Lovelace: Button card
I’m not using a boot time sensor but the Dev Tools give me a float error.
I see there are warnings due to the new templates code. I’ll see if I can modify my existing templates to see if it fixes the issues.
Copy it into your Dev Tools.
Wow, this is exactly what I am looking for. I’m going to try this out. Thanks.
I did as well and started using the lock function to solve it on buttons where it would cause a problem.
Can someone tell me a way, to use the !include_* function for a button_card_templates file in UI-mode? Or any other way to include the content of button_card_templates file in UI-mode? Despite copying everything into the raw-config-editor?
There is a thread with a feature request, but that doesn’t help either, as not too many voted til now (hint, hint, go vote, if you’d find that useful):
Thanks a lot for any ideas! :slight_smile:
I want to migrate slowly some of my button from the built-in button-card to this one. Sadly, the style be default does not match the built-in button. Can someone share the style to apply to my buttons to keep the built-in style? Thx
Hi! I’ve done some kind of “quick look button card” to all of my main rooms, but i’m stuck while trying to center some icons in the grid, the grid i’m trying to get is 3x4, i read the documentation which says that to fill the empty space just use a period (.) but still not getting aligned like other cards. Hope someone can help me :slight_smile:
Here is my code:
type: custom:button-card
entity: group.lights_master
tap_action:
  action: more-info
  entity: group.master
hold_action:
  action: more-info
  entity: sensor.0x00158d00027303ac_temperature
icon: mdi:bed
styles:
  card:
    - height: 100px
    - width: 116px
  grid:
    - grid-template-areas: '"n i .""temp temp .""humidity humidity .""aire door fence"'
    - grid-template-columns: 1fr 1fr 1fr
    - grid-template-rows: 1fr 1fr 1fr 1fr
    - font-weight: bold
    - font-size: 13px
    - align-self: start
    - justify-self: middle
  icon:
    - width: 30%
    - left: 30%
    - align-self: end
    - justify-self: end
  img_cell:
    - justify-content: start
    - align-items: start
  custom_fields:
    humidity:
      - align-self: start
      - justify-self: start
      - '--text-color-sensor': >-
          [[[ if (states["sensor.0x00158d00027303ac_humidity"].state > 70)
          return "red"; ]]]
    temp:
      - align-self: start
      - '--text-color-sensor': |-
          [[[ if (states["sensor.0x00158d00027303ac_temperature"].state < 17)
           return "red"; ]]]
    aire:
      - align-self: start
      - color: var(--text-color-sensor)
          [[[ if (states["climate.master_room_ac"].state === "cool") return
          "#339bf6"; ]]]
    door:
      - align-self: start
          [[[ if (states["binary_sensor.0x00158d0004aaecae_contact"].state ===
          "on") return "red"; else return "green" ]]]
    fence:
      - align-self: start
          [[[ if (states["binary_sensor.0x00158d0001dff41e_contact"].state ===
custom_fields:
  temp: |
      return `<ha-icon
        icon="mdi:thermometer"
        style="width: 18px; height: 18px;">
        </ha-icon> <span style="color: var(--text-color-sensor);">${states['sensor.0x00158d00027303ac_temperature'].state} °C</span>`
  humidity: |
      return `<ha-icon
        icon="mdi:water-percent"
        </ha-icon> <span style="color: var(--text-color-sensor);">${states['sensor.0x00158d00027303ac_humidity'].state} %</span>`
  aire: |
      return `<ha-icon
        icon="mdi:air-conditioner"
        </ha-icon> <span style="color: var(--text-color-sensor);">${states['climate.master_room_ac'].state}</span>`
  door: |
          "off") return `<ha-icon
        icon="mdi:door-sliding-lock"
        </ha-icon> ` ;
      else return `<ha-icon
        icon="mdi:door-sliding-open"
        </ha-icon> `
  fence: |
        icon="mdi:gate"
        </ha-icon> ` ;
        icon="mdi:gate-open"
        </ha-icon> `
Drop - justify-self: start for air, door and fence in the styles section.
thanks for replying that fast!!, but sadly i’m still getting “Master” word shrunk
Sorry, I’ve overlooked that. Change grid-template-columns to
    - grid-template-columns: auto 1fr 1fr
thanks! it did work :slight_smile:
I’m trying to learn, and I have read up as good as I can right now.
But I think I need some help here…
I want to create a template for these buttons;
image image
Could someone help me out with the coding. I’m trying my best by my self, but I aint getting any great results… :smiley:
Is there any problem with the original ones?
Absolutely not.
I’m just trying to learn how to create buttons for my specific needs and likings.
No need to be harsh.
