Hi world,
I would link to install the custom entity “slider-entity-row” using HACS in web mode (i keep everything done automatically, I’m not in YALM mode). However this does not work.
NB : sorry for approximate menu names, I’m using a french version, so translation may not be accurate
So far:
- I installed the entity using HACS front end. As explained in the HACS doc, it installed the files in /config/www/community/lovelace-slider-entity-row. At the end of the install, my web browser cache is deleted and the HA interface reloaded.
- In the configuration menu then lovelace ui, in the ressource tab, the entity is listed with URL “/hacsfiles/lovelace-slider-entity-row/slider-entity-row.js” and as a “Javascript module”, which seems correct according to HACS documentation
After installation, I restarted HA (menu configuration/server/ and then restart)
So the installation is consistent with the HACS lovelace plugin documentation : HERE
Now, if I try to add a manual card with the following code (“volet1” being a rolling curtain)
type: entities
entities:
- type: 'custom:slider-entity-row'
- entity: cover.volet1
I’ve got this error
No entity specified. type: 'custom:slider-entity-row'
I do not really know what to do to fix this error. I tried to specify a different folder name in the config/lovelace/ressources pannel, without any success so far
