Lovelace: Button card
I was wondering how you get these buttons so nicely centered on the display.
All my horizontal stacks start at the outer left edge of the screen, which on a mobile device is even uglier than on the desktop.
See my Tiles above on a card, below that the same in buttons, which are not on a card… can we somehow collect them as a group, give it a title etc. Or do we need to nest the buttons in yet another card?
desktop:
48
Mobile:
Use 2 blank-card in your horizontal-stack one at the beginning, one at the end, like in this post: Lovelace: Button card
Just tested this out and it did indeed update after a minute.
Just wanted to show everyone my setup so far and see what you think!
Yes exactly what @romrider says, they are just 2 blank button cards. One at the beginning of the horizontal-stack and one at the end. You can also use it for vertical stacks.
thx, done that. which makes it better placed indeed. Only wish we could set the gap between buttons… I know this isn’t Tiles, where that is a snap, but without any grid, and no auto sizing, this is really very difficult to setup for more than 1 display.
have another issue. Somehow the Buttons unsharpens (blurs might be too strong a word) my images. At first I thought is was the size of the images (my tiles were a bit smaller than the buttons). In the examples below, my Tiles are larger than the Buttons and still show much crispier.
The images themselves are much larger so they are not blown out of the possible size
Both photographic images as png files. Have a look ( and don’t mind the color difference which ca be caused by the opacity settings)
55
00
per set above the Tiles, below the Buttons
I don’t follow what you’re doing here.
If I add blank buttons they are the same size as the others in the horizontal stack which means that they all get resized. You seem to have narrow ones.
Unless of course you are hardcoding the widths? Which I guess means a bit of trial and error to get right and really only is useful on mobile?
This works if every other card on the line has a fixed width in px
I don’t do anything with images. I’m using the standard <img> html tag to load it.
good to know, will seek elsewhere then, the difference is rather noticeable.
Let me ask a different question please: I have a series of buttons using an operator template:
      - type: custom:button-card
        template: button_picture_script_small
        entity: script.lighting_aan_de_slag
        entity_picture: '/local/activities/aandeslag.png'
        state:
          - operator: template
            value: >
              return states['input_select.activity_lighting'].state === 'Aan de slag'
            color: '#F0C209'
            value: >
              return states['input_select.activity'].state !== 'Aan de slag'
            color: '#555B65'
            styles:
              entity_picture:
                - opacity: 0.6
which is my translation for the template I use elsewhere:
    templates:
      style: >
        if (entities['input_select.activity_lighting'].state === 'Aan de slag') return 'background-color: #F0C209';
        return 'background-color: #555B65;filter:grayscale(75%)';
could the buttons use the second ‘else’ in the config, without explicitly stating
            value: >
I mean the operator would only be needed in the === state, all else would be, well, else :wink: (might be a nice name for an operator…)
- operator: else
  color: '#555B65'
  styles:
    entity_picture:
      - opacity: 0.6
Ive tried to set the ‘else’ color as default for the button in the button-template, and let the operator template override that for that particular state, but that doesn’t work. The operator doesn’t override the global config so it seems.
operator: default, no value :wink:
you’ve thought about everything! nice, thanks.
so I use:
          - operator: default
            color: '#555B65'
or only
operator: default
, and set the default color in the button-template? Didn’t seem to work before using:
styles:
  card:
    background-color: '#555B65'
Set your styles in the state with operator: default, it’s better.
If I use storage mode for the lovelace (not the yaml mode), where have to be inserted the
template: !include button_card_templates.yaml?
You can’t use includes in storage mode
Hello
how can i give an exact size for all the card and exact size for each image?
on the example on the image on the right i cannot see the ‘name’ because it is behind the image
cards:
  - name: ILUMINAÇÃO DA SALA
    template: header_marcelo
    type: 'custom:button-card'
  - cards:
      - color: 'rgb(255, 228, 181)'
        color_type: card
        dbltap_action:
          action: more-info
        entity: light.luz_sala_de_estar
        icon: 'mdi:ceiling-light'
        name: SALA DE ESTAR
        show_entity_picture: true
        show_state: true
        state:
          - entity_picture: /local/images/SalaON.jpg
            value: 'on'
          - value: 'off'
        tap_action:
          action: toggle
        template: cartao
        color_type: card
        dbltap_action:
          action: more-info
        entity: light.luz_sala_de_jantar
        name: SALA DE JANTAR
        state:
          - entity_picture: /local/images/JantarON.jpg
            value: 'on'
          - entity_picture: /local/images/JantarOFF.jpg
            value: 'off'
        styles:
          entity_picture:
            - transform: rotate(180deg)
        tap_action:
          action: toggle
        template: cartao
      - color: auto
        color_type: card
        dbltap_action:
          action: more-info
        entity: light.yeelight_color1_04cf8c9557ff
        icon: 'mdi:floor-lamp'
        name: Candeeiro de pé
        show_state: true
        state:
          - entity_picture: /local/images/salapeon.jpg
            value: 'on'
          - entity_picture: /local/images/salapeoff.jpg
            value: 'off'
        styles:
          entity_picture:
            - transform: rotate(90deg)
        tap_action:
          action: toggle
        template: cartao
    type: horizontal-stack
  - cards:
        color_type: card
        dbltap_action:
          action: more-info
        entity: light.luz_hall
        icon: 'mdi:lightbulb'
        show_state: true
        state:
          - entity_picture: /local/images/HallOFF.jpg
            value: 'on'
          - entity_picture: /local/images/HallON.jpg
            value: 'off'
        tap_action:
          action: toggle
        template: cartao
      - color: auto
        color_type: card
        dbltap_action:
          action: more-info
        entity: light.luz_philips_xiaomi
        icon: 'mdi:lamp'
        tap_action:
          action: toggle
        template: cartao
      - color: auto
        color_type: card
        dbltap_action:
          action: more-info
          state: null
        entity: light.yeelight_color2_04cf8c842ee1
        icon: 'mdi:television-box'
        tap_action:
          action: toggle
        template: cartao
type: vertical-stack
Question number 2
is there a way to change color only on the marked area in red ? i dont want the all the card change color when on or off…only that area
thanks
I’m struggling with ripple coloring as there is a bug in the component… So for now I won’t release a version with ripple coloring.
I’m also working on adding aspect ratio for your buttons so you’ll not need to specify width and height anymore (example: for a square, aspect ratio would be 1/1) to have buttons the way you want and this will also adapt to whatever the screen size is. I’ll need to modify slightly some CSS, I hope it will not break things too much :blush: but hopefully you’re all using templates now so it will be fast to fix :stuck_out_tongue_winking_eye:
State merging when using template configurations is also incoming alongside with name and entity_picture javascript templating support.
You can use size: xx%, default being 40%
Use a combination of state and style in each state just for the name:
state:
- value: 'on'
  styles:
    name:
      - background-color: your_color
- value: 'off'
  styles:
    name:
      - background-color: other_color
I need some advice from the brain trust. I’m attempting to use button-card to replace custon:fan-control-entity-row and have run into a bit of a wall. Using all of button-card’s new features, I have replicated the look of fan-control-entity-row while adding some nice modifications (like spinning icons).
The challenge has been getting the fan speed buttons to function in the same fashion. With fan-control-entity-row, pressing any one of the speed buttons will do the following:
  • If the fan is off, pressing a speed button will simultaneously turn the fan on and set the fan speed.
  • If the fan is on, pressing a speed button will set the fan speed.
This is where I find myself, stuck at the limits of my YAML knowledge. How does one go about creating logic that not only checks for the current state of the fan but simultaneously calls two services (fan.turn_on and fan.speed) when necessary?
I considered using conditionals to monitor the on/off state of the fan but the concept of passing two separate service calls completely eludes me.
this might help:
        entity_picture: '/local/hue_scenes/concentrate.png'
        tap_action:
          action: call-service
          service: script.tiles_set_hue_scene
          service_data:
            option: 'Concentreren'
        state:
            value: >
              return states['input_select.hue_scenes'].state === 'Concentreren'
            color: '#a2eaf2'
          - operator: default
            color: grey
of course adapt the logic, but it shows how to call a script, and check for state, and act accordingly
:clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::clap::partying_face::partying_face::partying_face::partying_face::partying_face:
