Lovelace: Custom Cards
HI, using this example
Lovelace: Custom Cards | Home Assistant Developer Docs
I created an HTML page with 4 buttons it sends MQTT messages when pressed and released. all working in webserver, but when I integrate HTML code into Custom Cards, it’s showing buttons but clicking on it doesn’t do anything.
4 files in “www/custom_lovelace/habot”
I added resource /local/custom_lovelace/habot/habot-card.js
  • habot-card.js ----- Custom Cards
  • jquery-3.5.0.js
  • mqttws31.min.js
  • app.js
I think the problem is that I need to import these modules as
import "jquery-3.5.0.js?module";
import "mqttws31.min.js?module";
import "app.js?module";
but when I do this the card gives an error “custom habot-card not found”
Help with advice. which way to look
habot-card.js
class HABot extends HTMLElement {
  // Whenever the state changes, a new `hass` object is set. Use this to
  // update your content.
  set hass(hass) {
    // Initialize the content if it's not there yet.
    if (!this.content) {
      this.innerHTML = `
        <ha-card header="HABot Control">
          <div class="card-content"></div>
        </ha-card>
      this.content = this.querySelector('div');
    this.content.innerHTML = `
  <head>
  <script src="query-3.5.0.js"></script>
  <script src="mqttws31.min.js"></script>
  <script src="app.js"></script>
  </head>
	<body>
			<input type="button" value="FORWARD" id="forward"><br><br>
			<input type="button" value="LEFT" id="left">
			<input type="button" value="RIGHT" id="right"><br><br>
			<input type="button" value="BACKWARD" id="backward">
	<script>
	$( "[id^=left]" ).on('mousedown touchstart',function(){
		$(left());
	$( "[id^=left]" ).on('mouseup touchend',function(){
		$(stop());
	$( "[id^=right]" ).on('mousedown touchstart',function(){
		$(right());
	$( "[id^=right]" ).on('mouseup touchend',function(){
		$(stop());
	$( "[id^=forward]" ).on('mousedown touchstart',function(){
		$(forward());
	$( "[id^=forward]" ).on('mouseup touchend',function(){
		$(stop());
	$( "[id^=backward]" ).on('mousedown touchstart',function(){
		$(backward());
	$( "[id^=backward]" ).on('mouseup touchend',function(){
		$(stop());
	</script>
	</body>
  // The user supplied configuration. Throw an exception and Lovelace will
  // render an error card.
  setConfig(config) {
    this.config = config;
  // The height of your card. Home Assistant uses this to automatically
  // distribute all cards over the available columns.
  getCardSize() {
    return 3;
customElements.define('habot-card', HABot);
app.js
// Generate a new random MQTT client id on each page load
var MQTT_CLIENT_ID = "iot_web_"+Math.floor((1 + Math.random()) * 0x10000000000).toString(16);
// Create a MQTT client instance
var MQTT_CLIENT = new Paho.MQTT.Client("192.168.2.20", 1884, "/ws", MQTT_CLIENT_ID);
// Tell the client instance to connect to the MQTT broker
MQTT_CLIENT.connect({userName : "xxx",password : "xxxxx", onSuccess: myClientConnected });
// This is the function which handles button clicks
function left() {
  // create a new MQTT message with a specific payload
  var left = new Paho.MQTT.Message("left");
  // Set the topic it should be published to
  left.destinationName = "HABot/Controlle";
  // Publish the message
  MQTT_CLIENT.send(left);
function right() {
  var right = new Paho.MQTT.Message("right");
  right.destinationName = "HABot/Controlle";
  MQTT_CLIENT.send(right);
function forward() {
  var forward = new Paho.MQTT.Message("forward");
  forward.destinationName = "HABot/Controlle";
  MQTT_CLIENT.send(forward);
function backward() {
  var backward = new Paho.MQTT.Message("backward");
  backward.destinationName = "HABot/Controlle";
  MQTT_CLIENT.send(backward);
function stop() {
  var stop = new Paho.MQTT.Message("stop");
  stop.destinationName = "HABot/Controlle";
  MQTT_CLIENT.send(stop);
// This is the function which handles subscribing to topics after a connection is made
function myClientConnected() {
  MQTT_CLIENT.subscribe("<your_random_topic_root>/iot_tutorial/from_esp8266");
// This is the function which handles received messages
function myMessageArrived(message) {
  // Get the payload
  var messageBody = message.payloadString;
  // Create a new HTML element wrapping the message payload
  var messageHTML = $("<p>"+messageBody+"</p>");
  // Insert it inside the ```id=updateMe``` element above everything else that is there
  $("#updateMe").prepend(messageHTML);
// Tell MQTT_CLIENT to call myMessageArrived(message) each time a new message arrives
MQTT_CLIENT.onMessageArrived = myMessageArrived;
Good day.
I had the same problem.
Were you able to add modules?
If so, how did you do it?
I didn’t find the solution, and discarded this idea of making a module
Anyway thanks for your reply
