Is it only me thinking this sort of thing should be done in the backend with a template sensor?
Just trying to update this from Installed: 0.0.7 to 0.0.9 and get error
An error ocoured while processing
No module named âqueuemanâ
Tried to step upgrade to 0.0.8 and get the same error.
Do I need to log an issue in Github?
I donât use queueman in this card and that error looks like a Python error so, if it happens while trying to update, it looks more like an error in HACS (HACS does use the queueman package).
Thanks for the reply and for the project Steven. I will do some trouble shooting there.
Thank you for this awesome card. I was racking my brain for 3 days trying to get states into name:
fields. I tried to use config-tempate-card
but couldnât get the syntax right, but yours just worked. Thank you!
Hi all!
Iâm trying to template the bar-card, dynamically changing how the graph is displayed⌠if possibleâŚ
Based on reading I come up with following code for changing the target (2 charts for direct comparison, second one in the stack is actually templated):
type: 'custom:vertical-stack-in-card'
horizontal: true
cards:
- type: 'custom:card-templater'
card:
type: 'custom:bar-card'
entity: sensor.temp_max_1
direction: up
width: 40%
height: 150
min: 0
max: 30
target: 10
positions:
value: outside
icon: 'off'
card:
direction: up
width: 40%
height: 150
min: 0
max: 30
target_template: '{{ states(''input_number.watering_cycle'')|float}}'
positions:
value: outside
icon: 'off'
Which gives following result:
As you can see it does not work⌠Graph on the right that should have target lowered to 4 is not showing at all, instead I get some strange highlight line at the top of the graph. It might mean that it is somehow working (something changing in bart-card confirguration), but the way I desire. Any idea?
I think it may be due to the templating engine always returning a string. To confirm this, could you try changing the non-templated one to have target: '10'
instead of target: 10
and see if it breaks it.
If that is the issue, I will need to work out how to solve it. I already implemented a fix for Boolean values (it casts âtrueâ or âfalseâ to a Boolean), but it wonât be as simple for integers or floats since it may depend on what the underlying card is expecting).
Edit: I noticed that you are missing the entities option for the templater, it should be something like this:
card:
direction: up
width: 40%
height: 150
min: 0
max: 30
positions:
value: outside
icon: 'off'
entities:
- input_number.watering_cycle
That is currently needed so that it knows what entities to monitor for changes when processing the template.
Hi many thanks to Steven for making this card! very nice to see how easy you can apply tamplates. But I ran into a problem so hope you can help. I donât know if itâs a bug or my setup today the question here:
I use the template card together with the pie chart, now it seems that the template card is getting in the way of real time updating of the pie chart. As soon as I apply a template the Pie chart only refreshes when refreshing the whole page. Is this something I can set?
card:
type: 'custom:pie-chart-card'
entities:
- entity: counter.negative_hm2
- entity: counter.neutral_2_hm2
- entity: counter.neutral_1_hm2
- entity: counter.positive_hm2
title_template: '{{ states(''input_text.hm1'') }}'
total_amount: sensor.hm2
entity: input_text.hm1
I have run all the updates, use hassIO via virtualbox and edit and open in chrome.
hope you can help!
cheers Luuk
Try it like this and see if it helps:
card:
entities:
entities:
- input_text.hm1
hey! tnx for the fast reply, its to bad it dos not work i tryd to reboot and then test is but that did not work ether, is thare any place whare the card runst that is not real time?
cheers Luuk
Am using card-templater for the past 4+ months and it solved my needs. Thank you for that. But the page where the card has been using is getting crashed frequently. The only way is to refresh for web and restart the app in case of mobile. Could you please let me know whatâs wrong?.
WebSocket is already in CLOSING or CLOSED state.
