Bumpety bump
Hi all,
So I’ve been reading the git pages, documentation and forums for 24 hours and I can’t get my head around something. I’m trying to change the color of the name and state ‘text’ rather than the color of the icon.
By following the documentation I can change the color of the icon without issues, but how do I just change the “Indoor Temp” and the value to a different color based on the value of the temperature ?
I realise that it’s probably simple but I think I’ve over complicated it inside my head
Pete
If you want color to change with temperature, just add “styles” with “name” and “state” options - add “styles” under each condition. But if you just want a different color, put “styles” in root (like my example with “card” and brown).
btw…label doesn’t do anything in your case, since you don’t have it enabled (you should write “show_label: true” and define: “label: something”…
type: custom:button-card
entity: sensor.airpurifier_temperature
show_state: true
styles: #example ...for non-conditional formatting, you can delete these lines...
card: # example...
- background: brown # example...
state:
- value: 10
operator: '<='
color: blue
styles:
name:
- color: blue
state:
- color: red
- value: 18
operator: '>='
color: red
styles:
name:
- color: red
state:
- color: red
Arh that’s perfect, exactly what I was looking for. Thanks so much.
Pete M
Using linear-gradient color for icon or background works fine but not for a name or label. Anyone know a way to accomplish this?
Are you trying to color the text with a linear gradient? I’m not sure that’s possible. you can color a gradient behind name or label like this:
styles:
name:
- background: linear-gradient(0deg, blue, red)
- padding: 4px
- width: 100%
- border-radius: 8px
Just posting another use for the custom:button-card. While there is room here for improvement, I have a great time building this. What a great card!
Yes want to use the linear gradient color for the text but it seems only possible as a background color?
In my quest to streamline my application, I have some button-card-templates like this:
patio_vizio:
triggers_update: all
variables:
tv: patio_vizio
ip: >-
[[[ return states['sensor.vizio_tvs'].attributes.tvs.find(x=>x.name ==
'patio_vizio').ip ]]]
port: >-
'patio_vizio').port ]]]
auth: >-
'patio_vizio').auth ]]]
clientaddr: >-
'patio_vizio').clientAddr ]]]
office_vizio:
variables:
tv: office_vizio
ip: >-
'office_vizio').ip ]]]
port: >-
'office_vizio').port ]]]
auth: >-
'office_vizio').auth ]]]
clientaddr: >-
'office_vizio').clientAddr ]]]
I would love to reduce the complexity here, most specifically I am trying to use the variable “tv” inside the other variables. Something like this:
variables:
tv: office_vizio
ip: >-
'variables.tv').ip ]]]
In other words, use the variable tv inside the template for ip. Then I could only have one template to set ip, port, auth, clientaddr that would get the variable passed in. I have 4 templates like above and it would reduce the code if I could have one for the meat and 4 to just set which TV.
I cannot figure out how to do it.
I have tried many things … setting a variable in the JS, backticks, brackets, adding/removing quotes … all of them yield errors like variables.tv cannot be interpreted in the “.find”. I even tried :
=>x.name == '' + variables.tv).ip
Thinking it was string issue, but no bueno.
It seems odd to me because in other parts of this integration I have this:
entity_id: '[[[ return ''media_player.'' + variables.tv ]]]'
This works fine.
Any hints on how one could write that?
Hello !
Maybe someon can help me with buttom card.
