VietNgoc
(Ngoc John)
July 12, 2024, 5:04pm
7263
you can define additional logic, if the domain is sensor and use the correct form for theme variables, in case of sensor add attribute device class and their state
example for sensor battery, the correct theme var is:
var(--state-sensor-battery-high-color)
let class = entity.attributes.device_class;
color = `var(--state-${domain}-${class}-${state}-color);
or use default option for button card
Theme vars are not supported for sensors - at least acc. to Docs (((
Battery is an exclusion.
VietNgoc
(Ngoc John)
July 12, 2024, 5:17pm
7265
in the previous post, I made a quick demonstration just for the switch, for more complex cases you can use extra_styles and hardcode your own styles for each domain, avoiding repetitive code. And the variables theme works.
This is possible, but I do not think that this is what OP needed.
Agree that we can provide different ways to solve a problem.
frnak
(Frank Cassata)
July 13, 2024, 12:59pm
7267
Can someone help me understand or debug why the haptic option is not working for me? Iâve used the bubble card buttons before and they do haptics without exposing any settings for them, but Iâm unable to get the button card to do any haptics. Itâs obviously working on the device since it works with the aforementioned cards, but nothing happens with button cards. Config is just super basic:
type: custom:button-card
tap_action:
haptic: heavy
action: navigate
navigation_path: '#test'
Krona
July 14, 2024, 7:31pm
7268
Struggling with creating a header card thatâs stuck to the top, with a button at the end of it that will open a menu. The upper card is my old header (bubble card) which shows how it should look, the button under it is my new header (custom button card), but i havenât found out how to add the menu button at the end or make it stuck at the top of my view.
layout: icon_name
name: Home Assistant
primary: Home Assistant
secondary: ''
icon: mdi:home-assistant
icon_color: white
multiline_secondary: false
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
fill_container: false
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
ha-card-border-width: 0px;
styles:
card:
- height: 70px
- font-weight: bold
- font-size: 24px
- background-color: rgba(0, 0, 0, 0.0)
icon:
- width: 70%
- margin-left: '-60%'
name:
- margin-left: '-100%'
- margin-top: 4%
Edit: Nevermind, it was easier to edit the bubble card for a good result.
Krona
July 18, 2024, 8:18am
7269
Now iâm struggling with the text moving around on the card. How do i make the name and state always begin at a specific place on the card? If i copy the card to use with another entity, the name will move further to the right/left depending on how long the text is. The two cards on the bottom is custom buttons, the other ones are bubble buttons which is how itâs supposed to look.
The state of the battery should also always start at the percent.
square : false
type: grid
cards:
- type: custom:button-card
layout: icon_state_label
icon: mdi:battery
color_type: icon
entity: sensor.curtain_3_8155_batteri
show_state: true
show_name: true
show_label: false
state:
- value: '10'
operator: <
color: '#FF0000'
icon: mdi:battery-10
- value: '20'
operator: <=
color: '#ff6600'
icon: mdi:battery-20
- value: '30'
operator: <=
color: '#ff9933'
icon: mdi:battery-30
- value: '40'
operator: <=
color: '#ffcc00'
icon: mdi:battery-40
- value: '50'
operator: <=
color: '#FFFF00'
icon: mdi:battery-50
- value: '60'
operator: <=
color: '#FFFF00'
icon: mdi:battery-60
- value: '70'
operator: <=
color: '#FFFF00'
icon: mdi:battery-70
- value: '80'
operator: <=
color: '#CCFF33'
icon: mdi:battery-80
- value: '90'
operator: <=
color: '#66FF33'
icon: mdi:battery-90
- value: '100'
operator: <=
color: '#279b37'
icon: mdi:battery-full
styles:
grid:
- grid-template-areas: '"i n s"'
card:
- padding: 0%
- height: 55px
- background-color: rgba(1, 1, 1, 0.3)
img_cell:
- margin-left: 10%
- border-radius: 24px
- width: 40px
- height: 40px
- align-self: middle
- justify-self: start
state:
- margin-left: 45%
- font-size: 13px
name:
- font-weight: bold
- margin-left: '-21%'
name: Samsung Galaxy S22
icon: mdi:battery
color_type: icon
entity: sensor.sm_s908b_battery_level
show_state: true
show_name: true
show_label: false
state:
- value: '10'
operator: <
color: '#FF0000'
- value: '20'
operator: <=
color: '#ff6600'
- value: '30'
operator: <=
color: '#ff9933'
- value: '40'
operator: <=
color: '#ffcc00'
- value: '50'
operator: <=
color: '#FFFF00'
- value: '60'
operator: <=
color: '#FFFF00'
- value: '70'
operator: <=
color: '#FFFF00'
- value: '80'
operator: <=
color: '#CCFF33'
- value: '90'
operator: <=
color: '#66FF33'
- value: '100'
operator: <=
color: '#279b37'
styles:
grid:
card:
- padding: 0%
- height: 55px
img_cell:
- margin-left: 10%
- width: 40px
- height: 40px
state:
- margin-left: 45%
- font-size: 13px
name:
- font-weight: bold
columns: 1
silvio
(Silvio)
July 21, 2024, 6:54pm
7270
I have the same issue with the stack-in-card. I created many custom cards with the stack in card, but the loading is like loading a website on an old land line.m (back to the 90âs).
I hope the transition to custom button card ,will solve this.
Hello sebbaT, Can you please share the yaml code of your lightcard? That would be great!
Thank you!
Hello pimp1310,
Can you Share the code from the Climate Card?
newneo
(Neo)
August 7, 2024, 9:42am
7273
Hope Iâm in the right thread here!
Please help!
How can I place a dividing line in the lower area and a text in the middle underneath?
should look like this!
entity: sensor.tennis_atp_rafael_nadal_card
show_name: false
show_state: false
show_icon: false
styles:
grid:
- grid-template-areas: |
"template template template"
card:
- border-radius: null
- overflow: hidden
- position: relative
- padding: 0
- display: flex
- flex-direction: column
- justify-content: center
- align-items: center
custom_fields:
background-images:
- position: absolute
- inset: 0
- display: flex
- justify-content: space-between
- opacity: 0.3
foreground-images:
- inset: 0
- display: flex
- z-index: 0
custom_fields:
template:
card:
let state = states['sensor.tennis_atp_rafael_nadal'].state;
if (state === 'PRE') {
return `Text <br/>${entity.state}<br/> ${entity.attributes.pre_runde_start_zeit}`;
} else if (state === 'IN') {
return `${entity.attributes.in_ergebnis_sets}<br/>LIVE ${entity.attributes.in_live_ergebnis_score}<br/>
<div style="display: inline-block; text-align: right;">
${entity.attributes.in_spieler_score}<br/>
${entity.attributes.in_gegner_score}</div>`;
} else if (state === 'POST') {
return `Ergebnis ${entity.attributes.post_ergebnis_result}<br/>
} else if (state === 'NOT_FOUND') {
return 'Momentan Keine Tennis ATP Spiele';
styles:
card:
- background-color: transparent
- box-shadow: none
- font-weight: bold
- color: white
- font-size: 16px
background-images: |
return `
<img src="/local/sportpng/flagen/spanien.png" alt="Left Back" style="height: 13rem; width: 11rem;">
<img src="${states['sensor.tennis_atp_alexander_zverev'].attributes.opponent_logo}" alt="Right Back" style="height: 10rem; width: 10rem;">
foreground-images: |
return `
<img src="/local/sportpng/nadal.png" alt="Left Foreg" style="height: 7.5rem; ">
<img src="https://a.espncdn.com/combiner/i?img=/i/headshots/tennis/players/full/${states['sensor.tennis_atp_alexander_zverev'].attributes.opponent_id}.png" alt="Right Foreg" style="height: 7.5rem; ">
newneo
(Neo)
August 8, 2024, 6:38pm
7274
attempt 2 with the same result
entity: sensor.tennis_atp_card
show_name: false
show_state: false
show_icon: false
styles:
grid:
card:
- padding: 0
custom_fields:
images:
- inset: 0
custom_fields:
template:
card:
return 'Template Text <br/>';
styles:
card:
- box-shadow: none
- font-weight: bold
- color: white
- font-size: 16px
images: |
return `
<div style="position: absolute; inset: 0; opacity: 0.3; display: flex; justify-content: space-between; align-items: center;">
<img src="/local/sportpng/flagen/ger.png" alt="Left Background" style="height: 10rem; width: 10rem;">
<img src="/local/sportpng/flagen/ita.png" alt="Right Background" style="height: 10rem; width: 10rem;">
</div>
<div style="position: absolute; inset: 0; display: flex; justify-content: space-between; align-items: center; flex-direction: column;">
<div style="display: flex; justify-content: space-between; width: 100%;">
<img src="/local/sportpng/ke.png" alt="Left Foreground" style="height: 7.5rem;">
<img src="/local/sportpng/be.png" alt="Right Foreground" style="height: 7.5rem;">
</div>
jmfargas
(jmfargas)
August 22, 2024, 4:14pm
7275
Hi all, does anyblody know whether it is possible to get system attributes from the custom button card? Iâm trying to get the following attribute from an entity:
{{ device_attr(âcover.roller_roomâ, âconfiguration_urlâ) }}
Is there an equivalent in java of the above jinja2 code?
I tried:
entity.attributes.system_mode == âconfiguration_urlâ
But it doesnât work
Many thanks
Protoncek
(Pavel)
August 22, 2024, 5:02pm
7276
Try
states[âsensor.cover.roller_roomâ].attributes.configuration_url
jmfargas
(jmfargas)
August 22, 2024, 9:00pm
7277
I actually tried
states[âcover.roller_roomâ].attributes.configuration_url
But it dowsnât work since itâs a system parameter⌠It doesnât show up as an attribute of the entityâŚ
Hey all,
I have been racking my brain for a couple of hours / days over this;
This is what it currently looks like on PC, I would like the buttons to be âbiggerâ on PC as there is blank space at the bottom of the button that the text can take up (and has when I manually set it to a larger size).
tl;dr
Basically, I want to know - How do I change the height & width of the buttons depending on the size of the viewport/screen.
I know that Button Cards has extra_styles and I can target the @ media css query but I am not amazing at CSS.
Button Code:
show_icon: false
show_state: true
state_display: blah blah blah (temp value)
styles:
grid:
- grid-template-areas: '"switch button" "n n" "s s"'
- grid-template-rows: min-content min-content
card:
- padding: 6px 6px 3px 6px
- height: 100%
name:
- font-size: 16px
- font-weight: bold
- color: var(--primary-text-color)
- margin-top: 10px
- margin-bottom: 0px
state:
- font-size: 12px
- font-weight: bolder
- color: var(--secondary-text-color)
- margin-top: 4px
- text-wrap: wrap
custom_fields:
switch:
card:
entity: switch.plug_pc_switch
template:
- mini_button
button:
card:
entity: button.pc_hibernate
template:
- mini_button
styles:
card:
- align
Template Code:
button_card_templates:
mini_button:
show_name: false
show_state: false
variables:
icon_on: gold
icon_off: darkgray
show_borders: false
styles:
card:
- height: 40px
- width: 40px
- border: none
- border-color: red
- background-color: var(--secondary-background-color)
icon:
- transform: scale(0.75)
- color: |
if(entity?.state == 'on')
return variables.icon_on
else
return variables.icon_off
- width: 100%
jchh
((not John))
September 3, 2024, 9:50am
7279
Hi all,
Iâm trying to show/hide the name/state of my button depending on the window size.
I was hoping the following would work, but it doesnât. Does anyone have any ideas?
show_name: "[[[ if (Number(window.innerWidth) <= 1179) return 'false'; else return 'true'; ]]]"
show_state: "[[[ if (Number(window.innerWidth) <= 1179) return 'false'; else return 'true'; ]]]"
edit: I should add that setting label: does show the correct window size, but I canât get the comparison to work. Iâve tried with and without Number().
label: "[[[ return window.innerWidth ]]]"
you need to have the button update those templates
considering they will only update on state changes, youâre lostâŚ
unless, you set the triggers_update: option.
I tried something like you do now, but could only reliably have the buttons update using
triggers_update: all
it is not recommended to use that though, as it is rather active, updating on all state changes
jchh
((not John))
September 6, 2024, 4:06pm
7281
For anyone that is interested in the future, after bunch of testing, the problem appears to related to the return 'false' which seems to have a special meaning in javascript.
I would say - âfalseâ is not false because it is a string.
