This is my collapsing PS4 Controller Lovelace setup. The controller buttons only show when the PS4 is on.
You’ll need to install the Mini Media Player and Button Card plugins from HACS and have the PS4 integration configured.
Lovelace UI Card Code (add as Manual card or Vertical Stack)
type: vertical-stack
cards:
- artwork: cover
entity: media_player.playstation_4
group: false
hide:
controls: true
power_state: true
source: true
volume: true
info: short
source: icon
type: 'custom:mini-media-player'
- card:
cards:
- cards:
- aspect_ratio: 3/1
hold_action:
action: more-info
icon: 'custom:ps4-share'
show_icon: true
show_name: false
tap_action:
action: call-service
service: ps4.send_command
service_data:
command: share
entity_id: media_player.playstation_4
type: 'custom:button-card'
- aspect_ratio: 3/1
hold_action:
action: more-info
icon: 'custom:ps4-up'
show_icon: true
show_name: false
style:
height: 40px
tap_action:
service_data:
command: up
- aspect_ratio: 3/1
hold_action:
action: more-info
icon: 'custom:ps4-options'
show_icon: true
show_name: false
tap_action:
service_data:
command: option
type: horizontal-stack
- cards:
- aspect_ratio: 3/1
hold_action:
action: more-info
icon: 'custom:ps4-left'
show_icon: true
show_name: false
tap_action:
service_data:
command: left
- aspect_ratio: 3/1
hold_action:
action: more-info
icon: 'custom:ps4-x'
show_icon: true
show_name: false
tap_action:
service_data:
command: enter
- aspect_ratio: 3/1
hold_action:
action: more-info
icon: 'custom:ps4-right'
show_icon: true
show_name: false
tap_action:
service_data:
command: right
- cards:
- aspect_ratio: 3/1
hold_action:
action: more-info
show_icon: true
show_name: false
tap_action:
service_data:
command: ps
- aspect_ratio: 3/1
hold_action:
action: more-info
icon: 'custom:ps4-down'
show_icon: true
show_name: false
tap_action:
service_data:
command: down
- aspect_ratio: 3/1
hold_action:
action: more-info
icon: 'custom:ps4-o'
show_icon: true
show_name: false
tap_action:
service_data:
command: back
conditions:
- entity: media_player.playstation_4
state_not: standby
type: conditional
To get the custom icons, you make a file called custom_icons.js in your /config/www/ folder and put the following code into it. Then save and restart Home Assistant.
async function getIcon(name) {
if (name === "ps4-up") {
return {
path: "M5.7,14.384,11.9984,20,18.3,14.384V5.9937C18.3,4.8328,14.4112,4,12,4c-2.4128,0-6.3.8328-6.3,1.9937Z",
if (name === "ps4-down") {
return {
path: "M18.3,9.616,12.0016,4,5.7,9.616v8.3903C5.7,19.1672,9.5888,20,12,20c2.4128,0,6.3-.8328,6.3-1.9937Z",
if (name === "ps4-left") {
return {
path: "M14.384,18.3,20,12.0016,14.384,5.7H5.9937C4.8328,5.7,4,9.5888,4,12c0,2.4128.8328,6.3,1.9937,6.3Z",
if (name === "ps4-right") {
return {
path: "M9.616,5.7,4,11.9984,9.616,18.3h8.3903C19.1672,18.3,20,14.4112,20,12c0-2.4128-.8328-6.3-1.9937-6.3Z",
if (name === "ps4-x") {
return {
path: "M2,12A10,10,0,1,1,12,22,9.97863,9.97863,0,0,1,2,12ZM18.0109,7.5736,16.4274,5.9901,12.001,10.4165,7.5746,5.9901,5.992,7.5736,10.4195,12,5.993,16.4264l1.5825,1.5825,4.4265-4.4264,4.4264,4.4264,1.5835-1.5825L13.5855,12Z",
if (name === "ps4-o") {
return {
