KameDomotics
(Kame Domotics)
September 25, 2021, 12:18pm
5985
this is the last of the attempts, but even with other tests it only shows me a thermostat icon…
type: custom:button-card
tap_action:
action: toggle
entity: climate.termostato
aspect_ratio: 1/1
styles:
card:
- border-radius: 12%
- font-size: 100%
name:
- font-weight: bold
- font-size: 18px
- align-self: middle
- justify-self: center
- padding-bottom: 5px
img_cell:
- justify-content: center
- align-items: center
- margin: none
icon:
- width: 64%
rmertz3282
(Rmertz3282)
September 25, 2021, 12:58pm
5986
Where’s your reference to the thermostat card?
The example should look something like this.
- type: custom:button-card
aspect_ratio: 1/1
custom_fields:
graph:
card:
type: sensor
entity: sensor.sensor1
graph: line
style: |
ha-card {
box-shadow: none;
KameDomotics
(Kame Domotics)
September 25, 2021, 1:34pm
5987
ok now it works, thanks!
Is it possible to hide the entity name?
I tried show_name: false but it doesn’t work …
rmertz3282
(Rmertz3282)
September 25, 2021, 2:56pm
5988
The thermostat name? Where did you insert that line?
Keep in mind you technically have a card within a card. The show_name: false works at the button level. The thermostat card will still have a name.
Within the tstat card I think you can override the entity name only. Try something like…
KameDomotics
(Kame Domotics)
September 25, 2021, 3:51pm
5989
Many thanks!
It work with name: []
Hello, i would like to know how can i return a list to use it inside button card.
my orginal code , i wanna return a list value inside button card template.
cards:
color_type: label-card
color: rgb(44, 109, 214)
entity: light.bed_light
template: |
[[[ return variables.icon ]]]
template: |
[[[ return variables.icon_1 ]]]
Output passed in button card template :
template: light_white
Failed:
template: |
- [[[ return variables.icon_1 ]]]
- [[[ return variables.icon_2 ]]]
how can i do to output a list just like below?
template:
- light_white
- light_rgb
pedolsky
(Pedolsky)
September 25, 2021, 8:23pm
5991
You can simply use a custom field inside your card:
entity: sensor.time
show_icon: false
show_name: false
show_state: true
custom_fields:
counter: |
[[[ return states['counter.testzaehler'].state ]]]
styles:
card: null
state:
- padding-bottom: 11px
grid:
- grid-template-areas: "'s' 'counter'"
- grid-template-columns: 1
returns
Or you can use a custom:button-card
as custom field:
entity: sensor.time
show_icon: false
show_name: false
show_state: true
custom_fields:
counter:
card:
entity: counter.testzaehler
show_icon: false
show_name: false
show_state: true
styles:
card:
- box-shadow: none
- border-radius: 0%
- border-top: 1px dotted
styles:
card:
- padding: 0
state:
- padding: 14px
grid:
returns
The advantage of the second variant is that you have the more info dialogue on tap/click.
BeastHouse
(Damien)
September 26, 2021, 12:51pm
5992
Could you post a shot of the final result?
krovachek
(Krisztian Borsi)
September 27, 2021, 5:25am
5995
I played with similar card like this:
This is amazing! I am an css-empiric user and I love it … even if took me 4-6h to make it work :).
I do have some questions:
How does scaling works ? In the second picture (from my laptop screen) they lose “data” from the right side or the screen, why ? I guess is normal for the text as it has a px fixed size …
Why do I have to pad-bottom to push the icon on the top ? I tried with align top and it was just aligning quite far from top …
Why is CPU slightly further away than the others ? They should be at equal distance, right !?
How can I make the full page (txt, img, sub-cards) to work/scale on any device / screen size ?
