Lovelace: Button card
Try adding
    - grid-template-rows: auto
The icon is there is the size of the rows the problem
Perfect, now it works!!
Thanks.
Hello forum! :star2:
I hope youā€™re all having a fantastic day. Iā€™ve hit a bit of a snag with customizing the tooltip and was wondering if you could lend me a hand. Iā€™ve been trying to add a personal touch using HTML, but it seems itā€™s not being interpreted correctly. Any ideas on how to fix this? :thinking:
To keep things simple, I also tried adding line breaks with \n, but to no avail. What Iā€™m aiming for is to display a list in a readable manner. Hereā€™s the code Iā€™ve been working with for both attempts:
with HTML:
- type: custom:button-card
  icon: mdi:sprout
  tooltip: >
      var problems = "<ul>";
      var entities = ['plant.ficus', 'plant.filodendro_variegado'];
      entities.forEach(function(entity) {
        if (states[entity].state == 'problem') {
          problems += "<li>" + states[entity].attributes.friendly_name + "</li>";
      problems += "</ul>";
      return problems != "<ul></ul>" ? problems : "" ;
without HTML:
  icon: mdi:sprout
  tooltip: >
      var problems = "";
          problems += "- " + states[entity].attributes.friendly_name + "\n";
      return problems != "" ? problems : "";
Any guidance will be greatly appreciated. Thanks in advance for your help! :blush:
Best regards, [A HTML Enthusiast]
Hello guys
I nerd your help to modify my code because I am not able to modify slider card to select temp with range of 0,1 ĀŗC instead of 1ĀŗC.
In my entity I setup it steps of 0,1 but with the slider only works grade to grade
I hope you can help me:
title: Hall
cards:
  - type: horizontal-stack
    cards:
      - type: custom:slider-button-card
        entity: input_number.temperatura_hall
        slider:
          direction: left-right
          background: gradient
          use_state_color: false
          use_percentage_bg_opacity: true
          show_track: false
          toggle_on_click: false
          force_square: false
          min: 21
          max: 25
        icon:
          show: true
          use_state_color: true
          tap_action:
            action: none
        action_button:
          show: false
          show_name: true
        show_attribute: true
        show_state: true
        compact: false
        entity: light.colector_hall_entrada
        icon: mdi:heating-coil
        label: |
            if (states['light.colector_hall_entrada'].state === "on")
            return "Apagado";
            else if (states['light.colector_hall_entrada'].state === "off")
            return "Encendido";
        state:
          - value: 'on'
            color: rgb(70, 116, 156)
          - value: 'off'
            color: rgb(253, 192, 47)
        show_label: true
        styles:
          icon:
            - width: 50px
            - height: 60px
  - type: vertical-stack
    cards:
      - type: custom:mini-graph-card
        name: Temperatura y Humedad
        decimals: 1
        font_size_header: 15
        height: 18
        tap_action: false
        entities:
          - entity: sensor.termostato_pasillo_pb_temperatura
            show_state: true
            color: orange
            state_adaptive_color: true
            show_legend: true
            show_graph: false
            icon: mdi:thermometer
            show_icon: false
          - entity: sensor.termostato_pasillo_pb_humedad
            show_state: true
            color: lightblue
            show_legend: true
            show_graph: false
            icon: mdi:water-percent
            show_icon: false
            line_color: blue
            line_width: 7
            font_size: 60
Hello folks,
I am looking for a way to display the next waste in a button card.
I have a sensor that always shows the next waste in the first attribute (see picture)
I donā€™t understand how to display the first attribute in the card.
I already have the days until the next waste is collected.
  #                   Kopfzeile                                                            #
    view_layout:
      grid-area: kopfzeile
    cards:
        name: '[[[ return `<ha-icon icon="mdi:recycle"> </ha-icon> Abfall in ${ states[''sensor.abfallnaechster''].state } Tagen ` ]]]'
        template:
          - footer
sorry to get back on this, but I cant get this rightā€¦
only focussing on the menu button, do you say this toggles the menu on/off, without an error now, only because you use the
      entity: input_boolean.button_menu
      icon: mdi:menu
      show_name: false
      tap_action:
        action: toggle
      variables:
        menu: |-
           if (states['input_boolean.button_menu'].state === 'on') {
             this.dispatchEvent(new Event('hass-toggle-menu', { bubbles: true, composed: true }));
what I dont see is where this variable is used?
