thanks ! unfortunelly i cannot understand the documentatio.
can you please help?
Like this:
- dbltap_action:
action: more-info
entity: binary_sensor.meteoalarm
show_label: true
show_state: true
show_entity_picture: true
state:
- color: green
value: 'off'
entity_picture: '/local/your_image.jpg'
- color: red
value: 'on'
entity_picture: '/local/your_other_image.jpg'
tap_action:
action: toggle
type: 'custom:button-card'
yes, and since @mclaudiopt wanted to
replace the icon:
with entity_picture:
and a correct path to that picture on your system, but the above post was edited, so mine can be retractedâŚ
thanks
like this?
cause it does not show the image_(
cards:
- name: INFORMAĂĂO
template: header_marcelo
- cards:
- entity: sensor.riscoincendio
name: RISCO DE INCĂNDIO
show_label: true
show_state: true
state:
- color: red
value: REDUZIDO
- dbltap_action:
action: more-info
show_label: true
show_state: true
state:
- color: green
value: 'off'
entity_picture: '/local/images/meo.jpg'
- COLOR: RED
VALUE: 'on'
entity_picture: '/local/images/meo1.jpg'
tap_action:
action: toggle
type: horizontal-stack
type: vertical-stack
my image is in www/images
You missed:
and your should not write things in capital letters, like: COLOR: RED
or VALUE: 'on'
, this whould be lowercase: color: red
, value: 'on'
must be staring blindly, but somehow the âoffâ color wonât show:
- type: horizontal-stack
cards:
- type: custom:button-card
template: button_picture
entity: automation.switch_bedside_table_off_when_no_motion
state:
- value: 'on'
entity_picture: '/local/hue_scenes/clear.png'
styles:
- color: '#F0C209'
- value: 'off'
entity_picture: '/local/hue_scenes/nightlight.png'
styles:
- color: '#555B65'
with this button_template:
button_picture:
show_state: false
show_label: false
show_name: false
color_type: card
tap_action:
action: toggle
haptic: light
hold_action:
action: more-info
haptic: success
styles:
card:
- border-radius: 12px
- width: 105px
- height: 105px
on
is as it should be:
off
stays white, no matter what I enter for color, be it hex or name:
should be:
spot the error please?
âupdateâ
think I found it:
cards:
state:
- value: 'on'
color: '#F0C209'
- value: 'off'
color: '#555B65'
works. Still confusing to me, maybe have to rereadâŚwhy wonât styles work here, or is it even incorrect? And why does it work for on and not for offâŚ
cards:
state:
- value: 'on'
color: '#F0C209'
- value: 'off'
color: '#555B65'
when color_type: card
, color: xxx
is a shortcut for:
styles:
card:
- background-color: xxx
On a side note, your where missing something between styles
and the actual style you want to put in place.
haha, thanks, yes, I tried background-color before, but it didnât change the white backgroundâŚ
how come it did work for the on state?
Because by default the button applies a color for the on
state, and the default on
color is var(--paper-item-icon-active-color)
mmm, wait a minute please. So youâre saying that with an incorrect styles (which I had) the default color is applied, even to the off state?
Then how come the background for the on state was colored according to my erroneous styles, and not made white?
I mean, I am fine with the end result now, but like to really understand to prevent stupid mistakes in the futureâŚ
It was not applying your color, it was applying var(--paper-item-icon-active-color)
, which for you is also probably yellow
Defaults for color_type: card
- on:
- off:
var(--paper-card-background-color)
that seems most unlikely, since it is no default color of anything, and i have set this hex value specifically in this configurationâŚ
where w/could var(--paper-item-icon-active-color)
bet set to make it default to my âyellowâ color #F0C209?
This comes from the theme of your homeassistant, and yellow (#fdd835
) is also the default for this value in home-assistant when no theme is applied.
And by checking the color of your screenshot, I can tell that itâs not your color which is applied but home-assistantâs default Yours is more orange-ish than yellow.
aha! so it wasnât applying âmyâ yellow #F0C209 but the HA default yellow #fdd835 . Lol, missed that! It is rather subtle, I must admitâŚ
thanks again! very informative.
Actually I was thinking, you can already style the lock icon⌠I just forgot I already did it, it was released in 1.8.0
See example here: Lovelace: Button card - #952 by RomRider
AMAZING ! it works ! thank you so much
hi again
i made it work for one of the sensors. for the other it seams impossivel !
cards:
- name: INFORMAĂĂO
- cards:
template: cartao
show_name: true
show_label: true
show_state: true
state:
- value: MODERADO
entity_picture: /local/images/meteo_no_alert.jpg
- VALUE: 'on'
entity_picture: /local/images/meteoalert.jpg
- entity: binary_sensor.meteoalarm
template: cartao
name: ALERTAS METEROLĂGICOS
show_name: true
show_label: true
show_state: true
state:
- color: green
value: 'off'
- COLOR: red
VALUE: 'on'
can someone please setup this sensor and help me finding why the retrieved values are not beeing considered?
this is the output of the sensor
wich is equal to what i have in the codeâŚ
Actually itâs not but itâs subtle⌠I checked your scraper from the code you sent on github.
The sensor value has actually a line-return at the end but itâs not visible⌠Thatâs why it doesnât match.
You should change your scraper to something like this:
- platform: scrape
resource: 'https://fogos.icnf.pt/rif/Stat_Global_Sensibilizacao_Riscolist2.asp?cmd=search&t=Stat_Global_Sensibilizacao_Risco&z_Distrito=%3D&x_Distrito=Leiria&x_Concelho=Caldas da Rainha'
select: "FONT"
index: 1
value_template: "{{ value | trim }}" # I added this.
A yes, So cool! I missed that completely, and seems exactly what I was looking for (except for the exception rule, but that maybe too much an edge case for you to implement)
having great time transitioning my Tiles:
to your Buttons,
left out some opacity settings, and still need to find a way to collect the individual buttons on a card, like my Tiles, but they come along very nicely.
They look very robust compared to the sometimes jittering Tiles, especially for the animated Gifs I use, very steady. Thanks a bunch for this car.
Entity_picture templates will be the definitive clincherâŚ
the new versions look better. More centered and the rounded corners make for better buttons.
You are right !!! now works !
thanks a lot
