Lovelace: Button card
This should work
state:
  - value: -4 # no quotes here
Very cool, as you say everything important at a glance. Would you mind sharing your lovelace config somewhere(pastebin?) please.
OMG I am such an idiot, it seems I forgot the ; at the end of the lines OMG! Oh well, it works again, thanks again for you input everyone.
I have no idea why, but the ā€œtype:ā€ lines keep migrating to the bottom of the cards. Gave up trying to stop it ages ago.
Iā€™m in the middle of fixing up the vacuum view but when Iā€™ve done that I will.
No ; is required for styles. If you put it, the line is ignored by the code :blush:
You sure did :-
:slight_smile: I know its a lot of time and relentless editing to get it to where it is right now, so thank you once again.
Im not sure if this may help, in the code you shared, i did add 1 to the rgba value under styles since the value of a was missing, or maybe i have a translucent buttons and i wanted the ON to be more opaque.
        state:
          - value: "on"
            styles:*emphasized text*
              card:
                - --paper-card-background-color: rgba(255, 251, 239*, 1.0*)
                - box-shadow: none
              name:
                - color: black
              state:
                - color: gray
I wanted to ask how is the value of the brightness displayed under 100%? mine takes a value under 255%
im using
            label_template: >
              var bri = states['light.mbed_led'].attributes.brightness;
              return (bri ? bri : '0') + '%';
Here you go. Itā€™s got everything, so itā€™s pretty long. https://pastebin.com/6R7Ww1rS
Hey @RomRider , amazing work on the Button Card, its made my UI a lot more appealing and elegant , thank you on this tip, it solved the dot on the cardā€¦ its much cleaner looking now.
I made some remote buttons, still making changes on them.
Ah ok I see (not a programmer srry). Anyways then, it was the filter: invert(70%) line. I removed this and all is good now! I hardcoded the color instead of it being variable.
But anyways it no longer artifacts. Been working for a day now without problems.
I also took the time to put your card in at more locations :stuck_out_tongue:
Here is an example of how I use it:
@Prathik_Gopal You can use this for scaling to a 100:
label_template: >
  var bri = Math.round(states['light.your_light_here'].attributes.brightness / 2.55);
Does anyone know how to make the state a bit more pleasing aesthetically? For some reason it always shows an underscore. I know it would be possible by creating a template sensor, but if there was any faster way to do it it would be nice to know, thanks.
Iā€™ve finally managed to take some time and play with the card, thatā€™s some tabs of my current setup :blush:
And another (click to zoom, I donā€™t know why itā€™s not displayed correctly):
Iā€™ll soon release the new version :blush:
Iā€™ll soon introduce localization support to fix that :slight_smile: In the meantime, you can use the label instead.
Looks awesome! Glad to see you get to enjoy the fruits of your labor, too. :+1:
Iā€™d love to see your YAML - is that Alexa radio section using state-switch and vertical-stack-in-card?
Alsoā€¦ is that second screenshot what I think it is? A resizable version of the Light Card? I was intrigued by that card when I was first playing with Lovelace, but the lack of resizability made it a non-starter on mobile. Never mind, for some reason, that part specifically was blown up on the screenshot preview, after clicking it to show the whole screenshot I realized I donā€™t think you were trying to highlight that specifically. :joy:
Yeah, I donā€™t know why the second image is displayed like thatā€¦ :sweat_smile:
Going to share the yaml soon, but Iā€™m not home right now.
You are very right, it took me over 7 hours to get it exactly the way I wanted it. Trial and error and retry and retry. I am glad it helped you out. I will post a cleaned up version of the code later on as the previous code was still bloated with things I used in my previous setup.
My wife always liked the Homekit app, but she did not like the layout. As Homekit has the same tight layout as iOS it is hard to make an interface with Homekit that is not only great looking (which it already does) but most importantly easy to use. And with over 100 devices Homekit is no fun to use at all. So this made it a perfect middle route. (Though she got used to my previous setup).
Do you have 3 buttons joined up in your first screenshot without any padding between them? (The one with the padlock symbol and record player icon)
Edit: it actually looks like a vertical-stack-in-card?
Is there any way I can have the icon change color in case last_motion (as example) was less then 1 hour ago?
Also; how can I get the label closer to the bold text (so move up a bit)?
07
cards:
  - entity: group.motion_check
    icon: 'mdi:walk'
    layout: icon_name
    tap_action:
      action: more-info
    show_state: false
    show_last_changed: true
    show_name: yes
    styles:
      card:
        - height: 80px
        - width: 150px
      icon:
        - padding: 5px 60px 0px 10px
        - margin: 3px
      name:
        - padding: 0px 0px
        - font-size: 15px
        - font-family: Helvetica
        - justify-self: start
        - font-weight: bold
      label:
        - font-size: 11px
        - padding: 0px 10px
        - justify-self: end
      state:
        - font-size: 15px
        - padding: 0px 10px
        - justify-self: end
        - text-transform: capitalize
        - font-weight: bold
    type: 'custom:button-card'
  - entity: sensor.last_pin_vera
    icon: 'mdi:tag'
    layout: icon_state
    tap_action:
      action: more-info
    show_state: true
    show_name: false
    styles:
      card:
        - height: 80px
        - width: 150px
      icon:
        - padding: 0px 60px 0px 10px
        - margin: 5px
      name:
        - font-size: 13px
        - justify-self: end
        - font-weight: bold
      label:
        - font-size: 11px
        - padding: 0px 10px
        - justify-self: end
      state:
        - font-size: 15px
        - padding: 0px 10px
        - justify-self: end
        - font-weight: bold
type: horizontal-stack
I donā€™t think moving the text is possible without using padding, but if I am correct (someone correct me if I am wrong) you could add this to your label or state style:
padding: 40px 0px 0px 0px
If I am correct this should move the text up but it could be one of the other numbers (which are at zero in my example). You will have to play around to be sure.
Alternatively you can wait until next update as @RomRider said it will be easier to move elements in the next version. And with the speed this man works I am guessing it will take no longer than 2 weeks.
Edit:
For the ones looking for it, I made the Homekit button code a bit cleaner, it still isnā€™t the cleanest, but it is less cluttered then the last code I posted.
              - type: custom:button-card
                entity: light.bijkeukenlamp
                icon: "mdi:ceiling-light"
                label_template: >
                  var bri = Math.round(states['light.bijkeukenlamp'].attributes.brightness / 2.55);
                color: auto
                show_state: true
                show_label: true
                styles:
                  card:
                    - border-radius: 15px
                    - height: 105px
                    - width: 105px
                    - --paper-card-background-color: rgb(255, 251, 239)
                  icon:
                    - padding: 0px 60px 0px 0px
                  name:
                    - padding: 0px 10px
                    - font-size: 13px
                    - font-weight: bold
                  label:
                    - color: gray
                    - font-size: 11px
                    - padding: 0px 10px
                  state:
                    - font-size: 11px
                    - padding: 0px 10px
                    - font-weight: bold
                state:
                  - value: "on"
                    styles:
                      name:
                        - color: black
                      state:
                        - color: gray
                  - value: "off"
                    style:
                      - opacity: 0.4
                    styles:
                      icon:
                        - color: '#666666'
                      name:
                        - color: '#666666'
                      state:
                        - color: '#666666'
                  - value: "unavailable"
                    style:
                      - opacity: 0.2
                    styles:
                      icon:
                        - color: '#666666'
                      name:
                        - color: '#666666'
                      state:
                        - color: '#666666'
Thatā€™s for the color when last changed is less then 1h:
state:
  - operator: template
    value: >
      var last_changed = new Date(entity.last_changed);
      var now = new Date();
      return (now - last_changed) / 1000 / 60 / 60 <= 1
Use layout: icon_name_state2nd
It is indeed a vertical-stack-in-card, with lots of stuff inside:
- type: vertical-stack
  cards:
    styles: *card-header-style
  - type: horizontal-stack
    cards:
        entity: input_select.alexa_source
        color_type: card
        icon: mdi:radio
        layout: icon_name
        tap_action:
          action: call-service
          service: input_select.select_option
          service_data:
            entity_id: input_select.alexa_source
            option: 'Webradio'
        styles:
          card:
            - font-size: 0.8em
            - font-weight: bold
        state:
          - value: 'Webradio'
            color: white
            name: ā–¾ Webradio ā–¾
          - operator: default
            color: var(--paper-card-background-color)
        color_type: card
        icon: mdi:spotify
        layout: icon_name
        tap_action:
          service_data:
            option: 'Spotify'
        styles:
          card:
            - font-size: 0.8em
            - font-weight: bold
        state:
          - value: 'Spotify'
            color: white
            name: ā–¾ Spotify ā–¾
          - operator: default
        color_type: card
        icon: mdi:format-list-bulleted-square
        layout: icon_name
        tap_action:
          service_data:
            option: 'Predefined'
        styles:
          card:
            - font-size: 0.8em
            - font-weight: bold
        state:
          - value: 'Predefined'
            color: white
            name: ā–¾ Predefined ā–¾
          - operator: default
    cards:
      - type: custom:vertical-stack-in-card
        cards:
            cards:
                entity: input_select.alexa_destination
                icon: mdi:amazon-alexa
                layout: icon_name
                styles:
                  card:
                    - font-size: 0.8em
                    - font-weight: bold
                    - height: 40px
                  grid:
                    - grid-template-columns: min-content min-content
                    - width: min-content
                    - margin: auto
                    - grid-gap: 0px 10px
                tap_action:
                  service_data:
                    entity_id: input_select.alexa_destination
                    option: 'Office'
                state:
                  - value: 'Office'
                    color: var(--paper-item-icon-active-color)
                    styles:
                      name:
                        - color: var(--paper-item-icon-active-color)
                  - operator: default
                    color: var(--primary-text-color)
                layout: icon_name
                styles:
                  card:
                    - font-size: 0.8em
                    - font-weight: bold
                    - height: 40px
                  grid:
                    - margin: auto
                tap_action:
                  service_data:
                    option: 'Bathroom'
                state:
                  - value: 'Bathroom'
                    styles:
                      name:
                  - operator: default
            cards:
                cards:
                  - type: conditional
                    conditions:
                    - entity: input_select.alexa_source
                      state: Predefined
                    card:
                      type: custom:card-modder
                      style:
                        padding: 5px 16px
                      card:
                        type: entities
                        show_header_toggle: false
                        entities:
                        - input_select.predefined_music
                  - type: conditional
                    conditions:
                      state_not: Predefined
                    card:
                      style:
                        padding: 5px 16px
                      card:
                        type: entities
                        entities:
                        - input_text.alexa_music_input
                icon: mdi:play
                show_name: false
                styles:
                  card:
                    - width: 60px
                    - height: 100%
                tap_action:
                  service: script.alexa_play
                  service_data:
                    useless: useless
Itā€™s a vertical stack in card with 6 buttons inside:
  cards:
    cards:
      cards:
        entity: switch.player1_power
        icon: mdi:disc-player
        lock: true
        styles:
          card:
            - font-size: 0.8em
            - height: 100%
        cards:
          entity: input_select.subwoofer_preset
          layout: icon_name
          tap_action:
            action: none
          show_icon: true
          styles:
            grid:
              - margin: auto
            card:
              - font-size: 0.8em
          show_icon: false
          tap_action:
            service_data:
              entity_id: input_select.subwoofer_preset
              option: 'Off'
          styles:
            card:
              - font-size: 0.8em
              - font-weight: bold
          state:
            - value: 'Off'
              styles:
                name:
          show_icon: false
          tap_action:
            service_data:
              option: 'LFC'
          styles:
            card:
              - font-size: 0.8em
              - font-weight: bold
          state:
            - value: 'LFC'
              styles:
                name:
          show_icon: false
          tap_action:
            service_data:
              option: 'Line-In'
          styles:
            card:
              - font-size: 0.8em
              - font-weight: bold
          state:
            - value: 'Line-In'
              styles:
                name:
        entity: switch.player2_power
        lock: true
        styles:
          card:
            - font-size: 0.8em
            - height: 100%
Before the weekend so that you have time to play with :stuck_out_tongue:
