Lovelace card with big slider for blinds
Hello all,
I’m using the default card for a blinds entity:
blinds_cardsm
When I click (touch, whatever) this card it will open a bigger one with a slider:
This is the YAML code:
    sections:
      - type: grid
        cards:
          - type: tile
            entity: cover.moes_blind_bb
            features_position: bottom
            vertical: false
            grid_options:
              columns: 12
              rows: 1
I want to have the bigger card, with the slider in the dashboard, I don’t want to click the small one first.
Is it possible to do this?
Thank you.
I think you can put in a card type such as button instead of a tile type card?
(with that said I am not sure as I do not have blinds… but tile cards do not have such features as far as i know)
Actually I’ve tried this, however it’s just showing a bigger icon:
ahh bummer, probably better someone with experience can help before I send you down some possible rabbit holes.
with that said, I found this with a quick google that maybe can work (?) but it is not the design you are after
this
and this as an entities slider
Use this to display any more-info card as a dashboard card:
Thank you, the information you’ve sent is useful, maybe I can use it for other entities.
Thank you! I wonder why this is not the default card setting…
If you have lots of lights to control it would be impossible to fit all the cards on a page.
