04 sidebar_bottomCard_cards
- type: custom:weather-card
number_of_forecasts: '3'
hourly_forecast: false
details: false
entity: weather.home
forecast: false
current: true
- type: custom:mushroom-chips-card
chips:
- type: action
icon_color: blue
tap_action:
action: navigate
navigation_path: home
hold_action:
action: none
double_tap_action:
action: none
icon: mdi:home
- type: back
- type: menu
- type: action
tap_action:
action: navigate
icon: mdi:dots-vertical
icon_color: blue
- type: conditional
conditions:
- entity: switch.irrigation_pump_garden
state: 'on'
chip:
type: template
icon: mdi:sprinkler
icon_color: light-blue
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
.content {
animation: sprinkle 2s linear infinite;
transform-origin: 29% 88%;
@keyframes sprinkle {
0%, 15%, 30%, 45%, 60%, 100% { clip-path: inset(0 55% 0 0); transform: rotate(0deg); }
1%, 16%, 31%, 46% { clip-path: inset(0 0 0 0); transform: rotate(-10deg); }
6%, 21%, 36%, 51% { transform: rotate(2deg); }
- type: conditional
conditions:
- entity: switch.pool_tank_valve
state: 'on'
chip:
type: template
content_info: none
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
picture: /local/my-icons/smart-water-tap-color.png
- type: conditional
conditions:
- entity: switch.pool_filter_pump
state: 'on'
chip:
type: template
content_info: none
tap_action:
action: toggle
hold_action:
action: none
double_tap_action:
action: none
picture: /local/my-icons/pool filter-96.png
- type: custom:button-card
- type: grid
square: false
columns: 4
cards:
icon: mdi:home-floor-b
layout: vertical
tap_action:
action: navigate
navigation_path: b1
hold_action:
action: none
double_tap_action:
action: none
icon_color: green
icon: mdi:home-floor-g
layout: vertical
tap_action:
action: navigate
navigation_path: gf
hold_action:
action: none
double_tap_action:
action: none
icon_color: '#ffdead'
icon: mdi:home-floor-1
layout: vertical
tap_action:
action: navigate
navigation_path: ff
hold_action:
action: none
double_tap_action:
action: none
icon_color: '#CD5C5C'
icon: mdi:home-floor-2
layout: vertical
icon_color: '#4682B4'
tap_action:
action: navigate
navigation_path: rf
hold_action:
action: none
double_tap_action:
action: none
- square: false
columns: 1
type: grid
cards:
- square: false
columns: 4
type: grid
cards:
icon: mdi:palm-tree
layout: vertical
tap_action:
action: navigate
navigation_path: outdoor
hold_action:
action: none
double_tap_action:
action: none
icon_color: '#aeff00'
primary: ''
icon: mdi:chart-bar
layout: vertical
tap_action:
action: navigate
navigation_path: info
hold_action:
action: none
double_tap_action:
action: none
icon_color: '#593387'
icon: mdi:home-assistant
icon_color: blue
layout: vertical
tap_action:
action: navigate
navigation_path: ha
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
mushroom-shape-icon$: |
ha-icon {
--icon-animation: boing 3s ease infinite;
transform-origin: 50% 90%;
@keyframes boing {
0% { transform: scale3d(1, 1, 1); }
7% { transform: scale3d(1.25, 0.75, 1); }
10% { transform: scale3d(0.75, 1.25, 1); }
12% { transform: scale3d(1.15, 0.85, 1); }
16% { transform: scale3d(0.95, 1.05, 1); }
19% { transform: scale3d(1.05, 0.95, 1); }
25% { transform: scale3d(1, 1, 1); }
- square: false
columns: 4
type: grid
cards:
primary: ''
icon: mdi:fire
icon_color: red
layout: vertical
card_mod:
style:
ha-icon {
--icon-animation: fire 1.5s infinite;
transform-origin: 50% 85%;
@keyframes fire {
0% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
5% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
10% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
15% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
20% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
25% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
30% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
35% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
40% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
45% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
50% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
55% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
60% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
65% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
70% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
75% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
80% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
85% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
90% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
95% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
100% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
- type: grid
square: true
columns: 4
cards:
icon: none
primary: ''
icon_color: ''
layout: vertical
card_mod:
style:
.shape {
--shape-animation: fade 25s linear infinite reverse;
--shape-color: none;
@keyframes fade {
6.24%, 12.49%, 18.74%, 24.99%, 31.24%, 37.49%, 43.74%, 49.99%, 56.24%, 62.49%, 68.74%, 74.99%, 81.24%, 87.49%, 93.74%, 100% { box-shadow: 0 0 20px 20px transparent inset; }
0% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.7) inset; }
6.25% { box-shadow: 0 0 0 0 rgba(var(--rgb-deep-orange), 0.7) inset; }
12.5% { box-shadow: 0 0 0 0 rgba(var(--rgb-orange), 0.7) inset; }
18.75% { box-shadow: 0 0 0 0 rgba(var(--rgb-amber), 0.7) inset; }
25% { box-shadow: 0 0 0 0 rgba(var(--rgb-yellow), 0.7) inset; }
31.25% { box-shadow: 0 0 0 0 rgba(var(--rgb-lime), 0.7) inset; }
37.5% { box-shadow: 0 0 0 0 rgb(var(--rgb-light-green), 0.7) inset; }
43.75% { box-shadow: 0 0 0 0 rgb(var(--rgb-green), 0.7) inset; }
50% { box-shadow: 0 0 0 0 rgb(var(--rgb-teal), 0.7) inset; }
56.25% { box-shadow: 0 0 0 0 rgb(var(--rgb-cyan), 0.7) inset; }
62.5% { box-shadow: 0 0 0 0 rgb(var(--rgb-light-blue), 0.7) inset; }
68.75% { box-shadow: 0 0 0 0 rgb(var(--rgb-blue), 0.7) inset; }
75% { box-shadow: 0 0 0 0 rgb(var(--rgb-indigo), 0.7) inset; }
81.25% { box-shadow: 0 0 0 0 rgb(var(--rgb-deep-purple), 0.7) inset; }
87.5% { box-shadow: 0 0 0 0 rgb(var(--rgb-purple), 0.7) inset; }
93.75% { box-shadow: 0 0 0 0 rgb(var(--rgb-pink), 0.7) inset; }