I would like to replace the colored icon on the right
The left badge have template:
badge:
layout: vertical
variables:
tap_action:
action: toggle
hold_action:
action: more-info
custom_fields:
top_left_info: |
if (variables && variables.top_left_icon) {
var icon = variables.top_left_icon;
if (variables.top_left_icon == 'battery') {
var suffix = '-unknown';
var prefix = '';
if (variables.battery_entity) {
var intBatteryLevel = states[variables.battery_entity].state;
if (!isNaN(intBatteryLevel)) {
if (intBatteryLevel == 100)
suffix = '';
else if (intBatteryLevel > 9)
suffix = '-'+('' + intBatteryLevel)[0] + '0';
else
suffix = '-alert';
if (variables.charging_sensor && states[variables.charging_sensor].state == 'on') {
prefix = '-charging';
suffix = '-100';
else if (intBatteryLevel < 10)
suffix = '-outline';
icon = "mdi:battery"+prefix+suffix;
return `<ha-icon
icon="${icon}">
</ha-icon>`;
return "";
styles:
card:
- background: unset
- box-shadow: none
- padding: 0
- max-width: '[[[return variables.size + ''px'';]]]'
- margin: 0 auto
img_cell:
- background: var(--card-background-color, white)
- width: '[[[return variables.size + ''px'';]]]'
- height: '[[[return variables.size + ''px'';]]]'
- border-top-right-radius: |
if (variables && variables.top_right_icon)
return '10%';
else
return '40%';
- border-bottom-right-radius: 40%
- border-bottom-left-radius: |
if (variables && variables.bottom_left_icon)
return '10%';
else
return '40%';
- border-top-left-radius: |
return '10%';
else
return '40%';
icon:
- width: '[[[return variables.size/2 + ''px'';]]]'
- color: var(--paper-item-icon-color)
state:
- color: var(--secondary-text-color)
- font-size: 12px
custom_fields:
top_left_info:
- color: |
if (variables && variables.top_left_icon && variables.top_left_icon == 'battery')
return "var(--paper-item-icon-color)";
else
return "var(--paper-item-icon-active-color)";
- display: block
- position: absolute
- left: 0
- top: 0
- height: '[[[return variables.size/5 + ''px'';]]]'
- width: '[[[return variables.size/5 + ''px'';]]]'
- font-size: 0
- padding: 4%
- opacity: |
return "0.7";
else
return "1";
And this its the card:
entity: person.dani
show_entity_picture: false
tap_action:
action: more-info
template: badge
show_state: true
show_name: false
triggers_update:
- sensor.dani_telefon_battery_level
- binary_sensor.dani_telefon_is_charging
- binary_sensor.dani_telefon_headphones
variables:
top_left_icon: |
if (states['binary_sensor.dani_telefon_is_charging'].state == 'on')
return "mdi:lightning-bolt-circle";
return null;
bottom_left_icon: |
if (states['binary_sensor.dani_telefon_headphones'].state == 'on')
return "mdi:headset";
else if (states['binary_sensor.dani_telefon_headphones'].state == 'on' ) {
return null;
battery_entity: sensor.dani_telefon_battery_level
charging_sensor: binary_sensor.dani_telefon_is_charging
top_right_icon: battery
And this its the colored battery:
custom_fields:
battery: |
var i = states['sensor.dani_telefon_battery_level'].attributes.icon;
var b = states['sensor.dani_telefon_battery_level'].state;
return `<span style='vertical-align: 1px'></span><ha-icon icon='${i}' style='width: 16px; vertical-align:2px'></ha-icon>${b}%`
styles:
custom_fields:
battery:
- left: 14px
- top: 1px
- font-size: 14px
- color: >-
[[[ if (states["sensor.dani_telefon_battery_level"].state < 20) return
"#ff0000"; if (states["sensor.dani_telefon_battery_level"].state < 45)
return "#ffa229"; if
(states["sensor.dani_telefon_battery_level"].state < 101) return
"#00ff00"; else return "#ffc640"]]]
The second problem, i cant line up icons horizontally.
styles:
grid:
- grid-template-areas: >-
"n dryer space s" "n fan space s" "n humidifier space s" "n
cleaning space s" "n heater space s" "l l l humidity"
- grid-template-rows: min-content min-content
- grid-template-columns: min-content min-content 1fr min-content
name:
- align-self: center
- font-size: 20px
label:
- justify-self: start
- font-size: 12px
state:
- justify-self: end
- font-size: 22px
custom fields:
fan:
- align-self: start
- justify-self: center
cleaning:
- align-self: start
dryer:
- align-self: start
humidifier:
- align-self: start
heater:
- align-self: start
humidity:
- justify-self: end;
card:
- pointer-events: none
- background: unset
- box-shadow: none
- padding: 0 4px 16px 4px
I know it’s not a small request, if anyone can help, thank you in advance!
Just posting my solution for anybody who might need inspiration/help.
I’ve been struggling with the template values, seems to be a lot of nuances to the configuration (if you aren’t familiar with it), I know there is a lot to be improved upon by using template files… baby steps.
For non-SA guys, Geyser refers to residential water heater which is controlled by a custom controller.