sendMessage @ bootstrap:2 (anonymous) @ bootstrap:2 subscribeMessage @ bootstrap:2 (anonymous) @ lovelace-card-templater.js:10 (anonymous) @ lovelace-card-templater.js:10 parseTemplate @ lovelace-card-templater.js:10 applyTemplate @ lovelace-card-templater.js:10 getCardConfig @ lovelace-card-templater.js:10 getCardConfig @ lovelace-card-templater.js:10 getCardConfig @ lovelace-card-templater.js:10 set hass @ lovelace-card-templater.js:10 (anonymous) @ hui-view.ts:51 value @ hui-view.ts:51 performUpdate @ bootstrap:2 _enqueueUpdate @ bootstrap:2
My config:
card:
entities:
- icon: 'mdi:router-wireless-settings'
name: DLink DHP1565 - Access Point
type: weblink
url_template: 'http://{{ states.device_tracker.dlinkap1.attributes.ip }}/'
name: DLink DIR655 - Access Point
type: weblink
url_template: 'http://{{ states.device_tracker.dlinkap2.attributes.ip }}/'
name: TP-Link TL-WA850RE - Range Extender
type: weblink
url_template: 'http://{{ states.device_tracker.tplinkre1.attributes.ip }}/'
name: Comfast CF-WR150N - Access Point
type: weblink
url_template: 'http://{{ states.device_tracker.comfastap1.attributes.ip }}/'
name: DLink DIR816L - Repeater
type: weblink
url_template: 'http://{{ states.device_tracker.dlinkre1.attributes.ip }}/'
show_header_toggle: false
title: Routers/Extenders
type: entities
entities:
- device_tracker.dlinkap1
- device_tracker.dlinkap2
- device_tracker.tplinkre1
- device_tracker.comfastap1
- device_tracker.dlinkre1
The only thing I can think of is if you have briefly lost access to the Home Assistant server (do you get the âConnection lost. ReconnectionâŚâ popup?) which may interrupt the WebSocket connection it needs.
Iâll need to see if I can reproduce the issue first, and then I may be able to implement a fix to handle it.
Yes, you are correct. I get a popup on the left bottom which says Connection lostâŚ
Here is an annoying thing that happens occasionally on refreshing the frontend or switching between tabs. Another refresh will always fix it it tho. It just started happening after I updated to v110.
I get it on one other card (state-switch) with a very similar error and a refresh clears that one up too.
I know that state-switch isnât one of yours and I plan on posting this to that thread too but I thought it might give you more insight as to what could be causing it.
Hi @chipware,
this looks awesome, i wanted to check with you on how you doing the calculation for the cost . Are you setting up some custom entities based on reading you are getting. If so possible to share your example
You have to turn watts into KWH, then KWH into Cost by multiplying by your utilityâs cost per KWH. So:
In sensors.yaml:
- platform: integration
source: sensor.centralite_3210_l_d07f4f0b_electrical_measurement
name: "Server Plug Kwh"
unit_prefix: k
method: left
round: 2
In utility_meter.yaml:
server_plug_kwh_daily:
name: "Server Plug Kwh Daily"
source: sensor.server_plug_kwh
offset: 00:00:01
cycle: daily
server_plug_kwh_monthly:
name: "Server Plug Kwh Monthly"
cycle: monthly
offset:
days: 1
That will accumulate KWH daily and monthly, resetting at midnight and the first of the month.
Then back in sensors.yaml:
sensors:
server_plug_cost_daily:
friendly_name: Server Plug Cost Daily
unit_of_measurement: '$'
value_template: "{{ (0.10853 * states('sensor.server_plug_kwh_daily') | float) | round(2) }}"
server_plug_cost_monthly:
friendly_name: Server Plug Cost Monthly
value_template: "{{ (0.10853 * states('sensor.server_plug_kwh_monthly') | float) | round(2) }}"
Hi @chipware,
Appreciate your reply and the same code you are using
i currently am using some plugs which is configured via ESPhome. it gives me both Wattage value ( in Watts) and also a daily_energy (in Kwh) , so the plug keeps a cumulative value of the Kwh, although i found if i were to remove the plug this value is set to â0â.
i am guessing the best approach would be to take the ârawâ watt value and and create a new template sensor to give me the watt ==> Kwh followed by applying the cost factor.
in your example above , i was wondering with the âsensor.centralite_3210_l_d07f4f0b_electrical_measurementâ , do you get a Kwh directly from the sensor so are you also going through a conversion within Home assistant?
He s using the integration sensor to obtain energy from power:
unit_prefix: k
method: left
round: 2
Please note the choice of integration method is critical for getting sensible values from this sensor. See which method to select here:
New in home assistant. Trying to do garbage collection (https://github.com/bruxy70/Garbage-Collection) and can not get the the days left to display. Wonder if anyone would know what Iâm doing wrong. If I go to developer tools-templates I can see the correct data but they will now show on the png.
