Would you be able to post the config of the card as text (formatted as a code block) rather than an image? I think you need populate the entities collection for the outer card-templater card, but it’s hard to tell from an image.
cards:
- card:
entities:
- sensor.red_bin
entity: sensor.red_bin
name_template: '{{ states.sensor.red_bin.attributes.days }} days'
show_name: true
show_state: false
state_image:
'0': /local/garbage_bins/red1.png
'1': /local/garbage_bins/red2.png
'2': /local/garbage_bins/red3.png
type: picture-entity
type: 'custom:card-templater'
- card:
entities:
- sensor.green_bin
entity: sensor.green_bin
name_template: '{{ states.sensor.green_bin.attributes.days }} days'
show_name: true
show_state: false
state_image:
'0': /local/garbage_bins/green1.png
'1': /local/garbage_bins/green2.png
'2': /local/garbage_bins/green3.png
- card:
entities:
- sensor.yellow_bin
entity: sensor.yellow_bin
name_template: '{{ states.sensor.yellow_bin.attributes.days }} days'
show_name: true
show_state: false
state_image:
'0': /local/garbage_bins/yellow1.png
'1': /local/garbage_bins/yellow2.png
'2': /local/garbage_bins/yellow3.png
- card:
entities:
- sensor.kerbside
entity: sensor.kerbside
name_template: '{{ states.sensor.kerbside.attributes.days }} days'
show_name: true
show_state: false
state_image:
'0': /local/garbage_bins/kerb11.png
'1': /local/garbage_bins/kerb21.png
'2': /local/garbage_bins/kerb31.png
type: horizontal-stack
You appear to have the entities option nested under the picture-entity card, but this belongs under card-templater like this:
cards:
- card:
show_name: true
show_state: false
state_image:
entities:
- sensor.red_bin
- card:
show_name: true
show_state: false
state_image:
entities:
- sensor.green_bin
- card:
show_name: true
show_state: false
state_image:
entities:
- sensor.yellow_bin
- card:
show_name: true
show_state: false
state_image:
entities:
- sensor.kerbside
OMG, thank you, that was it. And I’m trying to fix this for last 4 days Thank you very much
trying to achieve something really simple in theory, but I keep getting “Error!”:
card:
entities:
- entity: switch.my_hifi
name_template: {{ sensor.hifi_title_status }}
type: entities
entities:
- sensor.hifi_title_status
this is pseudocode to signify what I want to achieve (albeit I tried this precise code too, I tried many different combinations using states. and many more, but can’t figure what’s wrong
You either need to surround your template with quotes like:
name_template: '{{ sensor.hifi_title_status }}'
or use this format:
name_template: >-
Thank you… that was embarassingly simple!
I am not sure why I cannot add something like sensor.hifi_title_status.split(‘,’)[0] tho … it works in the templates tester
it does working with this code tho
'{% set now_playing = states.sensor.hifi_title_status.state_with_unit.split(",")[0] %}
{{ now_playing }}'
that’s good I guess
Any idea why mini-media-player refreshes much slower when passed through card-templater?
I have 2 cards right now, one with mini-media-player only, and one with mini-media-player inside card-templater.
I can take an action on either card (change source, volume,etc) and it will always show the updated value on the mini-media-player only one within a very few seconds, while the one inside card-templater takes several, like 30 seconds or so.
@Steven_Rollason Thanks for writing and supporting this - great work!
Is there any way to use wildcards in templates? I have a lot of NMap-Tracker entities that show up as device trackers, but I just want to show if they are connected to the network - Home/Away isn’t really appropriate.
Here’s what I have so far - I really want to avoid having to cut and paste the template for 50+ devices:
- type: 'custom:card-templater'
card:
entities:
- entity: device_tracker.a8_a1_59_**_**_**
- entity: device_tracker.b8_27_eb_**_**_**
- entity: device_tracker.00_0f_60_**_**_**
- entity: device_tracker.b8_e8_56_**_**_**
- entity: device_tracker.1c_65_9d_**_**_**
title: Computers
type: entities
entities:
state_template: >
{{ "On" if states.device_tracker.a8_a1_59_**_**_**.state == "home"
else "Off" }}
Something like - entity: device_tracker.*
or - entity.device_tracker.all
There’s nothing built-in for this, but you could use this card together with the auto-entities card to do it.
