Lovelace Card YAML Question
I have 2 cards that I would like to combine into one. If I combine the YAML into one card it makes the icons very small so I guess I need a vertical stack or Vertical Stack In Card? Here is the first one:
cards:
  - icon: 'mdi:arrow-up-bold'
    tap_action:
      action: call-service
      service: remote.send_command
      service_data:
        command: DirectionUp
        device: '41560655'
        entity_id: remote.living_room
    type: 'custom:button-card'
  - icon: 'mdi:arrow-down-bold'
    tap_action:
      service_data:
        command: DirectionDown
        device: '41560655'
  - icon: 'mdi:arrow-left-bold'
    tap_action:
      service_data:
        command: DirectionLeft
        device: '41560655'
  - icon: 'mdi:arrow-right-bold'
    tap_action:
      service_data:
        command: DirectionRight
        device: '41560655'
  - icon: 'mdi:alpha-e-circle'
    tap_action:
      service_data:
        command: Ok
        device: '41560655'
  - icon: 'mdi:home'
    tap_action:
      service_data:
        command: Home
        device: '41560655'
type: horizontal-stack
Here is the second one:
cards:
  - icon: 'mdi:volume-plus'
    tap_action:
      service_data:
        command: VolumeUp
        device: '61379924'
  - icon: 'mdi:volume-minus'
    tap_action:
      service_data:
        command: VolumeDown
        device: '61379924'
  - icon: 'mdi:volume-off'
    tap_action:
      service_data:
        command: Mute
        device: '61379924'
  - icon: 'mdi:power-plug-off'
    tap_action:
      service: remote.turn_off
      service_data:
I am unsure what you want. Both ā€˜cardsā€™ have multiple cards (every dash is one).
So I guess what Iā€™m wanting then is a row of 6 cards and then below that a row of 4 cards. Currently these are 2 separate ā€œcardsā€.
I think what you mean by card is actually a view (tab).
Cards on views are dynamically placed and sized. To combine them in rows you would require vertical and horizontal stacks.
I donā€™t have much experience with it but there is a custom card that might be of help
Vertical stack card. Take a look at my config, use them all over the place for the remote page
Vertical stack card with horizontal stack within
Can you give me an example of that? From looking at other pplā€™s configs I started with my first button:
cards:
  type: vertical-stack
  cards:
    cards:
        tap_action:
          service_data:
            device: '41560655'
but the red box says ā€œNo card type foundā€ Seems to me that the vertical stack should come after the first 6 butttons, telling it to start a new row.
cards:
  - cards:
      - entity: light.garage
        hold_action:
          action: more-info
        tap_action:
          action: toggle
        type: entity-button
      - entity: light.hallway
        tap_action:
          action: toggle
        type: entity-button
  - cards:
      - entity: light.trash
        tap_action:
          action: toggle
        type: entity-button
      - entity: light.back_porch
        tap_action:
          action: toggle
        type: entity-button
  - cards:
      - entity: light.front_porch
        tap_action:
          action: toggle
        type: entity-button
      - entity: light.driveway
        tap_action:
          action: toggle
        type: entity-button
Got it. Thanks.
One other question. Iā€™d like all the buttons to be in one ā€œcardā€ in the UI. See how the lower buttons appear to be separate from the upper one? Do you know how to do that?
TV Lovelace
cards:
  - cards:
      - entities:
          - entity: media_player.sony_bravia_tv
            show_state: true
          - input_select.living_room
          - switch.apple_tv_power
          - switch.fire_tv_power
        show_icon: true
        show_name: true
        type: entities
  - cards:
        tap_action:
          service_data:
            device: '41560655'
        tap_action:
          service_data:
            device: '41560655'
        tap_action:
          service_data:
            device: '41560655'
        tap_action:
          service_data:
            device: '41560655'
        tap_action:
          service_data:
            command: Ok
            device: '41560655'
      - icon: 'mdi:home'
        tap_action:
          service_data:
            command: Home
            device: '41560655'
  - cards:
        tap_action:
          service_data:
            command: VolumeUp
            device: '61379924'
        tap_action:
          service_data:
            command: VolumeDown
            device: '61379924'
        tap_action:
          service_data:
            command: Mute
            device: '61379924'
        tap_action:
          service_data: null
For that, you would want to install the custom card ā€˜vertical-stack-in-cardā€™
You got a lot of unnecessary stuff in that. Anyways, doing what you want gets into the ā€˜advancedā€™ configuration category. You need to use the ā€˜under the hood namesā€™ while placing all cards into the entities card.
cards:
- entities:
      show_state: true
    - cards:
          tap_action:
            service_data:
              device: '41560655'
          tap_action:
            service_data:
              device: '41560655'
          tap_action:
            service_data:
              device: '41560655'
          tap_action:
            service_data:
              device: '41560655'
          tap_action:
            service_data:
              command: Ok
              device: '41560655'
        - icon: 'mdi:home'
          tap_action:
            service_data:
              command: Home
              device: '41560655'
      type: custom:hui-horizontal-stack-card
    - cards:
          tap_action:
            service_data:
              command: VolumeUp
              device: '61379924'
          tap_action:
            service_data:
              command: VolumeDown
              device: '61379924'
          tap_action:
            service_data:
              command: Mute
              device: '61379924'
          tap_action:
            service_data: null
  show_icon: true
  show_name: true
  type: entities
Is this available in HACS? Iā€™m not finding it.
Itā€™s not a custom card, itā€™s the under the hood name for the horizontal card. You donā€™t need anything custom.
Ok. Pasting in your code gives me ā€œno card type foundā€ so I thought maybe I needed something else.
let me verify that the name is correct
EDIT: The name is correct, it should work. You may need to switch to yaml mode.
By yaml mode do you mean pasting it into the raw config instead of a manual card? I noticed it put single quotes around custom:hui-horizontal-stack-card. Not sure if that makes a difference.
cards:
  - entities:
        show_state: true
      - cards:
            tap_action:
              service_data:
                device: '41560655'
            tap_action:
              service_data:
                device: '41560655'
            tap_action:
              service_data:
                device: '41560655'
            tap_action:
              service_data:
                device: '41560655'
            tap_action:
              service_data:
                command: Ok
                device: '41560655'
          - icon: 'mdi:home'
            tap_action:
              service_data:
                command: Home
                device: '41560655'
        type: 'custom:hui-horizontal-stack-card'
      - cards:
            tap_action:
              service_data:
                command: VolumeUp
                device: '61379924'
            tap_action:
              service_data:
                command: VolumeDown
                device: '61379924'
            tap_action:
              service_data:
                command: Mute
                device: '61379924'
            tap_action:
              service_data: null
    show_icon: true
    show_name: true
    type: entities
no, I mean full yaml mode where you donā€™t use the UI at all. Only configuration is done through ui-lovelace.yaml
yaml mode and storage mode should be the same when it comes to the raw editor. There should be no need to switch to yaml
Yeah, iā€™m not sure. Never used the UI. I would expect it to work but you never know. Especially when people mistake the UI warnings for errors.
