Newcomers
(Carl)
October 11, 2023, 12:25pm
7013
I have a custom button with a light as the entity. When the light is off, I would like the state to show as off (which it does) but when the light is on, I would like the state to show the brightness level. I have the code below but it still just shows the state as on instead of brightness level. I know the state display is being called because if I change the variable to text, it changes. Any ideas?
state:
- operator: template
value: >
[[[ return states['light.living_room_wall_lights'].state ==
'on' ]]]
state_display: '[[[ entity.attributes.brightness ]]]'
Mats789
October 11, 2023, 3:14pm
7014
state:
- value: 'on'
state_display: |
if (entity.state == 'on' && entity.attributes.brightness)
return (Math.round(entity.attributes.brightness / 2.55)) + ' %';
else
return 'On'
Newcomers
(Carl)
October 15, 2023, 8:46pm
7015
does anyone know how to use the or statement within this card?
I need either of these to be true:
value: |
return (states['sensor.wiser_heating'].state === 'On')
value: |
return (states['sensor.wiser_heating_2'].state === 'On')
And what if both are true? If this canāt be the case, then why not just use ifā¦elseifā¦
I have e.g. in one card:
- color: |-
if (states["weather.openweathermap"].attributes["wind_speed"] >
30) return "red"; else if
(states["weather.openweathermap"].attributes["wind_speed"] > 20)
return "orange";
else return "black";
Or for multiple alternatives where there can always only be one hit:
entity_picture: |
if (states["sensor.openweathermap_condition"].state == "sunny") return "/local/img/weather_animated/day.svg";
if (states["sensor.openweathermap_condition"].state == "clear-night") return "/local/img/weather_animated/night.svg";
if (states["sensor.openweathermap_condition"].state == "partlycloudy") return "/local/img/weather_animated/cloudy-day-2.svg";
if (states["sensor.openweathermap_condition"].state == "cloudy") return "/local/img/weather_animated/cloudy.svg";
if (states["sensor.openweathermap_condition"].state == "fog") return "/local/img/weather_animated/cloudy.svg";
if (states["sensor.openweathermap_condition"].state == "rainy") return "/local/img/weather_animated/rainy-5.svg";
if (states["sensor.openweathermap_condition"].state == "pouring") return "/local/img/weather_animated/rainy-6.svg";
if (states["sensor.openweathermap_condition"].state == "lightning") return "/local/img/weather_animated/thunder.svg";
if (states["sensor.openweathermap_condition"].state == "lightning-rainy") return "/local/img/weather_animated/rainy-6.svg";
if (states["sensor.openweathermap_condition"].state == "snowy") return "/local/img/weather_animated/snowy-6.svg";
else return "/local/img/weather_animated/weather.svg";
0la1
(0la1)
October 19, 2023, 2:27pm
7017
does someone has a clue why I get this error:
With this code:
- type: vertical-stack
cards:
- type: "custom:button-card"
template:
- card_scenes
variables:
entity_1:
entity_id: script.1697722111760
icon: mdi:netflix
from this custom card?
https://ui-lovelace-minimalist.github.io/UI/usage/custom_cards/custom_card_scenes/
arganto
October 19, 2023, 5:32pm
7018
Hm. I donāt use it, but try to compare the example from your link
variables:
entity_1:
entity_id: "scene.YOUR_SCENE"
with your
variables:
entity_1:
0la1
(0la1)
October 22, 2023, 12:22pm
7019
The issue was that you must have five entities and I tried it with one only. Once I defined the fith entity, it worked.
arganto
October 22, 2023, 2:11pm
7020
No. Perhaps as well. But the main problem was that your indention was wrong as pointed to.
fich
October 28, 2023, 8:55pm
7021
Hi, trying to figure out if there is a way to set colors using css? Feels like there is something Iām missing and after too many hours spent on finding out what, I hope someone can help.
to show a basic example:
type: custom:button-card
styles:
card:
- background-color: teal
What I would like to do is use a color from theme/css, or whatever that works
I seem to be able to use css-variables from some themes, but not from my own theme, or what seems like, none of the themes I have downloaded (from hacs) myself.
so, what am I missing?
Here is how to use a color (or any other value) defined in a theme (standard or custom):
if this is what you asked forā¦
fich
October 28, 2023, 9:40pm
7024
yes, except that I canāt get it to work for my own themeā¦
this is from the theme-file:
my_mushroom:
mush-rgb-red: 244, 67, 54
and then:
styles:
card:
- background-color: var(--mush-rgb-red)
And that will not work.
my_mushroom is the theme I use globaly
What am I missing???
fich:
Why you have a color defined as ā244,67,54ā instead of normal ārgb(244,67,54)ā ?
fich
October 28, 2023, 10:08pm
7027
thatās what happens when you copy an existing theme and stop thinking
but still not working as I would like.
trying a bit more.
in theme-file:
my_mushroom:
# Home Assistant override
text-color: "#fff1cce6"
color1: "#fff1cce6"
this works:
styles:
card:
- background-color: var(--text-color)
but not this:
styles:
card:
- background-color: var(--color1)
does this mean I can only use css-variables that overrides existing variables? wow, that makes it not so useful, I guess
in that case, is there any other way to define your own css-variables?
I have plenty of my own vars and they are used.
test_minimal:
some-fake-var: rgba(255,255,0,0.5)
some-fake-var2: rgba(255,0,255,0.5)
- type: horizontal-stack
cards:
- type: custom:button-card
styles:
card:
- background-color: cyan
styles:
card:
- background-color: var(--accent-color)
styles:
card:
- background-color: var(--some-fake-var)
styles:
card:
- background-color: var(--some-fake-var2)
What the āāā string is doing in your theme code?
fich
October 28, 2023, 10:37pm
7029
oh, the ā was just me overthinking it⦠to show that it wasnāt an overrideā¦
but problem solved, so many hours spent on missing one of the fundamentals, so if anyone else is stupid enough to do stuff when you are way to tired, here it comes:
DONāT FORGET TO RELOAD THEMES AFTER CHANGES!!!
thanks for the help anyway, you did help!
Krivatri
(Krivatri)
October 29, 2023, 9:00am
7030
Hi all,
question: is it possible to transition an icon animation?
for example: a fan has 2 speeds, when the speed changes from low to high or vice versa, can this change gradually instead of instant? (like a slow down or a speed up)
this is the code Iām currently using to change the rotating speed of the spinning fan animation:
styles:
icon:
- animation: |
var a = entity.state;
var b = states['binary_sensor.ventilation_low'].state;
var c = states['binary_sensor.ventilation_high'].state;
if (a == 'on' && b == 'on') return 'rotating 2s linear infinite';
if (a == 'on' && c == 'on') return 'rotating 1s linear infinite';
else return 'rotating 0s linear infinite';
simphi
October 29, 2023, 2:25pm
7031
Does somebody else using button cards have a problem when scrolling āover a buttonā via a mobile device? (see Visual bug when scrolling over button via app/mobile device Ā· Issue #793 Ā· custom-cards/button-card Ā· GitHub )
I am sure it wasnāt like that in the pastā¦
Thank you in advanceā¦
Edit: Seems to be Safari/iOS/macOS related. Can somebody confirm?
fich
October 30, 2023, 12:00pm
7032
check out this channel on youtube, he pretty much shows you everthing you can do re animation, and he is using a fan as example
There are so many options and canāt answer right away if it will do as you want, but seems like it shouldā¦
playlist button card
Krivatri
(Krivatri)
October 31, 2023, 7:06am
7033
thx for the link fich,
I did look at this channel before, but could not find what I was looking for unfortunately.
fich
October 31, 2023, 12:24pm
7034
I had to look through all of them more than once before finding all I looked for, they are packed!
BTW, could ease-in-out instead of linear do what you are looking for?