This is the actual (the newest) template for the light_slider (actual means, it collapses the slider when off):
card_light_slider:
  variables:
    ulm_card_light_slider_name: "[[[ return entity.attributes.friendly_name ]]]"
  show_icon: false
  show_name: false
  show_label: false
  state:
    - operator: template
      value: "[[[ return entity.state == 'on' ]]]"
      styles:
        grid:
          - row-gap: 12px
        card:
          - background-color: 'rgba(var(--color-background-yellow),var(--opacity-bg))'
  styles:
    grid:
      - grid-template-areas: '"item1" "item2"'
      - grid-template-rows: min-content min-content
    card:
      - border-radius: var(--border-radius)
      - box-shadow: var(--box-shadow)
      - padding: 12px
  custom_fields:
    item1:
      card:
        type: 'custom:button-card'
        template:
          - icon_info
          - light
        entity: "[[[ return entity.entity_id ]]]"
        name: "[[[ return variables.ulm_card_light_slider_name ]]]"
        styles:
          card:
            - box-shadow: none
            - border-radius: var(--border-radius) var(--border-radius) 0px 0px
            - padding: 0px
    item2:
      card:
        type: conditional
        conditions:
          - entity: "[[[ return entity.entity_id ]]]"
            state: 'on'
        card:
          type: 'custom:my-slider'
          entity: '[[[ return entity.entity_id ]]]'
          radius: 14px
          height: 42px
          mainSliderColor: rgba(var(--color-yellow),1)
          secondarySliderColor: rgba(var(--color-yellow),0.2)
          mainSliderColorOff: rgba(var(--color-theme),0.05)
          secondarySliderColorOff: rgba(var(--color-theme),0.05)
          thumbHorizontalPadding: '0px'
          thumbVerticalPadding: '0px'
          thumbWidth: 0px
          card_mod:
          style: |
            ha-card {
              border-radius: 14px;
              box-shadow: none;
Without the “collapse”:
card_light_slider:
  variables:
  show_icon: false
  show_name: false
  show_label: false
  state:
      styles:
        grid:
          - row-gap: 12px
        card:
  styles:
    grid:
    card:
      - padding: 12px
  custom_fields:
    item1:
      card:
        template:
          - icon_info
          - light
        styles:
          card:
            - box-shadow: none
            - padding: 0px
    item2:
      card:
        radius: 14px
        height: 42px
        thumbWidth: 0px
        card_mod:
        style: |
          ha-card {
            box-shadow: none;
I would like to create a button-card for my HVAC based on what I’ve made for my Hue light like that:
Capture
And the code:
entity: light.veranda
icon: mdi:floor-lamp-dual
aspect_ratio: 11/9
state:
  - value: 'on'
    styles:
      card:
        - background-color: rgba(255, 255, 255, 0.8)
        - border: 1px rgba(80, 80, 80) solid
      name:
        - color: rgba(0, 0, 0, 0.6)
      icon:
        - color: var(--button-card-light-color-no-temperature)
double_tap_action:
  action: more-info
variables:
  circle_input: |
    [[[ return Math.round(entity.attributes.brightness / 2.54); ]]]
styles:
  icon:
    - top: '-2%'
    - left: 3%
    - width: 50%
    - position: absolute
  name:
    - top: 80%
    - left: 15%
    - position: center
  card:
    - font-size: 100%
    - border-radius: 15%
    - box-shadow: true
    - transition: true
  custom_fields:
    circle:
      - top: 8.5%
      - left: 56%
      - width: 40%
custom_fields:
  circle: |
      if (entity.state === 'on') {
        const input = variables.circle_input;
        const radius = 20.5;
        const circumference = radius * 2 * Math.PI;
        return `
          <svg viewBox="0 0 50 50">
            <style>
              circle {
                transform: rotate(-90deg);
                transform-origin: 50% 50%;
                stroke-dasharray: ${circumference};
                stroke-dashoffset: ${circumference - input / 100 * circumference};
              tspan {
                font-size: 10px;
            </style>
            <circle cx="25" cy="25" r="${radius}" stroke="#b2b2b2" stroke-width="1.5" fill="none" />
            <text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle">${input}<tspan font-size="10">%</tspan></text>
          </svg>
And the DEV of my entity HVAC:
I would like:
  • on tap_action make a toggle off<>heat_cool of my HAVC
  • double tap action, show the more info of my Climate_sejour
  • show in the head right circle (or not in the circle):
    • the current_temperature
    • the temperature (consign)
Hi guys!
I have a new question…why in Home Assistant browser (PC) interface I see the complete card, and from the APP / Smartphone I see it cut below (and square)?
Did I get something wrong with the code?
