Lovelace Custom Fan Card Example
If anyone is interested I’ve been working on tweaking this card to make it look and act like the modifications I made to the state-card-custom-fanspeed from https://community.home-assistant.io/t/fan-control-set-speed-working-quick-setup/57520.
The only things different from that are the color for the “off” state and the button order. But if you want it the other way then it’s trivial to make the change.
Here are the screenshots with a dark theme and with the default theme:
ex
ex2
ex3
ex4
Here is the code:
class CustomFanCard extends Polymer.Element {
    static get template() {
        return Polymer.html`
            <style is="custom-style" include="iron-flex iron-flex-alignment"></style>
            <style>
                :host {
                    line-height: 1.5;
                .speed {
                    min-width: 30px;
                    max-width: 30px;
					margin-left: 2px;
                    margin-right: 2px;
    	            //background-color:#546E7A;
					background-color:#759aaa;
	                border: 1px solid lightgrey;
	                font-size: 10px !important;
	                float: right !important;
               </style>
            <hui-generic-entity-row hass="[[hass]]" config="[[_config]]">
                <div class='horizontal justified layout' on-click="stopPropagation">
                    <paper-button
                        class='speed'
						style='[[_lowOnColor]]'
                        toggles name="low"
                        on-tap='setSpeed'
                        disabled='[[_isOnLow]]'>LOW</paper-button>
                    <paper-button
                        class='speed'
						style='[[_medOnColor]]'
                        toggles name="medium"
                        on-tap='setSpeed'
                        disabled='[[_isOnMed]]'>MED</paper-button>
                    <paper-button
                        class='speed'
						style='[[_highOnColor]]'
                        toggles name="high"
                        on-tap='setSpeed'
                        disabled='[[_isOnHigh]]'>HIGH</paper-button>
				    <paper-button
                        class='speed'
						style='[[_offColor]]'
                        toggles name="off"
                        on-tap='setSpeed'
                        disabled='[[_isOffState]]'>OFF</paper-button>
                </div>
            </hui-generic-entity-row>
    static get properties() {
        return {
            hass: {
                type: Object,
                observer: 'hassChanged'
            _config: Object,
            _stateObj: Object,
			_lowOnColor: String,
			_medOnColor: String,
			_highOnColor: String,
			_offColor: String,
            _isOffState: Boolean,
            _isOnState: Boolean,
            _isOnLow: Boolean,
            _isOnMed: Boolean,
            _isOnHigh: Boolean
    setConfig(config) {
        this._config = config;
    hassChanged(hass) {
        const config = this._config;
        const stateObj = hass.states[config.entity];
        let speed;
        if (stateObj && stateObj.attributes) {
            speed = stateObj.attributes.speed || 'off';
		let low;
		let med;
		let high;
		let offstate;
		    if (stateObj.state == 'on' && stateObj.attributes.speed == 'low') {
			    low = 'on';
		    } else if (stateObj.state == 'on' && stateObj.attributes.speed == 'medium') {
			    med = 'on';
		    } else if (stateObj.state == 'on' && stateObj.attributes.speed == 'high') {
			    high = 'on';
		    } else {
				offstate = 'on';
        let lowcolor;
		let medcolor;
		let hicolor;
		let offcolor;
		if (low == 'on') {
			lowcolor = 'background-color: #43A047';
		} else {
			lowcolor = '';
		if (med == 'on') {
			medcolor = 'background-color: #43A047';
		} else {
			medcolor = '';
		if (high == 'on') {
			hicolor = 'background-color: #43A047';
		} else {
			hicolor = '';
		if (offstate == 'on') {
			//offcolor = 'background-color: #43A047';
			offcolor = 'background-color: #f44c09';
		} else {
			offcolor = '';
		this.setProperties({
            _stateObj: stateObj,
			_isOffState: stateObj.state == 'off',
            _isOnLow: low === 'on',
			_isOnMed: med === 'on',
			_isOnHigh: high === 'on',
			_lowOnColor: lowcolor,
			_medOnColor: medcolor,
			_highOnColor: hicolor,
			_offColor: offcolor
    stopPropagation(e) {
        e.stopPropagation();
    setSpeed(e) {
        const speed = e.currentTarget.getAttribute('name');
        this.hass.callService('fan', 'set_speed', {
            entity_id: this._config.entity, speed: speed
customElements.define('custom-fan-card', CustomFanCard);
the configuration is the same as the original card:
- entity: fan.master_bedroom_fan
  type: custom:custom-fan-card
If you don’t like the colors you can simply go into the code and change the hex values for the “background-color:”.
And @rhodges since this thread has transformed into a thread specific to a custom fan card I’m changing the title of the thread to reflect that. I hope that’s OK. It will help more people find it if that’s the kind of information they need.
And thanks for getting the ball rolling on this. I’m OK at modifying cards (after digging around trying to find the info I need!) but there’s no way I would have known how to even get started without your initial work.