The best way to use it would be to add all those device_trackers to a group called group.nmap_trackers and then the configuration would look like this:
type: 'custom:auto-entities'
card:
card:
type: entities
filter:
include:
- group: group.nmap_trackers
options:
state_template: |
{{ "On" if states.this.entity_id.state == "home" else "Off" }}
This works because of two things:
- If you don’t define the entities option on the card you are templating with card-templater, then card-templater will pass its entities option (which, in turn, it is getting from auto-entities) on to it.
- auto-entities will automatically replace the text this.entity_id with the entity id of each entity, so states.this.entity_id.state becomes states.device_tracker.whatever.state if the matching entity is device_tracker.whatever for example.
Thank you for that! It almost works…
I think I saw somewhere that entity names that start with a number are a problem?
Try this instead:
state_template: |
{{ "On" if states("this.entity_id") == "home" else "Off" }}
That should work better with entity ids starting with numbers.
Excellent! Thank you. I was trying this:
{{ "On" if states[states.this.entity_id].state == "home" else "Off" }}
but I wasn’t getting very far. Is there a way to cast variables as different types?
What are you trying to do? You can cast to int, float, or string by doing things like:
{{ states("sensor.whatever") | int }}
{{ states.sensor.whatever.state | int }}
{{ states("sensor.whatever") | float }}
{{ states.sensor.whatever.state | float }}
{{ states("sensor.whatever") | string }}
{{ states.sensor.whatever.state | string }}
However, a template always actually returns a string (this is a limitation of templates, not specific to this card) so you can’t have a template return anything else other than a string. Although, in this card, I implemented two special cases which are exceptions to this rule:
- Any template which returns the string “true” or “false” will be treated as a boolean, this allows you to template boolean options of cards
- If you template the entities or state_filter option of a card (e.g. entities_template or state_filter_template) the return value will be parsed as YAML/JSON
I was trying to cast states.this.entity_id | string
but I think I see it now… I was using states[...]
instead of states(...)
to get the entity - old coding habits die hard!
Either way, your solution worked great - thanks again
Last question, I promise…
I got the state text updated and I added the secondary row info for the IP address. Now I am trying to change the color of the icon using Lovelace-Card-Mod, but it looks like the condition isn’t being parsed - it’s not passing it through to the client. I’ve tried several different ways of doing this:
I think there are a couple of issues there:
- It should be just
is_state("this.entity_id", "home")
and notis_state(states("this.entity_id"), 'home')
- Putting the style at that level is setting it for the whole card, so it won’t have access to the entity id
If you are still using auto-entities there, you would need the style to be nested under the options section so it will apply to every entity something like this:
options:
state_template: |
{{ "Online" if is_state("this.entity_id","home") else "Offline" }}
style: |
:host {
--paper-item-icon-color:
{%- if is_state("this.entity_id","home") -%}
green
{%- endif -%};
Awesome. I was getting there slowly, but I’m completely new to Jinja templates. I had figured out that the style was at the wrong level but I was trying to template the whole style option instead of just the color value.
Final result:
Hi everyone,
I’m trying to develop a map with self-completion.
Everything seems to work correctly except for the “icon_template” directive.
I have tried several formulations but none of them work.
Could you check my code?
Thank you in advance.
card:
card:
type: entities
filter:
include:
- entity_id: sensor.ds*_access_control
options:
icon_template: |
{% if states.this.entity_id.state == '22' %}
mdi:door-open
{% elif states.this.entity_id.state == '23' %}
mdi:door-closed
{% else %}
mdi:help-circle-outline
{% endif %}
state_template: |
Open
Close
{% else %}
Check
{% endif %}
style: |
:host {
{% if is_state("this.entity_id", "22") %}
orange
{% elif is_state("this.entity_id", "23") %}
white
{% else %}
red
{% endif %}
sort:
method: name
The result
The way you’re calling it using auto-entities, you are templating the entities rather than the card. That means that to template attributes like icon and name they need to appear under attributes like this:
card:
card:
type: entities
filter:
include:
options:
attributes:
icon_template: |
mdi:door-open
mdi:door-closed
{% else %}
{% endif %}
state_template: |
Open
Close
{% else %}
Check
{% endif %}
style: |
:host {
orange
white
{% else %}
red
{% endif %}
sort:
method: name
