Lovelace Comparative Analysis of Electric Power Energy
source code : https://drive.google.com/file/d/1tg0yGWbnmSz2QrPJuAVQqRvKvYGz1v-U/view?usp=drive_link
install method;
  • The YAML code in the input_xxxx.yaml file is generated using the create_input_xxxx.yaml files and copied using HA’s template editor.
  • The YAML code in the utility_meter.yaml file is generated using the create_utility_meter.yaml file and copied using HA’s template editor.
  • The YAML code in the sensors’ integration (sensors.yaml) file is generated using the create_sensors_integration file and copied using HA’s template editor.
  • The lovelace view is created as a panel type, and after adding a vertical-stack card, the source code is generated using create_power_lovelace.yaml and copied using HA’s template editor.
  • Install the HA add-on AppDaemon and add the following to the Configuration options:
    system_packages:
    • python3-dev
      python_packages:
    • pymysql
      Configure the above two packages and save. restart.
  • Copy the energy_processor.yaml and energy_processor.py files to the addon_configs\xxxxxxxx_appdaemon\apps folder of HAOS (the path may be under config depending on your HA version).
  • Edit the MariaDB information in energy_processor.yaml.
:memo: Project Summary: Advanced Energy Analysis Dashboard
1. Project Goal
  • Objective: Build a precision dashboard to analyze monthly (1-year history) and daily (1-month history) power consumption using energy sensor data stored in MariaDB.
  • Key Requirements:
    • Allow users to freely select the Year, Month, and Device (Slot).
    • Data Preprocessing: Missing dates must be displayed as ‘0’ or empty cells to maintain the layout.
    • Calendar Visualization: Display daily data in a calendar format (e.g., correct start weekday, Sundays in red, weekly line breaks).
    • Dynamic Scalability: The number of device slots should be adjustable via the UI.
2. Challenges & Failed Approaches (The Struggle)
  • :x: Phase 1: SQL Sensor Integration
    • Issue: Disabling polling meant no updates; enabling it caused high DB load.
    • UI Flickering: The sensor frequently toggled between Unavailable and values during updates, causing the Lovelace UI to flash.
    • Logic Limits: Complex logic, like filling zero values for missing dates, was nearly impossible with SQL alone.
  • :x: Phase 2: Markdown Tables
    • Issue: Tables wouldn’t fill the full width (leaning left).
    • Styling: Impossible to control font color, weight, or cell padding.
    • Spacing: HA’s renderer ignored   and Unicode spaces, breaking the alignment.
  • :x: Phase 3: Modern CSS (Grid/Flex)
    • Issue: Home Assistant’s Markdown card sanitizer stripped out most inline styles (e.g., width: 100%, display: grid), rendering the layout broken.
3. The Final Solution (Success Strategy) :white_check_mark:
:key: Key Tech 1: Backend - AppDaemon (Python) Logic and DB queries were offloaded entirely to Python.
  • Dynamic Listeners: Only registers listeners for the currently active number of slots (via input_number) to save resources.
  • Logic: Uses datetime to calculate the weekday of the 1st of the month to insert empty padding cells, creating a true calendar layout.
  • Storage: The generated HTML string is stored in the attributes of an input_text entity to bypass the 255-character state limit.
:key: Key Tech 2: Frontend - Legacy HTML4 Tags Instead of modern CSS, I used Classic HTML4 tags to bypass the HA style sanitizer.
  • Layout: Used <table width="100%">, cellpadding="0", cellspacing="0".
    • Controlled margins using the height of empty <tr> rows instead of CSS padding.
    • Used a single monolithic table structure to eliminate external margins.
  • Styling:
    • <font color="...">: For coloring power usage (Pink), Sundays (Red), and dividers (Cyan).
    • <b>: For bold text.
    • align="center" & <th width="XX%">: To force equal column distribution.
    • bgcolor: Used for creating 1px divider lines without <hr> margins.
:key: Key Tech 3: UI - Lovelace (Jinja2 Templates)
  • Dynamic Generation: Used Jinja2 loops to automatically generate card YAML based on the slot count.
  • Live Updates: Tile card names and Markdown titles utilize {{ states() }} templates to reflect changes (Year/Month/Slot count) in real-time.
  • Manual Refresh: Added an input_button as a bridge to trigger an on-demand data refresh via AppDaemon.
4. Final System Flow
  1. User Action: Selects Year/Month or clicks “Refresh”.
  2. AppDaemon: Detects change → Queries MariaDB → Processes Data (Calendar Logic).
  3. HTML Generation: Python constructs a raw HTML string using legacy tags (<table>, <font>, etc.).
  4. State Update: Saves the HTML string into input_text.slot_X attributes.
  5. Lovelace: The Markdown card renders the attribute value as a perfect HTML table.
5. Key Results
  • Perfect Calendar View: Starts on the correct weekday; Sundays are highlighted.
  • Compact Design: Zero unnecessary margins; clean 1px divider lines.
  • Scalability: Changing the slot count (e.g., 4 → 6) instantly reflects in the backend logic.
  • Stability: DB polling is disabled. Updates are event-driven, eliminating system load and UI flickering.
