Thanks Thomas, you do not know how long I have been trying to get that working!
@thomasloven After update HA to 0.81.1 every entities card in column-card (with panel: true) has invalid style for card title.
Glance card (left side) has correct styled title but entities card (right side) not.
My config:
- id: home
icon: mdi:home
title: 'Pomieszczenia'
panel: true
cards:
- type: custom:column-card
cards:
- type: glance
title: 'Salon'
show_name: false
column_width: calc(100% / 4)
entities:
- sensor.temperature_salon
- sensor.humidity_salon
- sensor.co2_salon
- sensor.illumination_salon
- type: entities
title: 'Pracownia'
show_header_toggle: false
entities:
- sensor.temperature_pracownia
- sensor.humidity_pracownia
- binary_sensor.balcony_door_pracownia
Any solution for that?
I’m sorry. I cant’ seem to be able to reproduce this.
By the way column_width:
is deprecated.
You should use columns: 4
instead - or rather yet just leave it out entirely.
It’s very strange but on my test system I can’t reproduce this issue either. However, on the main system, adding column-card broke titles style. The problem isn’t related to the browser cache. I clean the cache every time.
I’m having trouble getting this card to work with the new Thermostat card.
With the following config:
cards:
- type: thermostat
entity: climate.bedroom
it renders like this:
Have you got any idea what is happening here?
Afraid not, but I’ve heard of the issue. Could you please post an issue on github to remind me for when I get the time to look at this?
I found a way to reproduce this.
When the first card inside column-card is entity-filter with the entities card, all the entites card titles are invalid styled. The same issue occurs with the layout-card.
Example config:
- id: c9621a53bbc144f687b870575aade4ef
icon: mdi:home
panel: true
cards:
- type: custom:layout-card
cards:
- type: entity-filter
entities:
- device_tracker.iphone
- device_tracker.ipad
- device_tracker.oneplus
state_filter:
- home
card:
type: entities
title: 'W domu'
- id: 47fe3813d353437f98b61740fa607cf4
type: custom:monster-card
show_empty: false
card:
type: entities
title: 'Światła'
filter:
include:
- domain: light
exclude:
- entity_id: light.lamp_salon
- entity_id: light.cabinet_antek
- entity_id: light.leds_przedpokoj
Try with the latest version of layout-card. I haven’t tested, but I may have accidentally fixed this…
Issue gone with latest version of th layout-card. Thank you.
Hey,
I have tried searching around for how to add this custom card to my Home Assistant but have not had any luck.
Could someone point me in the right direction to add this new card style?
Thanks in advance
Before anything else: Don’t use column-card. Use layout-card.
How to add a custom card is described in the first page of the lovelace documentation, under the section “Custom Cards”
This also has a good description: https://github.com/ciotlosm/custom-lovelace
THIS CARD IS DEPRECATED
It’s replaced by layout-card
I can’t edit the first post in the topic anymore… @fabaff can you do something? Locking the topic would be ok. Thank you @rpitera.
I understand this card was depreciated but it seems like the new card cannot create a bar at the top like the original. Is there a reason you depreciated it?
@thomasloven Do you think it’s possible to be able to make columns different widths? So like column 1 and 2 are say 200px and 3rd column is say 400px?
I really recommend reading through the entire readme before jumping into using layout-card - It’s tricky stuff to get right.
Particularly the second sentence of the Layouts section.
I also really recommend posting questions about layout-card in the forum thread for layout-card.
