Lovelace: Button card
@RomRider, make a break! :slightly_smiling_face:
We have to edit our buttons every day with new features.
Yup, I love the work you are doing, you made this card from unusable to better than ever in just a few weeks.
And I do love it, but your health comes first mate. That is the beauty of Home Assistant, that most people will have patience.
Any way to support you @RomRider ? Donations for example?
@RomRider, First Render issue seems fixed in my cases. Thanks for diverting off into the config-template-card for a moment.
THANKS, truly appreciated.
Donā€™t worry, it doesnā€™t take that much time :blush: but thanks!
The card is now in a better shape, development will probably slow down a bit. Feel free to open issues or new feature requests on github though :wink:
I have some more ideas, but now I want to use the new card in my own setup first :joy:
I do that for fun and to learn, i didnā€™t know much about frontend development 2 weeks ago :sweat_smile:
Best way to support that: do great things with the card and share your setup with others :slight_smile:
This card is wonderful and Iā€™m having great fun playing with it. Could someone offer some help with my stylingā€¦I am trying to set the border-color (ignore the color choice, they are random and just for testing :joy:)
cards:
  - type: custom:compact-custom-header # Compact header config
  - type: vertical-stack
    cards:
      - type: custom:card-modder # BANNER PICTURE ELEMENT
         ...blah blah....
      - type: horizontal-stack # FIRST ROW OF BUTTONS
        cards:
          - type: custom:button-card
            entity: light.living_room
            color_type: card
            icon: mdi:lightbulb
            tap_action:
              action: toggle
            hold_action:
              action: more-info
            state:
              - value: "on"
                color: '#1782ed'
                style:
                  - border-color: '#ed17cc'
                  - border-radius: 25px
              - value: "off"
                style:
                  - border-color: '#1782ed'
            size: 50% # SIZE OF THE ICON INSIDE THE BUTTON
            style:
              - height: 30px # HEIGHT OF THE CARD/BUTTON
The - border-color: command isnā€™t doing anything, however the - border-radius: 25px command does work. Any suggestions?
Setting it like this:
- border: 2px solid #ed17cc
Creates a solid white border, but not the color
Ok so I rebooted hassio and now it works! Problem solved!
Thanks again for creating such a brilliant and versatile card!
I definitely will share my setup as I always do, just working on all new stuff and ideas and Iā€™ll push my setup on github.
Just a question though. One of the previous versions fixed the color: auto setting for entities that didnā€™t support RGB, however I get this now when the brightness is low, it looks more blackish (not the way core does it) however it might be a setting I set wrong ofcourse.
               - type: "custom:button-card"
                    entity: light.woonkamer_led_lampen
                    icon: "mdi:led-strip"
                    color: auto
                    tap_action:
                      action: toggle
                      haptic: light
                    hold_action:
                      action: more-info
                      haptic: success
                    state:
                      - value: "on"
                        style:
                          - border-radius: 20px
                          - height: 85px
                          - padding: 20%
                          - font-size: 11px
                          - border-style: solid
                          - border-width: 1px
                          - border-color: '#e5e5e5'
                          - --paper-card-background-color: rgba(20, 20, 20, 0.4)
                          - white-space: nowrap
                      - value: "off"
                        style:
                          - height: 85px
                          - padding: 20%
                          - font-size: 11px
                          - box-shadow: 2px 2px rgba(0,0,0,0.3)
I also have a question, with that same setting I have words that are too long cut off (whereas the core entity-button doesnā€™t). I even lowered the font size to 11px (down from 13px) to make it fit, but for some it worked, for some it didnā€™t.
Iā€™ve been using the button card for awhile and now need to start using some more advanced features. In particular, Iā€™m interested in the template feature, but havenā€™t been able to get it to work. Furthermore, I cannot get much of the state ā€œoperatorā€ capability. Iā€™ve gutted my lovelace ui file to whatā€™s below (in case there were some conflicts). I have an entity switch.ac1_enabled and when the value is ā€˜onā€™ the card shows in blue as expected. If I change the matching value in the configuration from ā€œonā€ to ā€œblahā€, I would expect the card to show up in green given the ā€œdefaultā€ value, but it doesnā€™t work. It shows in black. My thought is that whatever is stopping this from working, is also stopping the templating capability from working for me.
This morning I download (via wget) the latest version of button-card.js and put it into the www directory. I figured there must be something simply that Iā€™m not doing right, but I cannot figure it out.
  - path: Test
    icon: 'mdi:water'
    cards:
      - name: Test Card
        color_type: card
        type: 'custom:button-card'
        state:
          - value: 'on'
            color: blue
          - operator: default
            color: green
        entity: switch.ac1_enabled
        show_state: true
    title: Water
resources:
  - type: module
    url: /local/button-card.js
Just from a quick look I think that you probably need operator: default to be in single quotes just like your value: 'on' is.
So for example:
          - operator: 'default'
            color: green
Thanks for the response. In the many hours spent trying to get this to work I had tried it both ways with no luck.
I just tested your button on my setup real quick and it worked fine here with my TV switch. Showed blue when on and green when off. It also showed the green default color when i changed ā€˜onā€™ value to ā€˜blahā€™ā€¦ Thatā€™s what you want right? I am not sure why itā€™s not working for you, but you could maybe just change it to this instead since switches only have two values afaik:
- name: Test Card
  color_type: card
  state:
    - value: 'on'
      color: blue
    - value: 'off'
      color: green
  show_state: true
Here is a working example of one I did for Spotify too which might help.
  entity: media_player.spotify
  icon: mdi:spotify
  color_type: icon
  tap_action:
    action: service
    service: media_player.media_play_pause
    service_data:
      entity_id: media_player.spotify
  hold_action:
    action: more-info
  state:
    - value: 'playing'
      color: "#1db954"
    - value: 'paused'
      color: var(--disabled-text-color)
      style:
        - animation: blink 2s ease infinite
When playing music itā€™ll be green, and when paused the color changes to a gray-ish and it blinks.
Thanks for the assistance. The discussion reminded me that my version of HA was several months outdated as each time I had attempted an upgrade it had failed. I just managed to get the RPi upgraded to HA 0.92.1 and that allowed the test configuration to work the way its supposed to.
Thanks again!
Iā€™ll check that :slight_smile: I remember having used the same formula as core
EDIT: You were absolutely right, next PR is going to fix that!
padding with a single value adds an invisible border all around the button (top, bottom, left and right), that also shrinks the size of the element that contains the text. First, I donā€™t think that you still need it with the latest version, as you can resize the icon and the button completely.
However if you want to keep your padding then padding: 20% 0px will be the solution (20% is top and bottom, 0px is left and right)
It was probably a cache issue @flyboy. I tried your setup and default is behaving as expected.
Let me know if there is any more issue.
No quotes around the javascript code :wink: in yaml, key: > means that everything on the following indented lines is a string. I will add some code to remove quotes if someone adds them, that will help to avoid dealing with lots of github issues :stuck_out_tongue:
Also looking at your config @jimz011, it makes me think that maybe the style options should be additive between the main part of the config and each state to avoid code duplication. What do you people think?
@RomRider Right. If you style inside the state, it ignores styles outside of the state. So yes, styles inside the state should add to styles outside, and override if there is a conflict.
Also want to say, you have made this button one of the most important elements in Lovelace. Iā€™m looking forward to seeing how people create innovative panels with this button.
Off-topic, (but Iā€™d like to know from people using this button) does anyone use Layout Card or something else to establish card order?
Cheers, Richard
@RomRider is there a way to have the buttons centered ?
If I donā€™t mentioned the width on the last button it gets very wide as you see on the green button.
I try to have uniform buttons.
@elRadix, add 1 color_type: blank-card on each side of your horizontal-stack, both without a width and it will be centered
can you show me how, not getting any results
See card config here:
cards:
  - type: 'custom:button-card'
    color: 'rgb(0,0,0.5)'
    color_off: var(--disabled-text-color)
    color_type: card
    default_color: var(--primary-text-color)
    style:
      - font-size: 20px
      - font-weight: bold
      - padding: 0px
      - height: 45px
  - cards:
      - card_style: ''
        color: 'rgb(255, 255, 0)'
        color_off: 'var(--disabled-text-color)(189, 255, 5)'
        color_type: card
        entity: switch.stp_living_other
        icon: 'mdi:power-socket-eu'
        show_name: false
        hold_action:
          action: more-info
          haptic: success
        state:
          - value: 'on'
            style:
              - height: 70px
              - width: 70px
              - border-radius: 50px
              - border-width: 2px
          - value: 'off'
            style:
              - height: 70px
              - width: 70px
              - font-size: 11px
              - box-shadow: '2px 2px rgba(0,0,0,0.3)'
      - card_style: ''
        color_type: card
        entity: switch.living
        icon: 'mdi:battery-charging-40'
        show_name: false
        hold_action:
          action: more-info
          haptic: success
        state:
          - value: 'on'
            style:
              - height: 70px
              - width: 70px
              - border-width: 2px
          - value: 'off'
            style:
              - height: 70px
              - width: 70px
              - font-size: 11px
      - card_style: ''
        color_type: card
        entity: switch.stp_living_bureau
        icon: 'mdi:speaker-wireless'
        show_name: false
        hold_action:
          action: more-info
          haptic: success
        state:
          - value: 'on'
            style:
              - height: 70px
              - width: 70px
              - border-width: 2px
          - value: 'off'
            style:
              - height: 70px
              - width: 70px
              - font-size: 11px
@RomRider - do you have on your ā€˜to-doā€™ list the ability to individually customise text, icon, and card colour depending on either the card entity state or another specified entity by any chance please? I canā€™t see any reference to this in the GitHub readme or open issues, so happy to create a new one for tracking if you like?
Thanks.
Try this below :slight_smile:
cards:
    color_type: card
    style:
      - font-size: 20px
      - font-weight: bold
      - padding: 0px
      - height: 45px
  - cards:
      - card_style: ''
        color_type: card
        show_name: false
        hold_action:
          action: more-info
          haptic: success
        state:
          - value: 'on'
            style:
              - height: 70px
              - width: 70px
              - border-width: 2px
          - value: 'off'
            style:
              - height: 70px
              - width: 70px
              - font-size: 11px
      - card_style: ''
        color_type: card
        show_name: false
        hold_action:
          action: more-info
          haptic: success
        state:
          - value: 'on'
            style:
              - height: 70px
              - width: 70px
              - border-width: 2px
          - value: 'off'
            style:
              - height: 70px
              - width: 70px
              - font-size: 11px
      - card_style: ''
        color_type: card
        show_name: false
        hold_action:
          action: more-info
          haptic: success
        state:
          - value: 'on'
            style:
              - height: 70px
              - width: 70px
              - border-width: 2px
          - value: 'off'
            style:
              - height: 70px
              - width: 70px
              - font-size: 11px
Please do so yes :slight_smile:
great tip, thank you very much !!!
