Lovelace config not found?
Greetings all. Probably a newbie question, but when installing Kalkih’s excellent mini-graph card (GitHub - kalkih/mini-graph-card: Minimalistic graph card for Home Assistant Lovelace UI) the instructions says “go to Navigation → Lovelace Dashboards → Resources Tab”, and none of this is to be found in HA …
It’s probably an “error 40” from this ol’ brickhead, but there seems no way into configuring Lovelace anymore (there used to be).
Editing configuration.yaml inaccordance with the instructions (adding a reference to mini-graph-bundle.js inside configuration.yaml) just produces errors.
What very basic and obvious thing am I missing here?
Settings → Dashboards → the three dots in the top right → Resources
You may need to enable Advanced Mode in your user profile first, I don’t remember.
Ah … well, close. First, thanks. It did bring me a little further (see, I told y’all it was an error 40… :blush:) . However, I don’t really see where it throws me. I just get this:
I added the text from “resources” and the two following lines, but that’s clearly neither here nor there. And the resulting card is seen on the right…
You have to add it to the Resources Dashboard, as Tinkerer already said. Or call the Resorces Dashboard with http://your_ha_ip:8123/config/lovelace/resources
You add the resources to the Resources tab, not in the card definition.
Thanks, it brought me a little further :slight_smile: (this stuff is hard on beginners)
