Lovelace calendar card distorted
The Lovelace calendar card seems to be unpleasantly compressed in the latest update - as if it has been optimised for a mobile phone. On a tablet it used to occupy most of a landscape screen.
Also it no longer seems to be possible to edit the card via the UI with the new compressed header. The edit dots top right have been replaced by the refresh button.
I was going to try deleting the card and re-creating it, but of course you can’t without the edit menu.
The same problem for me.
After a bit more fiddling around…
The edit dashboard menu still appears if the calendar is one of a number of tabs in the header; not if it is the only one. In this case, it looks as if you have no refresh button. If you create a new calendar it is still compacted, although centred not shifted to the left as in my screenshot.
