Thanks for quick answer. That is actually pretty cool!
Anyway to configure it, in case I would like the button to react only to brightness (not sure I do, but just in case)?
Itās not possible to configure it, but I can think about something, please open a feature-request on github
Iām liking the spin animation on icons in some cases, but looking to make something a bit more subtle for other icons (more like a sway). Has anyone played around with adding animations?
I suspect defining ā- webkit-animation:ā under style would work, unfortunately defining the animation keyframes there also doesnāt work, and I donāt know enough to work out how to get around that.
Use card-modder to inject this CSS using the extra_styles
property:
@keyframes mysway {
0%, 100%{ transform: rotate(-8deg);}
50%{ transform: rotate(6deg); }
Then on the button-card:
styles:
icon:
- animation: mysway 16s infinite
Play with the numbers to suit your needs
Ah, I know what happened now - the input_boolean needs to be ON when you refresh the browser, otherwise it doesnāt render the buttons⦠@iantrich do you know if thereās a better way of doing this instead of using input_boolean?
@dmatik what does those icons look like when off? What version of the card are you using? I have auto color working for shadows and icon color w/ no problem on v 1.8.0.
Add the padding in custom_button_motion and youāll get it to work.
custom_button_motion: &custom_button_motion
type: "custom:button-card"
color_type: card
show_name: true
show_icon: true
show_last_changed: true
styles:
label:
- font-size: 10px
card:
- border-radius: 10px
- padding: 10px 10px 0px 0px
name:
- font-size: 15px
grid:
- grid-template-areas: '"i n" "i l"'
- grid-template-columns: min-content min-content
- width: min-content
- grid-gap: 0px 2px
state:
- value: "on"
icon: mdi:run-fast
<<: *custom_button_state_red
- value: "off"
icon: mdi:run
<<: *custom_button_state_green
Brilliant! Thanks!
Works a treat, just wish I could define it globally as things are getting a bit crazy with different layers of custom cards now as Iām also using template-config in some places
I am interested too in animated icons, can I find this in the docs how to do that? Or does it only work with gifs?
Have a look at the spin option in the docs - it spins the regular icons - but thereās quite a few effects you can achieve using CSS
Iāve played a bit with all the stuff lately and wanted to simulate a menu, hereās the result using an input_boolean to trigger a conditional card. Also the menu resets itself after 15sec
The input_boolean part:
input_boolean:
lovelace_menu_ikea_spots:
lovelace_menu_falcon:
lovelace_menu_covers:
automation:
- alias: lovelace_reset_menu
hide_entity: true
- platform: state
entity_id: input_boolean.lovelace_menu_ikea_spots
to: 'on'
- platform: state
entity_id: input_boolean.lovelace_menu_falcon
to: 'on'
- platform: state
entity_id: input_boolean.lovelace_menu_covers
to: 'on'
- wait_template: >
{{ is_state(trigger.entity_id, 'off') }}
timeout: '00:00:15'
continue_on_timeout: 'true'
- condition: template
value_template: >
{{ is_state(trigger.entity_id, 'on') }}
- service: input_boolean.turn_off
data_template:
entity_id: "{{ trigger.entity_id }}"
Will have a look at that for sure. Iād like my fan icons to spin for example. Thanks a lot.
How do you get the botton with only color so thin? Mine is more like the old one in therms of height.
Iāve noticed some odd css behavior. The longer a button gets, the grid shifts down pixels and squeezes the grid-template-rows. And css auto will calculate zero for text height. Iāve been trying to fight this for a bit. I have this configuration.
All buttons have a static icon height/width of 30px x 30px inside the upper left grid spot which is 50px x 50px.
small button
medium button
large button
type: horizontal-stack
cards:
- type: custom:button-card
color_type: blank-card
styles:
card:
- width: 10px
- type: "custom:button-card"
layout: icon_label
color: auto
show_state: false
show_name: true
show_label: true
icon: mdi:music-note
label: Media
styles:
grid:
- grid-template-rows: 50px auto auto
- grid-template-columns: 50px auto
card:
- border-radius: 15px
- height: 76px
- width: 342px
- margin: 5px 5px 0px 0px
- --paper-card-background-color: rgba(40, 40, 40)
- box-shadow: 0px 0px 10px 3px var(--paper-item-icon-active-color)
icon:
- color: var(--paper-item-icon-active-color)
- height: 30px
- width: 30px
name:
- justify-self: start
- padding: 0px 10px
- font-size: 12px
- text-transform: capitalize
label:
- font-size: 12px
tap_action:
action: toggle
EDIT: I also noticed that I cannot override text-align and set it to left justified. Iām forcing carriage returns in the label text field to output title and artist of a media player. Is there any way to override it or should I create a new layout in my .js file?
I set up a sub menu system similar to RomRiderās using input_booleans and conditional cards last week. The number of views in my ui-lovelace.yaml is getting out of hand and I wanted a way to consolidate menus with similar functions.
I still need to tweak the text on some buttons as well as add some missing entities for the relevant rooms but overall, I am happy with the reduction in distinct views for the mobile platform. This new method should bring my number of mobile phone views well below 10.
EDIT: Sharing my config for those of you that have asked/might be interested. In hindsight, my setup is much more complicated than I originally thought so this might get a bit cumbersome. Forgive me in advance if I utterly confuse anyone.
My setup consists of:
- Input Booleans - one for each room
- Groups - Used for determining which input booleans should be on and off
- Automations - Leverage the state of a Group in order to set the off state of a Group based on the on state of an input boolean
- Conditional cards which show and hide based on the on state of an input boolean.
Input Booleans (defined in customize.yaml)
input_boolean:
livingroom:
initial: on
diningroom:
initial: off
kitchen:
initial: off
Groups
This is the most complex part of the setup. Since only one card can be visible at a time, it stands to reason that when one card is on, the other two cards must be simultaneously turned off. Grouping together two input_booleans together simplifies the next step, Automations.
Example: If the Kitchen Card is on, the Dining Room and Living Room Cards are off.
input_kitchen_on:
name: Input Kitchen ON
view: no
entities:
- input_boolean.diningroom
- input_boolean.livingroom
input_diningroom_on:
name: Input Dining Room ON
view: no
entities:
- input_boolean.kitchen
input_livingroom_on:
name: Input Living Room ON
view: no
entities:
Automations (one per input boolean)
With the groups configured, now we create an automation that will call homeassistant.turn_off and apply it to a group based on which input boolean is turned on. Below is one example of the automation (created via the HA GUI). One automation is needed for every card being created.
Whenever an input boolean is turned on, these automations will turn off the other input booleans.
- id: '1556756275823'
alias: Bedroom Card - Guest ON
- entity_id: input_boolean.guestbedroom
platform: state
to: 'on'
condition: []
- data:
entity_id: group.input_guest_on
service: homeassistant.turn_off
Please note: The formatting of this particular Automation was created by the HA GUI. This may not translate to a working automation in your environment if you do a simple copy/paste with the requisite entity replacement.
Button Cards (need one for each input_boolean)
These are the buttons that actually turn an input_boolean on. Below is one example of a single Button Card. You will need to create a button card for each view you are trying to consolidate. (e.g. Living, Dining, Kitchen).
show_icon: false
color_type: card
entity: input_boolean.livingroom
state:
- value: 'on'
- value: 'off'
tap_action:
action: call-service
service: homeassistant.turn_on
service_data:
entity_id: input_boolean.livingroom
Conditional Cards
These cards are pretty straight forward. Simply configure the Conditional card to monitor the state of your input boolean, then define which card and entities should be shown when the conditions are true.
- type: conditional
conditions:
- entity: input_boolean.livingroom
state: "on"
card:
type: #Define your cards and entities here
Thanks getting the head around now
Because the grid has 4 lines and you only define 3 of them - grid-template-rows: 50px auto auto auto
And also because the card has a default padding of: 4% 0px (4% is based on the width)
Itās not text align, itās justify-self: start
Thereās no need to edit the JS, you can do all the things in the config.
Any way to add sensor value to switch?
Yes, using value_template
, please check the documentation.
hello there ! i am new on this cardā¦i wish to make one thingā¦below is my current card
1st - when an identify is not available how can i change its icon?
2nd - come of the lamps are xiaomi so they have colors, how can i change the icon color according to the selected color on the lamp?
thanks to all in advance
regards
