i’ve been stuck for four days now.
How do you add new custom card element?
this is my configuration. it’s really messy because i’m still learning.
Thanks!!
Thanks!!
usually you need to copy your content-card-example.js somewhere inside /www/ and add it to resources
: if you’re using LL in YAML mode, check out this (example), otherwise go to Configuration → Lovelace Dashboards, select Resources tab and click the yellows plus sign at the bottom left to add a new one.
type is usually module.
path is /local/path/file.js
where /local
= /www/
here’s some info just in case
i worked home assistant 0.107.7
add resources to configuration.yaml
add card to ui-lovelace.yaml
i’ve made a blank card.
thanks to this card I was able to understand and make a blank card.
class BlankCard extends HTMLElement {
constructor() {
super();
this.attachShadow({ mode: 'open' });
setConfig(config) {
if (!config.entity) {
throw new Error('Please define an entity');
const root = this.shadowRoot;
if (root.lastChild) root.removeChild(root.lastChild);
const card = document.createElement('ha-card');
const content = document.createElement('div');
const style = document.createElement('style');
style.textContent = `
ha-card {
--base-unit: 50px;
height: calc(var(--base-unit)*3);
position: relative;
// content.innerHTML = `
// <div class="container">
// </div>
// card.appendChild(content);
card.appendChild(style);
root.appendChild(card);
this._config = config;
set hass(hass) {
const config = this._config;
root.lastChild.hass = hass;
getCardSize() {
return 1;
customElements.define('blank-card', BlankCard);
