Lovelace Cards for Sonoff POW
Hi - How can I see my power usage in lovelace? I can see it when logging directly into the web interface of tasmota - but I would prefer seeing it in lovelace?
Do anyone also use Hasskit app? Can I see power usage in that app as well?
Like this ?
Yes - man you are fast :slight_smile: Thanks for always replying to my questions!
Is there a card that shows the power history as well?
You can use the history graph card.
can you please assist me to get these cards into lovelace?
First you click on the three dots in the upper right corner, you choose configure ui
For the badge’s , you click on the pencil
Choose badges, and select the entities you want
For the history graph card, you click on the orange + button in the lower right corner
Next select history graph card
and again select the entities you want
Thanks so much for the detailed response.
I dont have any sensors to select - just switches. I added normal switch cards when I set them up originally - must I maybe change something on the yaml file first?
Did you flash your sonoff pow with tasmota ?
Yes you did, read it in your first post :slight_smile:
In the tasmota console, enter
setoption19 1
This will create the sensors.
Thanks so much - Appreciate your help its working now
