Lovelace: custom sidebar card
I have the same issue
Hi @Umbe and @adamlaakso1,
It works for me but i think the problem is the heigth of the sidebar it self.
You guys know developer console of your browser? Below i can see the height of the sidebar-inner please check how large it is and if the bottom card is at the bottom of the sidebar-inner.
If it is the problem is not the card but the sidebar it self. and than i need to find a solution :slight_smile: let me know!
Here is mine
but if i check the inner is another size
And i just made an update and my sidebar became grey … , the code there was making the bar same colour as the page , and now , not anymore.
Temporary fixed , changing the background and applying a fixed color to the bar , but if anyone get back the transparent , please let me know : )
So, I found that in the Dev console I can temporarily change the PX in the line element style. Changing it to 950 from 905 fixed it for me. Let me know if I can edit the style somewhere to force the change. Sorry, I’m techy but not a web dev kind of person!
hello everyone :slight_smile:
I need help, I made the menu I what.
it works fine but I need to refresh the page to get a menu why ??
Only after the refresh does I see it.
I really when to add my calendar to the sidebar,
Dose someone manage to do it and it looks good ?
Yep, I’m having the same problem. I see most others are using the 24 hour clock.
I’ve tried making changes to the sidebar-card.js file, but it’s not reflecting the changes on my UI.
I can’t say definitively because I haven’t been able to get it to make any changes, but line 17421 defines variable ampm to pm if hours >= 12.
However hours is a constant defined below. This means the constant hours will always be less than 12. Which would lead to always being am.
const hours = ((date.getHours() + 11) % 12 + 1);
Here’s an example: It is currently 8:16pm CST.
date.getHours() = 20
20 + 11 = 31
31 mod 12 = 7
7 + 1 = 8
so...
8 < 12
It is the correct hour, but since ampm is pulling from this constant, then it is technically less than 12.
Hopefully, this is the problem, and @DBuit can verify.
There is an issue listed in the Git, so I will add this to that thread as well.
Update Dec. 20: I can confirm this is the case now, because anytime it is 12:00-12:59 am or pm, the clock shows PM. It also shows the day before when running the 12 hour format.
Update Dec. 20, 7:50pm CST:
So I ended up having to search how to modify a custom component, I found out that the .gz file can be renamed or deleted, and any changes in the .js file will then show. I don’t know if this will affect how HACS acts with the component then.
To correct the ampm function, I modified the following.
Before
17741        const hours = ((date.getHours() + 11) % 12 + 1);
17766            var ampm = hours >= 12 ? 'pm' : 'am';
After
17741        const realhours = date.getHours();
17742        const hours = ((realhours + 11) % 12 + 1);
17767            var ampm = realhours >= 12 ? 'pm' : 'am';
I also added a way to turn the period off if I want a 12-hour clock without the AM or PM. I did this because on my Lenovo tablet, the clock takes up 1 whole row, and the period is below it and I like the clean look with just the numbers in 12-hour format.
image image
@Umbe & @adamlaakso1
To bring the bottomCard down to the base of the sidebar, you can add a negative margin-bottom to the ha-card style. When I set it to -50px, it brings the bottomCard down to the bottom of the screen. Even though the size of the header is 58px tall.
    cardStyle: |
      :host {
        width: 100%;
        position: absolute;
        bottom: 0;
        left: 0;
      ha-card {
        background: transparent;
        color: #fff;
        overflow: hidden !important;
        box-shadow: none !important;
        margin-bottom: -50px;
      .state {
        font-size: 8px;
Thanks!!! , it worked.
Amazing. Totally worked! Thank you
I’m testing the media background (https://github.com/TheLastProject/lovelace-media-art-background) in combination with the custom sidebar.
The problem is that when i use the media background nothing is clickable in the sidebar.
The sidebar is showing, but i can’t click any of the links or controls in there.
i can’t really shows it on a picture but i hope you get what i’m explaining. Anyone who has tried this? Or fixed this?
Hello everyone!
The sidebar-card is fantastic, I have a problem I can’t remove the top bar, where am I wrong? thanks
Hi
The car overview on right side is just amazing! I’ve been looking for something linke that for some time, would you mind sharing the original picture?
I’ve found useable pictures but none like yours!
Hi Mikael. The picture was derived from de mobile app of MercedesMe. SInce Mercedes recently closed down (limited) their Api, I am not using it anymore. Also I migrated my HA instance, and the image is no longer there. I switched to Dwains Dashboard with HA as well. So a lot of changes the last couple of months. In short :-): I don’t have it anymore. Srry.
Ahh okay, thanks! How do you show it now then? Maybe you found some nice way of doing it?
Thanks to your “MercedesMe” info i found and made the folowing. I’m not the best photoshopper but I think I can make it work for me atleast. Sharing with others.
Adding my pictures for anyone to find them using Google :slight_smile:
Keywords: Vehicle Car Overview Smart Home
pressure_new
Edit:
I actually found the original mercedesme android apg with a tons of nice pictograms inside including the original files
Please anyone help me my selecting tab doesnot show up
Let me know if clear :slight_smile:
  sidebarMenu:
    - action: navigate
      navigation_path: /home-kit/Page1
      active: true
      icon: mdi:home-assistant
config.yaml:
lovelace:
  mode: storage
  dashboards:
    home-kit:  #must have a - in the name
      mode: yaml
      title: example
      icon: mdi:apple
      show_in_sidebar: true
      require_admin: false
      filename: ui-lovelacehk.yaml
and the cards pages :
  - title: System
    path: Page1
    panel: true
    cards:
btw , which cards are you using for the entities ?
thanks
Is it possible to use a background image for the sidebar instead of a color?
This thread has a ton of good examples in it. Would love to see these pulled out and the sidebar-card documentation updated with these valuable “how-to” samples.
My question: I cannot get the .digitalClock font-size to adjust. I’d like the clock text to be smaller but nothing I’ve tried seems to change the default size including adding the !important. Suggestions?
.digitalClock {
    text-align: center;
    padding-bottom: 1px;
    padding-top: 20px
    font-size: 25px!important;
    line-height: 45px;
Mike