also, how would the toggle event be called if the boolean wasnt onā€¦? there must be more to it than this
but, testing this, I can do
entity: input_boolean.menu
icon: |
  [[[ return entity.state == 'off' ? 'mdi:menu' : 'mdi:menu-open'; ]]]
show_name: false
tap_action:
  action: toggle
variables:
  menu: >-
    [[[ this.dispatchEvent(new Event('hass-toggle-menu', { bubbles: true,
    composed: true })); ]]]
without further automation, and it does not trigger an error in the log,
It is reversed though compared to the boolean up[on reload of the page (I have the menu hidden by default, so it always goes back there), which means the actual menu state is not considered ā€¦ :wink:
must find a way to check that and set the boolean based on that. Or, simply ditch the desire to sync the button card with the actual menu state, and simply use it as a toggle
Just a heads-up there is an issue with the blank-card option in custom:button-card in 2024.7.0b0-2 where it seems to ignore sizing.
If you have an unsized blank-card it works fine but if you use sizes in your blank-cards for spacing etc itā€™s broken.
Iā€™ve opened an issue on github;
please add more detail as a minimum card config that is affected. As I suggested in the issue, we need more than a screenshot to be able to analyze this
Hi @Mariusthvdb
Iā€™ve updated the issue with yaml of the screenshots.
Team,
Iā€™m trying to create a very compact overview of temperatures in my house. The temperature color changes to RED if WARMER than Outside. (i.e.: open a window!)
This layout was created with the grid feature and it works fine, except for 1 thing that is not possible:
click a room/value to see the history chart (to see if the trend is up or down)
This is because the grid only contains text, not an ā€˜entityā€™.
Code:
variables:
  fontsize: 22
styles:
  card:
    - height: 170px
    - width: 180%
  grid:
    - grid-template-areas: >-
        ". sens-attic sens-office .""sens-outside sens-bed1 sens-bed ."". .
        sens-living sens-garage"
    - grid-template-columns: 25% 25% 25% 25%
    - grid-template-rows: 1fr 1fr 1fr
    - font-weight: normal
    - font-size: 13px
    - align-self: start
    - justify-self: middle
  icon:
    - width: 30%
    - left: 30%
    - align-self: end
    - justify-self: end
    - color: grey
  name:
    - color: grey
  img_cell:
    - justify-content: start
    - align-items: start
  custom_fields:
    sens-attic:
      - entity: sensor.temp_rfx_atticfront_temperature
      - tap_action: null
        action: more-info
      - '--text-color-sensor': >-
          [[[ if (states["sensor.temp_rfx_atticfront_temperature"].state >
          states["sensor.helper_temperature_outside_average"].state) return
          "orange"; return "lightgreen" ]]]
    sens-office:
          [[[ if (states["sensor.temp_rfx_office_temperature"].state >
    sens-bed1:
          [[[ if (states["sensor.temp_rfx_bed1_temperature"].state >
    sens-bed:
          [[[ if (states["sensor.temp_rfx_bedroom_temperature"].state >
    sens-living:
          [[[ if (states["sensor.temp_rfx_living_temperature"].state >
    sens-garage:
          [[[ if (states["sensor.temp_rfx_garage_temperature"].state >
    sens-outside:
      - '--text-color-sensor': lightblue
custom_fields:
  sens-outside: |
      return `<font color=grey>OUTSIDE</font><br><span style="font-size: ${variables.fontsize}px;color: var(--text-color-sensor);">${states['sensor.helper_temperature_outside_average'].state}</span>` ;
  sens-attic: |
      return `ATTIC<br><span style="font-size: ${variables.fontsize}px;font-weight: bold; color: var(--text-color-sensor);">${states['sensor.temp_rfx_atticfront_temperature'].state}</span>` ;
  sens-office: |
      return `OFFICE<br><span style="font-size: ${variables.fontsize}px;font-weight: bold; color: var(--text-color-sensor);">${states['sensor.temp_rfx_office_temperature'].state}</span>` ;
  sens-bed1: |
      return `BED1<br><span style="font-size: ${variables.fontsize}px;font-weight: bold; color: var(--text-color-sensor);">${states['sensor.temp_rfx_bed1_temperature'].state}</span>` ;
  sens-bed: |
      return `BED<br><span style="font-size: ${variables.fontsize}px;font-weight: bold; color: var(--text-color-sensor);">${states['sensor.temp_rfx_bedroom_temperature'].state}</span>` ;
  sens-living: |
      return `LIVING<br><span style="font-size: ${variables.fontsize}px;font-weight: bold; color: var(--text-color-sensor);">${states['sensor.temp_rfx_living_temperature'].state}</span>` ;
  sens-garage: |
      return `Garage<br><span style="font-size: ${variables.fontsize}px;font-weight: bold; color: var(--text-color-sensor);">${states['sensor.temp_rfx_garage_temperature'].state}</span>` ;
Any idea if it is possible to achieve something similar with or without the grid?
