Hi community,
I’m trying to configure a very simple “entities card” able to dynamically show the list of connected devices in my LAN.
I’m using the nmap device tracker.
When I exploit the developer tool for Jinja template elaboration, I’m able to obtain the list of entities id thanks to the following lines of code:
type: entities
title: MyConnectedDevices
entities: {{ states.device_tracker | selectattr('attributes.scanner', 'eq', 'NmapDeviceScanner') | map(attribute="entity_id") | list }}
this is the output:
type: entities
entities: ['device_tracker.XX_XX_XX_XX_XX_01', 'device_tracker.XX_XX_XX_XX_XX_02'', 'device_tracker.XX_XX_XX_XX_XX_03']
When I try this stuff into the Lovelace card configuration I receive this error: " missed comma between flow collection entries at line 3, column 96: … nner’, ‘eq’, ‘NmapDeviceScanner’) | map(attribute=“entity_id”) | … ^ "
Could you please tell me if it is right to insert Jinja templates into lovelace card configurations? If yes, where is the error?
Thank you very much for the support!