path: "M2,12A10,10,0,1,1,12,22,9.97812,9.97812,0,0,1,2,12ZM12,7.179A4.821,4.821,0,1,1,7.179,12,4.82686,4.82686,0,0,1,12,7.179m0-1.8843a6.7063,6.7063,0,1,0,6.7073,6.7063A6.70641,6.70641,0,0,0,12,5.2947Z",
if (name === "ps4-options") {
return {
path: "M17.71674,10.32349v8.032c0,2.77289-2.55939,5.01947-5.71576,5.01947a5.95825,5.95825,0,0,1-4.74054-2.21442,4.58,4.58,0,0,1-.97718-2.8078V10.32349a4.52465,4.52465,0,0,1,.70087-2.40784A5.55025,5.55025,0,0,1,9.90948,5.65521,6.38682,6.38682,0,0,1,11.99915,5.304l.00183.00006V5.304C15.15735,5.304,17.71674,7.55151,17.71674,10.32349ZM4.68265,4.116a2.0508,2.0508,0,0,0,.4589-1.454,2.78746,2.78746,0,0,0-.1179-.8552,1.8459,1.8459,0,0,0-.3442-.6426,1.43388,1.43388,0,0,0-.558-.4015A1.95249,1.95249,0,0,0,3.36005.625a1.87079,1.87079,0,0,0-.7739.1481,1.47876,1.47876,0,0,0-.5622.3984,1.46062,1.46062,0,0,0-.3484.6259,3.33987,3.33987,0,0,0-.1043.848,2.09135,2.09135,0,0,0,.4642,1.4539,1.70589,1.70589,0,0,0,1.3246.5049A1.72724,1.72724,0,0,0,4.68265,4.116Zm-1.3236-.1794A.945.945,0,0,1,2.605,3.631a1.45533,1.45533,0,0,1-.2671-.9679,1.62692,1.62692,0,0,1,.265-1.0045.89756.89756,0,0,1,.7562-.3421.88839.88839,0,0,1,.7541.3421,1.65564,1.65564,0,0,1,.2566,1.0045,1.82671,1.82671,0,0,1-.0772.5716,1.12339,1.12339,0,0,1-.2159.3963.88748.88748,0,0,1-.3234.2295,1.01216,1.01216,0,0,1-.3932.0761Zm1.9838.5476h.7802V3.1231h.8657a1.31436,1.31436,0,0,0,.4934-.0877,1.11486,1.11486,0,0,0,.3755-.2419.92416.92416,0,0,0,.2399-.3693,1.37554,1.37554,0,0,0,.0855-.4693,1.32592,1.32592,0,0,0-.0866-.4715,1.13311,1.13311,0,0,0-.2399-.3849,1.07075,1.07075,0,0,0-.3755-.2586,1.2789,1.2789,0,0,0-.4933-.0918H5.34185V4.4748Zm1.5208-1.9963h-.7302V1.3927h.7302a.655.655,0,0,1,.485.1512.531.531,0,0,1,.1491.388.55575.55575,0,0,1-.1481.4026.65337.65337,0,0,1-.485.1544Zm2.473,1.9879h.7802V1.3988h1.1296V.748H8.21535v.6488h1.1213v3.079Zm2.8454.0083V.748h-.7802V4.4841Zm1.9974.1408a1.72174,1.72174,0,0,0,1.3215-.4881,2.0505,2.0505,0,0,0,.4589-1.454,2.923,2.923,0,0,0-.1178-.8553A1.77965,1.77965,0,0,0,15.5,1.185a1.43349,1.43349,0,0,0-.5581-.4015,1.95032,1.95032,0,0,0-.7614-.1377,1.98971,1.98971,0,0,0-.7614.1377,1.62842,1.62842,0,0,0-.5632.3984,1.612,1.612,0,0,0-.3463.6258,2.80932,2.80932,0,0,0-.1179.848,2.08152,2.08152,0,0,0,.4621,1.454,1.70939,1.70939,0,0,0,1.3246.5048Zm-.0021-.6779a.94535.94535,0,0,1-.7541-.3056,1.45678,1.45678,0,0,1-.265-.968,1.62768,1.62768,0,0,1,.2629-1.0044.896.896,0,0,1,.7562-.3421.88688.88688,0,0,1,.7541.3421,1.65425,1.65425,0,0,1,.2587,1.0044,1.8269,1.8269,0,0,1-.0793.5716,1.12388,1.12388,0,0,1-.2159.3964.88686.88686,0,0,1-.3233.2294,1.00559,1.00559,0,0,1-.3933.0762Zm4.3255.5371h.7165V.748h-.7301V3.1438L17.00815.748h-.8344V4.4852h.7217V1.9819l1.5959,2.5033Zm3.0905-2.6264h.7301a1.27833,1.27833,0,0,0-.1179-.5028,1.13765,1.13765,0,0,0-.3024-.388,1.38733,1.38733,0,0,0-.4621-.2461,2.25517,2.25517,0,0,0-1.2308-.0021,1.34534,1.34534,0,0,0-.4172.2357.91976.91976,0,0,0-.2587.3505,1.1261,1.1261,0,0,0-.0855.4318,1.1563,1.1563,0,0,0,.096.5006.7765.7765,0,0,0,.2993.3338,2.13746,2.13746,0,0,0,.5215.2295l.7301.1825a1.6579,1.6579,0,0,1,.2921.0866.59319.59319,0,0,1,.1773.1095.25685.25685,0,0,1,.0855.1377.62444.62444,0,0,1,.024.1669.42146.42146,0,0,1-.1919.365.97145.97145,0,0,1-.5632.1356.9407.9407,0,0,1-.5685-.1669.53443.53443,0,0,1-.2326-.4516h-.7541a1.1632,1.1632,0,0,0,.4318.9314,1.98822,1.98822,0,0,0,1.2245.315,2.28423,2.28423,0,0,0,.5424-.0761,1.30066,1.30066,0,0,0,.4485-.2086.9106.9106,0,0,0,.3129-.3505,1.10418,1.10418,0,0,0,.1043-.4777,1.47077,1.47077,0,0,0-.0458-.3807.91149.91149,0,0,0-.12-.2691.72225.72225,0,0,0-.1857-.1877,1.218,1.218,0,0,0-.2326-.1273,3.60994,3.60994,0,0,0-.4829-.1678l-.6237-.1565a1.13539,1.13539,0,0,1-.4402-.1825.334.334,0,0,1-.1356-.2712c0-.3025.2201-.4548.6624-.4548a.93951.93951,0,0,1,.5382.1409.54957.54957,0,0,1,.2086.4172Z",
if (name === "ps4-share") {
return {
path: "M5.4313,1.8729a.63124.63124,0,0,0-.2334-.4793.97961.97961,0,0,0-.6041-.1574c-.4956,0-.7416.17-.7416.5092a.37366.37366,0,0,0,.1537.3048,1.32924,1.32924,0,0,0,.4947.2053l.6991.1763c.1972.0543.3772.1176.5427.1809a1.34168,1.34168,0,0,1,.2596.1429.771.771,0,0,1,.208.2107,1.01008,1.01008,0,0,1,.1356.3021,1.61789,1.61789,0,0,1,.0507.4287,1.09733,1.09733,0,0,1-.1266.5354,1.22491,1.22491,0,0,1-.3401.3934,1.66875,1.66875,0,0,1-.5047.2442,1.94291,1.94291,0,0,1-.6104.085,2.177,2.177,0,0,1-1.3729-.3617A1.27106,1.27106,0,0,1,2.9559,3.575h.8438a.59785.59785,0,0,0,.2713.5065,1.08313,1.08313,0,0,0,.6395.1854,1.09185,1.09185,0,0,0,.6303-.1502.47734.47734,0,0,0,.2135-.4097.67652.67652,0,0,0-.0254-.1863.33787.33787,0,0,0-.0967-.1537.697.697,0,0,0-.199-.1221,1.77387,1.77387,0,0,0-.3274-.0977l-.8375-.2053a2.01106,2.01106,0,0,1-.5752-.2578.98465.98465,0,0,1-.3346-.3753A1.27125,1.27125,0,0,1,3.05,1.7481a1.23069,1.23069,0,0,1,.094-.4857A1.04062,1.04062,0,0,1,3.4334.869,1.44981,1.44981,0,0,1,3.9155.6049,2.07712,2.07712,0,0,1,4.5838.5,2.20607,2.20607,0,0,1,5.264.5977a1.5703,1.5703,0,0,1,.52.2767,1.27311,1.27311,0,0,1,.3364.4341,1.45427,1.45427,0,0,1,.1321.5644H5.4313ZM9.0851,4.8213V2.9437H7.4526V4.8204H6.5781V.6384h.8745V2.212H9.0851V.6384h.8818v4.182H9.0842Zm4.0608,0-.2634-.8628H11.3398l-.2967.8628H10.117L11.6093.6393h1.0129l1.4742,4.182h-.9505Zm-1.0392-3.236h-.0163l-.5426,1.6532h1.0645l-.5246-1.6623Zm4.5908,3.2441V3.7441a.57279.57279,0,0,0-.1375-.4314.76016.76016,0,0,0-.5155-.1293H15.113V4.8113h-.852V.6384h2.1236a1.46432,1.46432,0,0,1,.5263.0904,1.18056,1.18056,0,0,1,.4052.2532,1.08557,1.08557,0,0,1,.2605.3844,1.28374,1.28374,0,0,1,.0931.4812,1.11623,1.11623,0,0,1-.1627.6014.912.912,0,0,1-.4631.369.69179.69179,0,0,1,.3943.2713,1.03034,1.03034,0,0,1,.1176.5481V4.8131h-.8592ZM15.1112,1.3628V2.477h1.0943a.65418.65418,0,0,0,.4974-.1573.56136.56136,0,0,0,.1447-.3962.58646.58646,0,0,0-.1429-.4033.6033.6033,0,0,0-.4684-.1574Zm2.7675,3.4576V.6384h3.0731v.7307h-2.232v.9044h2.0485v.7371H18.7198V4.0959h2.3243v.7434H17.8787ZM12.001,5.429v.00006L11.99918,5.429a6.38585,6.38585,0,0,0-2.1283.36358A5.55121,5.55121,0,0,0,7.01273,7.99927a4.52793,4.52793,0,0,0-.7295,2.44922v8.02929A4.58,4.58,0,0,0,7.26077,21.286,5.95816,5.95816,0,0,0,12.001,23.5c3.15643,0,5.71582-2.24658,5.71582-5.01947v-8.032C17.71677,7.67651,15.15738,5.429,12.001,5.429Z",
window.customIconsets = window.customIconsets || {};
window.customIconsets["custom"] = getIcon;
Then you lastly have to add /local/custom_icons.js as a Javascript Module to your Lovelace Resources.
If you have any questions, let me know!
