Lovelace: Button card
i want the sensor to set the icon here:
      return `<ha-icon
        icon="mdi:wifi"
this is my icon sensor:
    sensors:
      p30_sofia_sound:
        friendly_name: "Sofia p30 ringer mode icon"
        value_template: >-
          {% if is_state('sensor.sofia_p30_ringer_mode', 'normal') %}
            mdi:volume-high
          {% elif is_state("sensor.sofia_p30_ringer_mode", "vibrate") %}
            mdi:vibrate
          {% else %}
            mdi:volume-mute
          {% endif %}
like
      return `<ha-icon
        icon="{states['sensor.p30_sofia_sound'].state}"
but that is not possible :stuck_out_tongue:
Quick test, try:
      return `<ha-icon
        icon="${states['sensor.p30_sofia_sound'].state}"
Tank you!! Works :slight_smile:
      return `<ha-icon
        style="width: 20px; height: 20px; color: var(--icon-color);">
        </ha-icon>`
Hi! Is there a way to insert a small button into an existing button card?
Something like this:
Tom could you post your configs to Github? Love these cards you doā€¦ they are amazing.
You mean like this? Every side icon is actually a button.
Yes, please can you post the complete code of this card?
yes, you need to check out GitHub - custom-cards/button-card: ā‡ļø Lovelace button-card for home assistant
and probably especially the ā€˜notificationā€™ which is used throughout the community for those
Hi Petro,
Would you be kind to share the code (easy to read by newbie) for:
  • Theme and/or dashboard background colors
  • Theme and/or card background colors
  • How did you align the title/room name
  • How did you combine all i.e. Synology related info in one card with no separators
I am trying to achieve liquid (water & diesel) levels for 4 tanks as described here
Button card in button card + ā€œentity.attribute.current_temperatureā€ reference
I am trying to make a header card to each room, which will hold multiple functions.
If you tap on the header itself (The kitchen text) it will toggle all the kitchen lights.
This button-card has a ā€œcustom_fieldā€ called ā€œclimateā€.
In this climate custom_field, there is another button-card, with a label, showing the climate entityā€™s attribute ā€œcurrent_temperatureā€ (25Ā°C) and an icon based of the state of the climate component.
In the label, I use Java script reference to the entity.attribute (See code below).
The issue is; it is referring to the entity of the mother button card (light.kitchen) and not to the climate.kitchen, as defined in that Ā“custom_field card.
label: '[[[ return entity.attributes.current_temperature + '' Ā°C''; ]]]'
The current code for the complete header card I am trying to make:
type: custom:button-card
show_state: false
show_icon: false
show_label: false
show_name: true
entity: light.kitchen
tap_action:
  action: toggle
hold_action:
  action: more-info
color: yellow
styles:
  card:
    - padding: 1%
    - background-color: rgba(43, 55, 78, 0.8)
    - border-radius: 15px
  grid:
    - grid-template-areas: '"n climate"'
    - grid-template-columns: 3fr 1fr
  name:
    - font-weight: 300
    - font-size: 40px
    - align-self: center
    - justify-self: center
custom_fields:
  climate:
    card:
      entity: climate.kitchen
      show_name: false
      show_label: true
      styles:
        card:
          - background-color: rgba(100, 100, 100, 0.5)
          - box-shadow: 0px 0px
        grid:
          - grid-template-areas: '"l i"'
          - grid-template-columns: 1fr min-content
I know I could hard code the entity.attribute directly in every label of each custom_field button-cards, but I want to make this button-card setup to a template, and therefore hopefully only have: Type, entity, template and name in the actual card code.
My goal for the code:
template: header-card
custom_fields:
  climate:
    card:
      template: climate-card
The goal for my templates:
templates:
  header-card:
    show_state: false
    show_icon: false
    show_label: false
    show_name: true
    tap_action:
      action: toggle
    hold_action:
      action: more-info
    color: yellow
    styles:
      card:
        - padding: 1%
      grid:
      name:
        - font-weight: 300
        - font-size: 40px
  climate-card:
    show_name: false
    show_label: true
    styles:
      card:
      grid:
On the top picture, it is trying to get the ā€œcurrent_temperatureā€ attribute of the light.kitchen entity, which does not have that attribute.