fixed with 2024.7.0b4
think because custom fields are not entities there is no tap action, try adding custom tap action to every custom field
    tap_action:
      action: fire-dom-event
      browser_mod:
        service: browser_mod.popup
          title: TITLE
          content:
            cards:
              - type: history-graph
                entities:
                  - entity: ENTITY
Dear all,
Iā€™m using a template and for some entities I want to control the icon color in function of the entity and/or state, but for some others I want to display their original color, which happens to change in function of the state. The problem is that if the icon color style is set for some entities, by filtering them using the entity_id, then for those entities that I want to display their original color, the color turns white. Thus, the only way to show the original color is not to change the color style at all? Sounds strange. So I need a workaround and this is why I was thinking to catch the original colorā€¦ Is there any way, i.e. a HASS variable, to get the original color of an entity?
The following is the code Iā€™m using to set the color style:
  styles:
    icon:
      - color: |
            var type = entity.entity_id.split(".")[0];
            if (type == "switch") {
              return states[entity.entity_id].state == 'on' ? 'rgb(0,100,255)' : 'Silver';
            } else if (variables.var_select_option_value) {
              if (states[entity.entity_id].state == variables.var_select_option_value) {
                return "rgb(0,100,255)";
              } else {
                return "Silver";
            //if the entity is not a switch or a select entity the original color should be used, but it's not !
Many thanks!
BTW, to test the icon color problem, just add a dummy code into the icon color style and the original icon color of any entity will not be shownā€¦
styles:
    icon:
      - color: |
            if ("dummy" === 0) return "Red";
            //With this code no entities are shown with their color !
Donā€™t think thereā€™s a way to add a tap_action to a custom field. Think I may have to use a custom button card combined with grid cards and a highly customized margin/padding
You can have a custom button card in a custom field, and that card can have a tap action.
Never thought about that :slight_smile:
@potat0
I eventually solved it with:
  • grid card 5 columns
  • each column: vertical stack card with
  • custom button cards and using templates
Hereā€™s the 2-column version of the CARD:
type: grid
square: true
columns: 2
cards:
    cards:
        template: temp_sensor
        variables:
          var_name: ATTIC
          var_entity: sensor.temp_rfx_atticfront_temperature
        variables:
          var_name: BED1
          var_entity: sensor.temp_rfx_bed1_temperature
        label: spacer button
        styles:
          state:
            - color: '#2c2c2e'
    cards:
        variables:
          var_name: OFFICE
          var_entity: sensor.temp_rfx_office_temperature
        variables:
          var_name: BED2
          var_entity: sensor.temp_rfx_bed2_temperature
        variables:
          var_name: LIVING
          var_entity: sensor.temp_rfx_living_temperature
and the TEMPLATE that needs to be inserted in the raw configuration editor (3dot menu top right)
button_card_templates:
  temp_sensor:
    variables:
      var_name: null
      var_entity: sensor.helper_temperature_outside_average
    entity: '[[[ return variables.var_entity ]]]'
    show_state: true
    show_icon: false
    show_units: false
    name: '[[[ return variables.var_name ]]]'
    styles:
      name:
        - color: grey
      state:
        - color: |
              if (entity.state <= states["sensor.helper_temperature_outside_average"].state) return 'deeppink'; else return 'darkturquoise'
        - font-size: 25px
        - font-weight: bold
      card:
        - height: 50px
        - background-color: '#2c2c2e'
The template makes the rest of the code a lot more compact.
Have you ever managed to fix this? Running into the same problem.
Did you figure this out somehow?
Been struggling to create a card that shows days left until the next laundry day, bin day etc, based on a calendar date. The card should pretty much look like the attached screenshot. Are there any tutorials out there?
This is what the code looks like right now, without an entity or label.
entity: *
layout: vertical
icon: mdi:trash-can
show_state: false
show_name: true
show_label: true
show_entity_picture: false
color: auto
show_units: true
label: *
styles:
  name:
    - font-weight: bold
    - font-size: 17px
    - align-self: middle
  card:
    - height: 180px
    - width: 180px
  icon:
    - color: grey
    - position: absolute
    - top: 5%
  label:
    - height: 27px