Deskop: Imgur: The magic of the Internet
Laptop (smaller ress): Imgur: The magic of the Internet
The code is inside one of a “3 columns” grid!
entity: sensor.docker_homeassistant_state
icon: mdi:home-assistant
aspect_ratio: 1/1
name: Home Assistant
styles:
card:
- border-radius: 10%
- padding: 5%
- font-size: 10px
grid:
- grid-template-areas: '"i n n " "sts sts sts" "cpu ramp ram"'
- grid-template-columns: 33% 33% 33%
- grid-template-rows: 30% 10% 60%
name:
- font-weight: bold
- font-size: 100%
- color: dodgerblue
- align-self: top
- justify-self: right
- padding-bottom: 25%
img_cell:
- justify-content: left
- align-items: top
- padding-top: 10%
- padding-bottom: 50%
icon:
- width: 60%
- padding-top: 10%
- color: |
if (entity.state = "Running") return 'lime';
if (entity.state = "Restarting") return 'yellow';
else return 'red';
custom_fields:
sts:
- align-self: top
- font-size: 8px
- padding-bottom: 40%
- '--text-color-sensor': |-
[[[ if (entity.state = "Running") return 'lime';
if (entity.state ="Restarting") return 'yellow';
else return 'red';
cpu:
- justify-self: left
ramp:
ram:
custom_fields:
sts: |
return `<span><span style="color: var(--text-color-sensor);">${states['sensor.docker_homeassistant_status'].state}</span></span>`
cpu:
card:
type: custom:bar-card
entity: sensor.docker_homeassistant_1cpu
height: 50px
width: 10px
direction: up
positions:
icon: 'off'
indicator: 'on'
minmax: 'off'
title: outside
value: outside
decimal: 1
animation:
state: 'on'
entity_row: true
severity:
- color: '#00BFFF'
to: 10
- color: '#40bf40'
to: 40
- color: '#ffde00'
to: 80
- color: '#fd0000'
to: 100
ramp:
card:
entity: sensor.docker_homeassistant_memory_percent
height: 50px
width: 10px
direction: up
positions:
icon: 'off'
indicator: 'off'
minmax: 'off'
title: outside
value: outside
decimal: 1
animation:
state: 'on'
entity_row: true
severity:
- color: '#00BFFF'
to: 10
- color: '#40bf40'
to: 40
- color: '#ffde00'
to: 80
- color: '#fd0000'
to: 100
ram:
card:
height: 50px
width: 10px
direction: up
max: 2048
positions:
icon: 'off'
indicator: 'off'
minmax: 'off'
title: outside
value: outside
decimal: 0
animation:
state: 'on'
entity_row: true
severity:
- color: '#00BFFF'
to: 204
- color: '#40bf40'
to: 820
- color: '#ffde00'
to: 1642
- color: '#fd0000'
to: 2048
flemmingss
(Flemmingss)
September 30, 2021, 12:13pm
5998
This must be simple, but I can’t find out how. I just wan to add a “Dim level: XX%” to my card. How do I accomplish this?
show_state: true
entity: light.zigbee_29
icon: mdi:bed
color_type: card
color: auto
tap_action:
action: toggle
hold_action:
action: more-info
double_tap_action:
action: call-service
service: light.turn_on
service_data:
entity_id: light.zigbee_29
brightness: 255
kelvin: 40000
pedolsky
(Pedolsky)
September 30, 2021, 3:17pm
5999
If you mean brightness level, search for Math.round here.
Hi, can someone please guide me on getting the icon to align to the right, opposed to center?
I’ve tried various ideas using the developer console. As an example, i thought if i changed justify-content
to right
on the img-cell
it would solve it.
I confess i have very little knowledge of CSS so any pointers would be really great.
Ed
Luxor73
(Luxor73)
October 2, 2021, 3:09pm
6001
Pulsaro
October 4, 2021, 1:28am
6003
Hello Community,
can someone help a newbie?
How do I get the edges of the card as rounded as in the picture?
pjn77
October 4, 2021, 5:17pm
6004
How can I get a button that calls a script to show the current color of a light entity? I’ve tried using a template in the color: value of the config but that doesn’t work.
pedolsky
(Pedolsky)
October 4, 2021, 6:09pm
6005
styles:
card:
- border-radius: 5%
or:
styles:
card:
- border-radius: 25px
Jason_hill
(Jason Hill)
October 4, 2021, 6:12pm
6006
Install card-mod and use border radius
card_mod:
style: |
ha-card
border-radius:10;