On the second image, I have changed the entity of the mothercard to climate.kitchen, and then i get the correct reading - but now the toggle light function does not work :slight_smile:
I hope someone can help me along here!
Well - i tried something, and copied all the style and setups in template.
So without changing anything, besides templifying it, now it works :smiley:
So now for each header (One pr room) I can just use this code, and define light- & climate entity as well as the name of the room.
template: header
custom_fields:
  climate:
    card:
      template: climate
YAML Template to define the button-cards used
button_card_templates:
  header:
    show_state: false
    show_icon: false
    show_label: false
    show_name: true
    hold_action:
      action: more-info
    tap_action:
      action: toggle
    color: yellow
    styles:
      card:
        - padding: 1%
      grid:
      name:
        - font-weight: 300
        - font-size: 40px
  climate:
    show_name: false
    show_label: true
    styles:
      card:
      grid:
        - grid-template-columns: 1fr min-content```
I was curious about how you did those light buttons? I like those controls all in one card or button. Could you post config for one of those?
I love these sensor examples. I tried to use the code way down on the list but I could not get it to work right. Could you share just the code for one of them?
There are some code examples above, e.g. here
If you are more specific, we can try to help.
@gdreelin
These ideas, the light and the raspi sensors, work with custom_fields. Something along the way like this:
card_light_slider:
  styles:
    grid:
      - grid-template-areas: '"item1" "item2"'
      - grid-template-rows: min-content  min-content
  custom_fields:
    item1:
      card:
        # here comes the top card, eg. the light
    item2:
      card:
        # here comes the bottom part of the card, like the slider
Both these items are configurable, so you can insert totally different cards here, like a light-slider or a mini-graph or whatever you want. :slight_smile: Even another button-card (read button-card inside button-card) is possible.
Hi guys. I was try for hour or two, but Iā€™m not skilled with coding. Could someone help me what styles should I apply to get name and icon nice inline:
This is what I have until now, but it is not good:
  - type: custom:button-card
    color_type: card
    entity: group.yeelight_checkboxes_true
    show_last_changed: false
    show_state: false
    tap_action:
      action: toggle
    state:
      - value: 'on'
        color: green
        icon: hass:toggle-switch
      - value: 'off'
        color: grey
        icon: hass:toggle-switch-off-outline
    styles:
      card:
        - height: 70px
        - border-radius: 5px
      img_cell:
        - display: flex
        - height: 450%
        - width: 40%
        - max-width: 500%
        - max-height: 500%
        - justify-self: end
        - justify-content: end
        - align-items: center
        - position: relative
        - padding-top: 16px
        - padding-right: 15px
      name:
        - justify-self: start
        - padding-left: 20px
        - font-size: 30px
        - font-weight: bold
        - padding-bottom: 20px
Many thanks in advance.
EDIT: No need, thanks, figured it out this way:
    color_type: card
    show_state: false
    tap_action:
      action: toggle
    state:
      - value: 'on'
        color: green
      - value: 'off'
        color: grey
    styles:
      card:
        - height: 70px
      grid:
        - grid-template-areas: '"n i"'
        - grid-template-columns: 1fr 1fr
        - grid-template-rows: 1fr
      name:
        - font-size: 30px
        - padding-left: 40px
        - font-weight: bold
      icon:
        - width: 180%
        - height: 180%
        - max-width: 200%
        - max-height: 200%
        - padding-left: 100px
I suppose it can be even better way (I donā€™t like that - padding-left: 100px at the end), but this is also working for now.
Is it possible to make the custom_fields background transparent?
custom_fields:
                title:
                  - align-self: start
                  - background-color: null
                  - position: absolute
                  - filter: opacity(90%)
                  - left: 0%
                  - top: 0%
                  - height: 10%
                  - width: 100%
                  - line-height: 0px
                  - font-size: 80%
Have you tried background-color: transparent;? Would be the only thing that comes to mind with CSS and transparent, but I truly donā€™t know, this is just a guess. :slight_smile:
I tried, but it didnā€™t work
The background of the custom_field is the same the card has. So background: transparent wonā€™t make much sense. What should the whole card look like?
