@DavidFW1960, this should be fixed in the latest PR
Awesome! I had considered this to be abandoned before you came along! Thanks a lot!
Iāve added blink animation support in the PR, letās wait for the merge to happen
So I loaded the card from the PR because itās not merged yet and it looks great! Fixed the layout issue and works as expected. Thanks!
Version 0.1.0 Released
Lots of breaking changes in this release but a big push towards alignment with other standards and some cool new features. Great work @RomRider!
Breaking Changes
color_off
is now deprecated, usestate
instead if you want to redefine the color whenoff
Instead of:
Use:- type: "custom:button-card" name: Switch entity: switch.main color: red color_off: green
Or:- type: "custom:button-card" name: Switch entity: switch.main color: red state: - value: 'off' color: green
- type: "custom:button-card" name: Switch entity: switch.main state: - value: 'off' color: green - value: 'on' color: red
default_color
is deprecated as it seems redundant withcolor
(when light is not rgb). For rgb light, you can still define a specific color for theoff
state for example. -
service
has been deprecated in favor oftap_action
, see below -
action
has been replaced bytap_action
to mimic the default button card and allow for future options likehold_action
more_info
renamed tomore-info
,more_info
still works -
service
now takes the full service namelight.turn_on
- Add default entity icon support, Fix #53, add
show_icon
to decide whether to display the icon or not
Others
- blink animation support, see examples
tap_action
supportsnavigate
. Fix #75 & Fix #31 - Support for style definition in state. Fix #41
- Disable click when not needed
- Refactored the code for faster rendering
- Documentation update
- Fix #71
Version 0.1.1 Released
- New
confirmation
option that produces a popup confirmation dialog to avoid accidental clicks
Is there a way to have different actions based on state?
Hovering with the mouse over a button changes the color and the last clicked button stays with this color.
Is there a way to deactivate this, or change this color in the theme?
THANKS to all for working on this card again!
Iāve seen that also, going to check this out.
@anilet, what would be the use case?
With a home assistant script
you can do exactly that. Call the script from the button, test the state in the script and run the appropriate actions.
This latest update is absolutely amazing!! It fixes almost all of my nitpicks with the card.
I especially love the ability to leave off the icon and let it use the existing icon for that entity, can do much more things now with sensors that dynamically change their icons like weather-related ones for example. Now I have a really nice button for sensor.dark_sky_hourly_summary.
Blink is also fantastic - one of my Apple TVās acts up and goes to āunavailableā state where it continuously spams home assistant logs with an error. But now with blink I can see right away if I need to take action and reboot the Apple TV. So besides just the āintruder alertā demo gif, it also is an excellent way to monitor devices. Just look for āunavailableā state and blink.
Thank you so much @RomRider!
Two things I noticed so far while updating:
- It no longer seems to have more-info as the default. Many of my buttons do nothing when clicked on, when before they used to open more-info window. Is this a bug or an intentional change? Here is an example of a button that use to have more-info but no longer does anything when interacted with.
name:
entity: sensor.dark_sky_hourly_summary
show_state: true
color_type: card
- The documentation for the input_select near the bottom of page (where it mentions
input_select.cube_mode
) is incorrect. Instead of toggle, it should be:
tap_action:
action: service
service: input_select.select_next
service_data:
entity_id: input_select.cube_mode
(I would edit that myself but I donāt have permissions, says I need to be on a branch.)
Thanks again for these awesome improvements.
Playing with the custom:mini-media-player, and adding speaker overview to see which speakers are are used by the Rotels input sources.
Ten button cards in a horizontal-stack, using color_type: blank-card, for empty space.
Looks like when decreasing the button, the button icon does not stay in the middle of the button.
Just nit-picking, any way to make the icon stay in the center?
Any reason its not possible to declare the width of a button (now it auto adjust depending on the card and number of collums)?
Love the new features, but my code no longer works. How would I fix this to show switch.one, but toggle switch.two?
- action: call-service
color_type: icon
entity: switch.one
service:
domain: switch
action: toggle
entity_id: switch.two
type: 'custom:button-card'
I had to move back to the regular built in button. This button is so out of date at this point that it just doesnāt work. Regular button has everything I want at this point. I had to combine it with the card modder to get the colors for the buttons.
toggle
is default with most recent changes
You canāt submit a PR now? I did lock down the master branch so that you need a PR, but you should be able to still do that.
Hi @RichardU,
The way to call a service has changed in the latest version, please check the documentation (https://github.com/custom-cards/button-card/blob/master/README.md)
However, in your case it should be now:
- type: 'custom:button-card'
color_type: icon
entity: switch.one
tap_action:
service: switch.toggle
service_data:
Cheers
