Lovelace: custom sidebar card
Too bad this doesn’t support multiple dashboards :frowning:
Does anyone have problems with the Custom Sidebar Card since the update to Home Assistant 0.116.0?
Since the update my default start page is not loaded correctly when I start Home Assistant.
However, if I deactivate the Custom Sidebar, it is displayed correctly.
I have also tried several devices and tried to clear the browser cache. But this did not help
Start page with activated sidebar:
Start page with deactivated sidebar:
Just did the update and it looks like there are no problems except the one i describe a couple of posts ago, but that was also before the update.
Anyone who knows how to add spacing between the lines? :confused:
Same issue … i have to go up right … 3 dots refresh… weird
how you made 1st 2 buttons with persons? Can you please share your config
Possibly the problems are related to the last changes made in Home Assistant 106:
The problem seems to be the custom homekit style card, also from @DBuit, and not the sidebar card.
Does anyone here have enough debug experience to get to the bottom of this problem? Maybe we can solve the problem ourselves, because it seemd that @DBuit is currently very busy.
@timota; You can find my current configuration on my GitHub page. The concrete code for the person cards is this one:
Send me a PM if you have any questions.
Greetings
Many thanks. Will try myself first.
Customer-header can no longer be used to hide the head bar.I now use the kiosk-mode. But as a result, the sidebar no longer goes at the bottom of the screen. How can I solve this problem? I put the sidebar in red so that it is more visible.
@Alindil
Little annoying the fix.
Open Kiosk.js file
replace with
  if (window.location.href.indexOf('kiosk') > 0) {
    setTimeout(function() {
        try {
            const home_assistant_main = document
                .querySelector("body > home-assistant").shadowRoot
                .querySelector("home-assistant-main");
            const header = home_assistant_main.shadowRoot
                .querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-lovelace").shadowRoot
                .querySelector("hui-root").shadowRoot
                .querySelector("#layout > app-header")
                .style.display = "none";
            const drawer = home_assistant_main.shadowRoot
                .querySelector("#drawer")
                .style.display = 'none';
            home_assistant_main.style.setProperty("--app-drawer-width", 0);
                .querySelector("#drawer > ha-sidebar").shadowRoot
                .querySelector("div.menu")
                .click();
            const mainView = home_assistant_main.shadowRoot
                .querySelector("#layout > div")
                .style.height = 'calc(100vh)';
            window.dispatchEvent(new Event('resize'));
        catch (e) {
            console.log(e);
    }, 200);
Open sidebar-card.js. On line 17807
replace
sidebarInner.style.height = (100 * _1vh) - headerHeight + 'px';
with
sidebarInner.style.height = (100 * _1vh) + 'px';
@DBuit all of a sudden my sidebar is translucent, I think since 0.117? This looks sick!
thanks for an amazing card!! so much potential…
but I’m having an issue, i want to use the media art plugin to show the cover art whats playing in the background ( https://github.com/TheLastProject/lovelace-media-art-background/blob/f7752ae8e1007cd5f1d7825b55f6588957f3acda/README.md)
but how can i change the z-index of the sidebar, so its above the background?
did you manage to find a solution for this?how to put sidebar above background and opague? trying to do the same
Anyone has this error on logs ?
2020-11-05 09:33:29 ERROR (MainThread) [frontend.js.latest.202009182] https://xxxxxxxxx:8123/hacsfiles/sidebar-card/sidebar-card.js:18269:25 Uncaught TypeError: Cannot read property ‘shadowRoot’ of null
Tanks for a great card.
A question. Can you group menu items? Say I want first 3 paths, then a breakpoint then 3 more? I guess I can a item without action but I like the lines.
Only thing I could do so far was setting a splitted background (aka on sidebar with fixed width while setting fixed background on right pane)
sidebar card seem no more loading since the upgrade to 118, did you notice the same ?
Using the twelve hour clock format however AM & PM is reversed. Does anyone know how to fix that?
Update - isn’t not reversed, it just does not switch to pm. Always says am.
Hi , please someone knows how to place the player card at the bottom? i m getting crazy
  bottomCard:
    type: 'custom:mini-media-player'
    cardOptions:
      entity: media_player.pi1
      hide:
        power: true
        source: true
        volume: false
    cardStyle: |
      :host {
        width: 100%;
        position: absolute;
        bottom: 0;
        left: 0;