Blinking state if the preconfigured button matches the target temperature:
type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: custom:button-card
color_type: icon
entity: binary_sensor.geyser0_active
show_name: false
show_label: true
show_state: false
state:
- operator: template
value: |
var sensor_state = (states['binary_sensor.geyser0_active'].state);
var setpoint_state = (states['sensor.geyser0_setpoint'].state);
if (sensor_state == "on" &&
setpoint_state == 65)
return true;
else
return false
icon: mdi:water-alert-outline
color: orangered
label: 65 °C
styles:
card:
- box-shadow: 1px 1px 9px 3px red
- animation: blink 3s ease infinite
- operator: default
icon: mdi:water
color: orangered
label: 65 °C
tap_action:
action: call-service
service: mqtt.publish
service_data:
payload: 65
topic: geyser/0/set
color_type: icon
show_name: false
show_label: true
show_state: false
state:
value: |
setpoint_state == 45)
return true;
else
return false
color: orange
styles:
card:
- box-shadow: 1px 1px 9px 3px orangered
- animation: blink 2s ease infinite
- operator: default
icon: mdi:water
color: orange
label: 45 °C
tap_action:
service_data:
payload: 45
topic: geyser/0/set
color_type: card
show_name: false
show_label: true
show_state: false
state:
- value: 'on'
styles: null
color: red
label: Turn Off
- value: 'off'
styles: null
icon: mdi:water-outline
color: white
label: 'Off'
styles:
card:
- text-transform: uppercase
- font-size: 14px
tap_action:
service_data:
payload: 0
topic: geyser/0/set
- type: gauge
entity: sensor.geyser0_temperature
needle: true
severity:
green: 50
yellow: 30
red: 50
max: 75
min: 15
- type: entities
entities:
- entity: binary_sensor.geyser0_active
secondary_info: last-changed
- entity: binary_sensor.geyser0_heating
- entity: sensor.geyser0_temperature
name: Lower Water Temperature
- entity: sensor.geyser0_setpoint
name: Target Temperature
icon: mdi:thermometer-alert
- entity: sensor.geyser0_next_program_2
title: Geyser Information
show_header_toggle: false
Apologies, another shameless ask for trouble shooting help:
I’ve managed to generate the following card using this yaml -
entity: person.NAMEISHERE
show_icon: false
show_name: true
styles:
card:
- border-radius: 4%
- padding: 5%
grid:
- grid-template-areas: '"n n""i i""zone zone""battery battery"'
- grid-template-columns: 1fr 1fr
- grid-template-rows: 1fr min-content min-content min-content min-content
name:
- letter-spacing: 0.1em
- font-familly: cursive
- justify-self: middle
- align-self: middle
- padding: 1px 1px
- color: black
state:
- padding: 1px 1px
custom_fields:
i:
- scale: 100%
zone:
- font_familly: cursive
- font-size: 15px
- self-start: center
- padding-bottom: 4px
battery:
- entity: sensor.NAMEISHERE_phone_battery_state
- font-size: 15px
- '--text-color-sensor': >-
[[[ if (states["sensor.NAMEISHERE_phone_battery_level"].state <= 20)
return "red"; ]]]
custom_fields:
i: |
<img width= 38% src='/local/_20220825_155544.JPG'>
zone: |
if (states['person.NAMEISHERE'].state ='Home')
return `<ha-icon
icon="mdi:home"
style="width:20px;height:20px;color:SteelBlue">
</ha-icon><span> <span style="color: var(--text-color-sensor);">${states['person.NAMEISHERE'].state}</span></span>`
else
return `<ha-icon
icon="mdi:google-maps"
style="width:20px;height:20px;color:DarkOrange">
battery: |
if (states['sensor.NAMEISHERE_phone_battery_state'] = 'charging')
return `<ha-icon
icon="mdi:battery-charging"
style="width:20px;height:20px;color:lime">`
else
return `<ha-icon
icon="mdi:battery"
style="width:20px;height:20px">
</ha-icon><span> <span style="color: var(--text-color-sensor);">${states['sensor.NAMEISHERE_phone_battery_level'].state}%</span></span>`
The issue I have are the following:
- When the person state changes (home/away) it is not reflected on the card, either by name, icon or color as it’s meant to.
- The battery value is displaying and updating correctly but when plugging in the phone it does not update and show it charging, neither icon or color.
Been tinkering with it all day to no avail - any master out there who could set me straight?
Does anyone know if I can pass a variable from button_card to a card_mod style? Something like this?
card_mod:
style: |
:host {
--mush-icon-border-radius: [[[ return variables.radius ]]];
Cual es el código y tarjeta en Home Assistant?
