunkel:
variables:
basis_unavailable_color: 'rgba(253,253,253,0.9)'
basis_unavailable_bg: 'rgba(99,99,99,0.9)'
basis_unavailable_icon: 'rgba(213,213,213,0.9)'
The corresponding template:
button_basis:
template: farbschema_dunkel
aspect_ratio: 1/1
ā¦
ā¦
state:
- value: unavailable
styles:
card:
- color: '[[[ return variables.basis_unavailable_color ]]]'
- background-color: '[[[ return variables.basis_unavailable_bg ]]]'
icon:
- color: '[[[ return variables.basis_unavailable_icon ]]]'
Thank you for your reply.
Iāve tried your solution, but itās not quite what I want to accomplish
I want to be able to fill in the variable in the card configuration.
Standard the button has the default color scheme, but for example, in the event of an triggered alarm, I can make the icon red and the box shadow turns red instead of the default color.
I donāt think so, itās part of the service data, and the call-service part is working fine. Removed the tap-actions completely and it is behaving the same way.
Itās just that the button-cards are not getting the update of the entity state.
Also tried with a template sensor copying the climate device state, but no luck
It follows the same scheme:
Variables:
farbschema_dunkel:
variables:
ā¦
sensorwarnung_card_color: 'rgba(255,255,255,0.9)'
sensorwarnung_card_bg: |
if (entity.state == 'on') return 'rgba(219,23,9,0.9)'; return 'rgba(0,179,0,0.9)';
Template:
styles:
card:
- color: '[[[ return variables.sensorwarnung_card_color ]]]'
- background-color: '[[[ return variables.sensorwarnung_card_bg ]]]'
icon:
- color: '[[[ return variables.sensorwarnung_card_icon ]]]'
Card:
template:
- button_sensor_warnung
entity: binary_sensor.wassersensor
Ok, thanks.
Iām gonna try it tommorow! My wife is calling
Sleep tight
