I use esphome, ads1115 and this sensor (30 psi):
https://fr.aliexpress.com/item/4001254325128.html
Green : correct pressure (between 0.6 and 1.1 bar).
Yellow : high pressure (between 1.1 bar and 1.4 bar).
Red : very high pressure (> 1.4 bar).
wilsto
(Wilsto)
May 26, 2023, 9:33am
22
Thanks to your feedback, please find here a major update of the “Pool Monitoring Card” : https://github.com/wilsto/pool-monitor-card
New functionnalities
Add 8 new pre-defined sensors : we already have temperature, pH, ORP levels and TDS and now if you need them : salinity, CYA, calcium, phosphate, alkalinity, filter pressure , free chlorine, total chlorine
Add a second temperature sensor
Improve UX settings with show_names & show_labels
Add FR language
Add Info in Browser Log
Update Hardware list
Update Screenshots
Improve Readme
** Breaking changes : names is enabled by default
DAVIZINHO
(DAVIZINHO)
May 26, 2023, 9:49am
23
hello, do you want to add spanish language?
i can translate for you if you want
wilsto
(Wilsto)
24
@DAVIZINHO sure, i will add it
wilsto
(Wilsto)
May 26, 2023, 9:57am
25
@DAVIZINHO is this ok for you ? or would like to improve ?
"Demasiado bajo",
"Aceptable bajo",
"Perfecto",
"Aceptable alto",
"Demasiado alto"
Very cool, that is actually what I need
Really great work and appreciate the quick turnaround on feedback! I’ve started using the new card and love it. A couple other questions/feedback items now that I’ve been using it.
Is there a way to reorder the sensors? I assumed it was based on the order in which they were laid out in the config but it appears to be a fixed order.
Some sensors may need a minimum limit value. For example, Phosphates and TDS do not have a negative lower threshold since you just want to stay under a certain number as a high limit. I’ve configured TDS to be 0-2500 as the ideal range using setpoint and step but then it displays negative values for values under 0, which isn’t possible.
wilsto
(Wilsto)
May 30, 2023, 5:21pm
28
Hi @kernel610 appreciate your feedback, I log your feature request and will think how to implement them :
opened 05:13PM - 30 May 23 UTC
enhancement
Is there a way to reorder the sensors? I assumed it was based on the order in wh… ich they were laid out in the config but it appears to be a fixed order.
opened 05:14PM - 30 May 23 UTC
enhancement
Some sensors may need a minimum limit value. For example, Phosphates and TDS do … not have a negative lower threshold since you just want to stay under a certain number as a high limit. I’ve configured TDS to be 0-2500 as the ideal range using setpoint and step but then it displays negative values for values under 0, which isn’t possible.
DAVIZINHO
(DAVIZINHO)
July 21, 2023, 3:14pm
29
Hello again!
This week I installed a salinity system in my pool and buy other blueriiot sensor.
This new bluerriiot sensor can measurement the salinity of the pool.
But the sensors provide the value in g/L like this picture
Its posible to add the unit g/L to the salinity graphic to show like this picture?
Thanks!!
salzrat
(Michael)
August 1, 2023, 3:14pm
30
I have a TDS value of 244ppm in my pool, which is supposed to be drinking quality. The card says this is much too low, why?
vobele
August 6, 2023, 4:53pm
31
notovich
(Влад Нотович)
August 7, 2023, 8:27pm
32
just a little alteration and it is working with my Seneye sensors for reef aquarium:
GregTR
(Greg Takacs)
August 14, 2023, 2:53pm
33
I have added the capability to change the colors and add min/max historic tickers:
wilsto:master
← gregtakacs:master
opened 02:12AM - 13 Aug 23 UTC
![Screenshot from 2023-08-12 21-08-38](https://github.com/wilsto/pool-monitor-ca… rd/assets/20398441/be6a840f-0d67-4b97-9807-307edcde4e21)
If the yaml template defines additional min/max sensors such as
ph: sensor.iopool_ph
ph_min: sensor.daily_ph_min
ph_max: sensor.daily_ph_max
They will display as tick marks on the bar chart.
For the sensors I use the statistics platform:
- platform: statistics
name: "Daily pH Min"
unique_id: <UUID>
entity_id: sensor.iopool_ph
state_characteristic: value_min
max_age:
hours: 24
name: "Daily pH Max"
unique_id: <UUID>
state_characteristic: value_max
max_age:
hours: 24
Also templatized the color scheme of the bars:
normal_color: var(--dark-primary-color)
low_color: var(--primary-color)
warn_color: var(--light-primary-color)
or:
normal_color: green
low_color: yellow
warn_color: "#ff0000"
`TODO:` Templatize the color tickmarks, right now they're all red with a bit of transparency on the min/max.
Pull request is in.
ManuelV
(Manuel Vasco)
December 28, 2023, 9:28pm
34
What a wonderful job! Judy a little question, about salinity: I have read that , in terms of salinity, 1g/L = 1 ppm. Besides, in the card it states as normal quantity 3000 ppm or 4,5 g/L.
Am I missing something?
TimU
February 23, 2024, 4:56am
35
@wilsto - Did @GregTR ’s PR ever get accepted please? Seems like a good addition.
Also, Could you help me add this to my lovelace dashboard please?
I tried adding the card via the Dashboard YAML as instructed, but I get an error that the “Custom element doesn’t exist: pool-monitor-card”
Edit: Nevermind, it started working by itself a few minutes after I saved the card.
