make sure that you have custom-ui installed and working.
follow the installing and activating directions
in your configuration.yaml add or append this to your homeassistant:
customize_glob:
fan.*:
custom_ui_state_card: state-card-custom-fanspeed
in your configuration.yaml add or append the new state card under frontend: you should have the lines above this for custom_ui so don’t be surprised if it looks different.
frontend:
extra_html_url:
- /local/custom_ui/state-card-custom-fanspeed.html
extra_html_url_es5:
save this as state-card-custom-fanspeed.html in www/custom_ui
<dom-module id="state-card-custom-fanspeed">
<template>
<style is="custom-style" include="iron-flex iron-flex-alignment"></style>
<style>
:host {
line-height: 1.5;
paper-button {
min-width: 30px;
height: 30px;
margin: 2px;
background-color:#f3f3f3;
border: 1px solid lightgrey;
font-size: 10px !important;
float: right !important;
</style>
<div class='horizontal justified layout'>
<state-info state-obj="[[stateObj]]"></state-info>
<paper-button-group>
<paper-button style="[[btnOffstyle]]" on-click='handleOffTap'>Off</paper-button>
<paper-button style="[[btnLowstyle]]" on-click='handleLowTap'>Low</paper-button>
<paper-button style="[[btnMedstyle]]" on-click='handleMedTap'>Med</paper-button>
<paper-button style="[[btnHighstyle]]" on-click='handleHighTap'>High</paper-button>
</paper-button-group>
</div>
</template>
</dom-module>
<script>
Polymer({
is: 'state-card-custom-fanspeed',
properties: {
hass: {
type: Object,
stateObj: {
type: Object,
observer: 'stateObjChanged',
statusValue: {
type: String,
value: 'Unset',
btnOffstyle: {
type: String,
value: '',
btnHighstyle: {
type: String,
value: '',
btnMedstyle: {
type: String,
value: '',
btnLowstyle: {
type: String,
value: '',
stateObjChanged: function (newVal) {
if (newVal) {
if (newVal.attributes.speed == 'off') {
this.statusValue = 'off';
this.btnOffstyle = 'background-color: #42d9f4;';
this.btnLowstyle = '';
this.btnMedstyle = '';
this.btnHighstyle = '';
this.updateStyles({'--status-text-color': 'gray'});
} else if (newVal.attributes.speed == 'low') {
this.statusValue = 'low';
this.btnOffstyle = '';
this.btnLowstyle = 'background-color: #42d9f4;';
this.updateStyles({'--status-text-color': 'blue'});
} else if (newVal.attributes.speed == 'medium') {
this.statusValue = 'medium';
this.btnMedstyle = 'background-color: #42d9f4;';
this.updateStyles({'--status-text-color': 'yellow'});
} else if (newVal.attributes.speed == 'high') {
this.statusValue = 'high';
this.btnHighstyle = 'background-color: #42d9f4;';
this.updateStyles({'--status-text-color': 'red'});
handleHighTap: function (ev) {
this.setSpeed(ev, 'high');
handleMedTap: function (ev) {
this.setSpeed(ev, 'medium');
handleLowTap: function (ev) {
this.setSpeed(ev, 'low');
handleOffTap: function (ev) {
this.setSpeed(ev, 'off');
setSpeed: function (ev, setspeed ) {
if( setspeed == 'off' ){
//this.updateStyles({'--status-text-color': '#F44336'});
//this.updateStyles({'--state-label-badge': '#F44336'});
var serviceData = {entity_id: this.stateObj.entity_id};
this.hass.callService('fan', 'turn_off', serviceData);
} else {
if (this.stateObj.state != 'on'){
var serviceData = {entity_id: this.stateObj.entity_id, speed: setspeed };
this.hass.callService('fan', 'turn_on', serviceData );
}else{
this.hass.callService('fan', 'set_speed', serviceData );
ev.stopPropagation();
</script>
Restart home assistant and when its loaded in your browser make sure you do a full reload of the HA interface. Shift + refresh.
End result