This is the code:
aspect_ratio: 1/1
styles:
  card:
    - border-radius: 6%
    - font-size: 100%
  custom_fields:
    alarm:
      - align-self: start
      - height: 100%
      - width: 100%
      - line-height: 28px
custom_fields:
  alarm:
    card:
      type: custom:alarmo-card
      entity: alarm_control_panel.alarmo
      no_card: false
      use_clear_icon: true
      style: |
        ha-card {
          box-shadow: none;
PC Browser:
Smartphone/APP
After hours of debugging i didn’t find the reason of the bug.
My button do not change of color, text did, but not the color :
chips_icon:
  template: chips
  show_icon: true
  show_state: false
  tap_action:
     action: more-info
     entity: '[[[ return variables.entity ]]]'
  variables:
    icon: "mdi:arrow-left"
    entity: "alarm_control_panel.tyxal_alarm"
    prefix: ""
  icon: '[[[ return variables.icon ]]]'
  label: |
      if (states[variables.entity].state == 'disarmed'|| states[variables.entity].state == 'off'){
         return variables.prefix + ` Désactivée`
      if (states[variables.entity].state == 'armed' ||  states[variables.entity].state == 'on'){
         return variables.prefix + ` Activ..e`
      return '??' ;
  styles:
    grid:
      - grid-template-areas: '"i l"'
    label:
      - justify-self: center
      - padding: 0px 6px
      - font-weight: bold
      - font-size: 14px
chips_color:
  template: chips
  show_icon: true
  show_state: false
  triggers_update: all
  tap_action:
     action: more-info
  variables:
    entity: ""
    prefix: ""
    min: 0
    max: 6
  label: |
      if (states[variables.entity].state < variables.min)
        return variables.prefix + " bas"
      if (states[variables.entity].state > variables.min && states[variables.entity].state < variables.max)
        return variables.prefix + " moyen"
      if (states[variables.entity].state > variables.max)
        return variables.prefix + " haut"
      return '??' ;
  states:
    - operator: '>'
      value: variables.max
      styles:
        icon:
          - color: 'rgba(var(--color-red),1)'
        img_cell:
          - background-color: 'rgba(var(--color-red),0.2)'
        card:
          - background-color: 'rgba(var(--color-background-red),var(--opacity-bg))'
        name:
          - color: 'rgba(var(--color-red-text),1)'
        label:
    - operator: '<'
      styles:
        icon:
          - color: 'rgba(var(--color-green),1)'
        img_cell:
          - background-color: 'rgba(var(--color-green),0.2)'
        card:
          - background-color: 'rgba(var(--color-background-green),var(--opacity-bg))'
        name:
          - color: 'rgba(var(--color-green-text),1)'
        label:
      value: variables.min
    - operator: 'default'
      styles:
        icon:
          - color: 'rgba(var(--color-yellow),1)'
        img_cell:
          - background-color: 'rgba(var(--color-yellow),0.2)'
        card:
        name:
          - color: 'rgba(var(--color-yellow-text),1)'
        label:
  styles:
    grid:
    label:
      - padding: 0px 6px
      - font-weight: bold
      - font-size: 14px
              - template: chips_color
                variables:
                   icon: "mdi:sunglasses"
                   entity: "sensor.wattignies_uv"
                   prefix: "UV :"
                   min: 3
                   max: 6
any idea ?
EDIT : theme :
      #main interface colors
      primary-color: '#434343'
      google-red : '#F54436'
      google-green : '#01C852'
      google-yellow : '#FF9101'
      google-blue : '#3D5AFE'
      google-violet : '#661FFF'
      google-grey: '#BBBBBB'
      color-red : 245, 68, 54
      color-green : 1, 200, 82
      color-yellow : 255, 145, 1
      color-blue : 61, 90, 254
      color-purple : 102, 31, 255
      color-grey : 187, 187, 187
      color-pink : 233, 30, 99
      color-theme : 51,51,51
      color-background-yellow : 250, 250, 250
      color-background-blue : 250, 250, 250
      color-background-green : 250, 250, 250
      color-background-red : 250, 250, 250
      color-yellow-text: 'var(--primary-text-color)'
      color-blue-text: 'var(--primary-text-color)'
      color-green-text: 'var(--primary-text-color)'
      color-red-text: 'var(--primary-text-color)'
      opacity-bg: '1'
thanks
Nothing wrong with th card, it shows exactly like it should. :slight_smile: Smaller screen = card get’s fitted. Everything is there, the border, the margins/paddings, looks fine! :slight_smile: What do you want to have different? :slight_smile:
Forget it, just realised, the last line of buttons is missing… I’ll have to look again. :slight_smile:
