Question: is it at all possible to install custom Lovelace cards in Home Assistant Core?
Running HA Core in a python virtual environment on Xubuntu 20.04. Trying to install the custom power-wheel-card (Github). Dropped ‘power-wheel-card.js’ in config/www. In my case: /home/homeassistant/.homeassistant/www/
Using yaml-mode for Lovelace. Added ‘resource’ statement to ui-lovelace.yaml:
resources:
url: /local/power-wheel-card.js?v=1
type: module
When loading front-end, I get response ‘custom card does not exist’.
Permissions on files and directories are OK. Searched the forums, and it’s unclear to me whether custom cards only work in Hass.io/Home Assistant, or also in HA Core.
Thanks – I went the manual route you suggested (config -> dashboard -> resources) and that worked. Wasn’t entirely happy, as I only have a GUI-managed Lovelace test page, and manage the ‘production’ part of my front-end fully via YAML (I don’t think that’s deprecated, at least, I hope not!). Yet oddly enough, after having added the custom card in the GUI, it suddenly started to work on the YAML-page as well. Not sure if this is a bug or a feature, but the end result is satisfactory!