Hey folks, I’m trying to get my head around adding a new state to my Person card (which I plagiarized from a different thread), but really struggling to get my head around the YAML, particularly the grid section which is what’s tripping me up. Have read the doco through and through, and can’t work it out
I have this card, and want to add Travel Time under Distance From Home.
entity: person.andrew
aspect_ratio: 1/1
show_entity_picture: true
show_name: false
hold_action:
action: none
state:
- value: home
styles:
custom_fields:
icon:
- border-color: '#77c66e'
- icon-color: green
- value: not_home
styles:
card: null
custom_fields:
icon:
- border-color: '#EF4F1A'
- value: Work
styles:
custom_fields:
icon:
- border-color: deepskyblue
styles:
card:
- border-radius: 5%
- padding: 5%
- color: gray
- font-size: 10px
- text-shadow: 0px 0px 0px black
- text-transform: capitalize
- justify-self: end
grid:
- grid-template-areas: '"icon status" "n n" "battery proximity" "wifi ss" "sd sd"'
- grid-template-columns: 2fr
name:
- font-size: 15px
- padding-bottom: 10px
custom_fields:
icon:
- clip-path: circle()
- width: 80%
- display: grid
- border: 5px solid
- border-color: gray
- border-radius: 500px
- margin: 0 +10% 0 0
- justify-self: end
- opacity: 1
status:
- align-self: start
- justify-self: end
- color: white
proximity:
- padding: 0.5em 0px
- color: white
wifi:
- color: white
- '--text-wifi-color-sensor': >-
[[[ if (states["sensor.pixel_3_xl_wifi_connection"].state == '<not
connected>') return "#aaaaaa"; ]]]
battery:
- color: white
[[[ if (states["sensor.pixel_3_xl_battery_level"].state < 50)
return "#EF4F1A"; ]]]
custom_fields:
icon: >
[[[ return entity === undefined ? null : `<img
src="${states[entity.entity_id].attributes.entity_picture}"
width="100%">`; ]]]
status: |
if (states['person.andrew'].state =='not_home') {
return `<ha-icon icon="mdi:home-export-outline"
style="width: 20px; height: 20px; color: '#888888';">
</ha-icon><span> Away</span>`;
if (states['person.andrew'].state =='home') {
return `<ha-icon
icon="mdi:home"
style="width: 20px; height: 20px; color: 888888;">
</ha-icon><span> ${entity.state}</span>`;
} else {
return `<ha-icon
icon="mdi:map-marker-radius"
proximity: |
return `<ha-icon
icon="mdi:map-marker-distance"
style="width: 20px; height: 20px; color: #888888;">
</ha-icon> <span>\<span style="color: var(--text-color-sensor);">${states['proximity.andrew'].state} Kms</span></span>`
battery: |
if (states['sensor.pixel_3_xl_battery_state'].state =='charging') {
return `<ha-icon
</ha-icon> <span><span style="color: var(--text-color-sensor);">${states['sensor.pixel_3_xl_battery_level'].state}% battery</span></span>`;
} else {
return `<ha-icon
icon="mdi:battery"
wifi: |
if (states['sensor.pixel_3_xl_wifi_connection'].state =='<not connected>') {
return `<ha-icon
icon="mdi:wifi"
style="width: 20px; height: 20px; color: var(--text-wifi-color-sensor);">
</ha-icon> <span><span style="color: var(--text-wifi-color-sensor);">Disconnected</span></span>`;
} else {
return `<ha-icon
icon="mdi:wifi"
</ha-icon> <span><span style="color: var(--text-color-sensor);">${states['sensor.pixel_3_xl_wifi_connection'].state}</span></span>`;
Before delving into a lot of work would like to confirm following;
Am I right in thinking you can only have a ‘tap-action’ on the full card and not the separate custom-fields?
Solution would then be to use separate button cards for the custom fields?
Nope, I’ve used tap-action on a button and then another tap-action on a custom field successfully.
OK thanks, even more versatile then I thought.
That will give me something to do then.
I have this button card with a slider and I can’t figure out how to either just disable the thing blue thing over the knob or make it visible. Any ideas? Here’s the code
For a similar card I am not using a grid at all, just absolute positioning for the additional information in the corners. This is how the relevant part looks like:
styles:
name:
- font-size: 16px
label:
- font-size: 8px
custom_fields:
icloud3zone:
- left: 2%
- bottom: 2%
- font-size: 10px
distance:
- left: 2%
- top: 2%
- font-size: 10px
traveltime:
- left: 2%
- top: 11%
- font-size: 10px
direction:
- left: 35%
- top: 2%
- font-size: 9px
The result is like this:
