Just one question
HOW you do that
that is so sexly
Just one question
HOW you do that
that is so sexly
Use the label
to customize the show last changed part:
styles:
label:
Iām looking for something like this for TV - you can share this code
How did you get that glow effect around your buttons? It looks amazing.
Sure, here you go:
- type: horizontal-stack
cards:
- type: custom:vertical-stack-in-card
cards:
cards:
- type: custom:card-modder
style:
padding: 5px 16px
card:
type: entities
show_header_toggle: false
entities:
- type: custom:slider-entity-row
entity: media_player.player1
icon: mdi:volume-high
- type: custom:button-card
icon: mdi:volume-minus
tap_action:
action: call-service
service: input_number.decrement
service_data:
entity_id: input_number.player1_volume
styles:
card:
- width: 40px
- height: 100%
icon: mdi:volume-mute
show_name: false
tap_action:
service: script.mute_unmute_entity
service_data:
entity_id: media_player.player1
styles:
card:
- width: 40px
- height: 100%
state:
- operator: template
value: >
return states['media_player.player1'].state != 'off'
&& states['media_player.player1'].attributes.is_volume_muted;
color: '#FF0000'
- operator: default
color: var(--primary-text-color)
icon: mdi:volume-plus
tap_action:
service: input_number.increment
service_data:
styles:
card:
- width: 40px
- height: 100%
You can use this to generate your box shadow:
And then paste the result here:
styles:
card:
- box-shadow: RESULT_HERE
What I brilliant link. Thanks very much.
@RomRider The CSS world is quite new for me and acquires quite some study to understand.
Iām still struggling what the best way is to move the ālabelā (last_changed) up to be directly under either the state or name. The icon_name_state2nd does not do the job. The padding Jimz011 suggested also not.
Yeah, Iād like to possibly use it on the shadows. I was wondering if i could template it with the template card. Havenāt researched it. Hoping there was an easier way.
These are the anchors that Iām currently using for lights and switches:
custom_button_switch_active_glow: &custom_button_switch_active_glow
type: "custom:button-card"
layout: icon_label
show_state: true
show_name: true
show_label: false
styles:
grid:
- grid-template-rows: 30px auto 30px
card:
- border-radius: 15px
- height: 105px
- width: 105px
- margin: 0px 5px 0px 0px
icon:
- align-self: end
- height: 30px
- width: 30px
name:
- justify-self: start
- padding: 0px 10px
- font-size: 13px
label:
- align-self: end
- padding: 1px
- font-size: 11px
- font-weight: bold
- font-family: Helvetica
- text-transform: capitalize
state:
- font-size: 11px
- font-weight: bold
- align-self: end
- padding: 5px 10px
state:
- value: "on"
styles:
card:
- --paper-card-background-color: rgba(40, 40, 40)
- box-shadow: 0px 0px 20px 3px var(--paper-item-icon-active-color)
icon:
- color: var(--paper-item-icon-active-color)
name:
- color: white
state:
- color: white
label:
- color: white
tap_action:
action: toggle
hold_action:
action: more-info
custom_button_light_active_glow: &custom_button_light_active_glow
layout: icon_label
show_state: true
show_name: true
show_label: true
styles:
grid:
card:
- height: 105px
- width: 105px
icon:
- align-self: end
- height: 30px
- width: 30px
name:
- padding: 0px 10px
- font-size: 13px
label:
- align-self: end
- padding: 1px
- font-size: 11px
- font-weight: bold
state:
- font-size: 11px
- font-weight: bold
- align-self: end
- padding: 5px 10px
state:
- value: "on"
styles:
card:
icon:
name:
- color: white
state:
- color: white
label:
- color: white
- value: "off"
styles:
label:
- color: rgba(0, 0, 0, 0.0)
tap_action:
action: toggle
hold_action:
action: more-info
Then to use them you just need to call out the anchor properly and add the missing attributes.
This is an example of a light that turns a group on and off (switch template controls group, label_template counts lights that are on).
- <<: *custom_button_light_active_glow
entity: switch.living_room
icon: mdi:alpha-l-box
label_template: >
var i;
var entities = states['group.living_room'].attributes.entity_id;
var count = 0;
for (i = 0; i < entities.length; i++) {
var state = states[entities[i]].state;
if (state === 'on') {
count += 1;
return count.toString() + ' of ' + entities.length.toString();
This is a normal dimmer. Nothing too crazy.
label_template: >
var bri = Math.round(states['light.living_room'].attributes.brightness / 2.55);
return (bri ? bri : '0') + '%';
entity: light.living_room
And this is a switch.
- <<: *custom_button_switch_active_glow
entity: switch.living_room_window
Anchors make it easy to adjust all your buttons at once and shrink your config from 5k lines to 1k lines. Very useful.
Next version will include this feature itās already developed, Iāll release it probably tonight (for me)
Slow down man. Take a coffee break! Thanks for all the work. This card forced me to learn CSS which was on my bucket list. I canāt thank you enough for just that alone.
The next release will include a fix for this when there is no state displayed. Youāll have to use layout: icon_name_state2nd
It was literally 1 line of code
NEW FEATURES
hold_action
now has a new parameter: repeat
(in milliseconds). If set, while you hold the button, the action will repeat itself every repeat
in milliseconds. Fixes #147
entity: input_number.test
show_state: true
hold_action:
repeat: 500
service_data:
entity_id: input_number.test
New double click action: dbltap_action
(this introduces a slight delay [250ms] for single click actions on buttons where you also use double tap)
show_state: true
hold_action:
repeat: 500
service_data:
dbltap_action:
service_data:
styling for the lock, available also per state (Fixes #150)
styles:
lock:
- color: red
- align-items: flex-end
- justify-content: flex-start
You can now use the current light color in your CSS styles. If a light entity is assigned to the button, the CSS variable --button-card-light-color
will contain the current light color so that you can use it where you want on your card. Example:
styles:
name:
color: var(--button-card-light-color)
card:
- -webkit-box-shadow: 0px 0px 9px 3px var(--button-card-light-color)
- box-shadow: 0px 0px 9px 3px var(--button-card-light-color)
FIXES
when there was no state.The multiple card embedding you have there for the volume slider example is excellent! Itās amazing what you can do with these custom cards - half the trouble is figuring it all out!
Thanks for sharing @RomRider
You gotta get inventive with combinations. You can come up with some pretty cool cards using vertical-in-stack-card. Itās what makes these card comboās flat
EDIT: I need to replace the uptime w/ this button card to get an icon and some nice styling. Thatās using the built in button-card.
EDIT: Another tip is to make your background and shadow for cards transparent, this anchor will get you that with the card-modder card:
transparent_background: &transparent_background
type: 'custom:card-modder'
style:
--ha-card-background: "rgba(0, 0, 0, 0.0)"
--ha-card-box-shadow: 'none'
# The filter card will filter entities for their state
- <<: *transparent_background
card:
type: ...etc...
Thanks. I must try anchors out when I am brave enough.
Theyāre only hard if you donāt understand data structures in yaml.
This is a pretty good read here:
I started using anchors yesterday based on @petroās (thanks for the tip!) previous posts and I really like what it can do to save space and make it easier to navigate the UI file.
For example, in the same ui-lovelace.yaml file, I have anchors at the start (just after resources), and refer to them throughout that file.
anchors:
custom_button_motion: &custom_button_motion
color_type: card
show_name: true
show_icon: true
show_last_changed: true
styles:
label:
- font-size: 10px
card:
- border-radius: 10px
state:
- value: "on"
color: rgb(71,39,45) #Red
icon: mdi:run-fast
styles:
label:
- color: rgb(220,69,121)
icon:
- value: "off"
color: rgb(49,68,42) #Green
icon: mdi:run
styles:
label:
- color: rgb(134,219,85)
icon:
title: Home
- title: New View
icon: mdi:view-dashboard-variant
panel: false
path: newview
cards:
- type: vertical-stack # Motion
cards:
- type: horizontal-stack # Motion Title
cards:
- type: "custom:button-card"
styles:
card:
- height: 30px
- padding: 0px 0px
- type: horizontal-stack # Motion Buttons Lvl 1
cards:
- <<: *custom_button_motion # Study
entity: binary_sensor.motion_study_occupancy
- <<: *custom_button_motion # Lounge
entity: binary_sensor.motion_sensor_158d0001ad5c5c
- <<: *custom_button_motion # Kitchen
entity: binary_sensor.motion_sensor_158d0001e43b9f
- <<: *custom_button_motion # Downstairs Hall
entity: binary_sensor.motion_hall_downstairs_occupancy
- <<: *custom_button_motion # Upstairs Hall
entity: binary_sensor.motion_sensor_158d0001ad4ad6
- type: horizontal-stack # Motion Buttons Lvl 2
cards:
- <<: *custom_button_motion # Garage
entity: binary_sensor.motion_sensor_158d0001ad3413
- <<: *custom_button_motion # Porch
entity: binary_sensor.motion_sensor_158d0001ad3403
- <<: *custom_button_motion # Bed 1
entity: binary_sensor.motion_sensor_158d0001ad33f3
- <<: *custom_button_motion # Bed 2
entity: binary_sensor.motion_sensor_158d0001ad698e
- <<: *custom_button_motion # Bed 3
entity: binary_sensor.motion_sensor_158d0001ad4a0f
@petro Iād love to see the yaml behind your NUC and Switch cards, along with details on the brushed metal background and colour theme there please?
Yes, I will share. Iām rebuilding the interface and sensors for the sole purpose of making a github page for my configuration. I plan to have it posted in the next few days.
