I can’t delete or edit cards from the ui now. Dev info says I’m in storage mode, and this is happening on all of the tabs. Restart and reboot don’t fix it. Any hints on how to fix it?
It happened to me today… same thing, after update to 2021.7.1 this morning. No edit links in any card, in any of my lovelace boards, exactly like picture in first post. I don’t have YAML mode.
Same on chrome, edge, android. Log off/on doesn’t help. I deleted all browser history, coockies, nothing. Then i changed theme in personal settings from “backend selected” to some other i have instsalled and even more weird things happened: half of text was missing in my settings page. Then i pressed shift+F5, text came back and edit links also, but only in chrome and edge but no in android phone. After some additional “tinkering” now all is fine on phone also. Until…when…?
Any clues what could be wrong?
I have exactly the same problem with 2021.7.1. No edit bars. If I revert to 2021.6.6, then they return. Tried clearing the browser cache, logging out and in, changing the theme. None of these worked for me.
This sometimes happens to me (on Container rather than HA OS).
When it happens I find that navigating to another view in the dashboard (while still in edit mode) and then back to the view I want to edit makes the edit buttons appear.
Thanks. Yes, tried that too! You’re right I’m running as a container. The only workable solution was to roll back to 2021.6.6. Edit buttons immediately reappeared.
I found “kind off” solution: when i open browser usually edit bars are missing, then i go into my first (default) view, click “edit” there (until now edit bars always show there), then i go back to previous lovelace, click “edit” again and bars now appear.
BTW… i’m NOT in containers, but inside Synology VM.
I just wonder… did anyone reported this bug yet? There were two updates already and this bug still exists and it’s pretty annoying (i don’t know where to report…)
I just played a bit with this still existing problem. I found out that “edit” cards are not there if first lovelace page LAYOUT VIEW SETTING i try to edit is set to “anything but” default. I have one of my boards set to “vertical layout” (for phone) and when i open broswer, go to that page and hit “edit” then “EDIT” bars are not there. If i set view to “default” all is ok.
Just for possible further thinking (and maybe looking for a bug…)
(i’ll post this on gitbub link above, too).
All of the sudden happened to me as well, on 2021.8.8 and persisted after updating to 2021.9.1. If I switch back and forth between tabs, they reappear but when hen it seems it won’t save when pressing save. The ‘saving animation’ keeps playing and it won’t return to the dashboard.
