Lovelace: custom sidebar card
Hi!!! Thank you very much for sharing!!!
I copied your “styling” code but it doesn’t seem to work for me…my code now looks like this
sidebar:
  title: null
  width:
    mobile: 50
    tablet: 80
    desktop: 25
  digitalClock: true
  sidebarMenu:
    - action: navigate
      navigation_path: /dashboard-new/home
      icon: mdi:home
      icon-color: red
      active: true
    - action: navigate
      navigation_path: /dashboard-new/lounge
      icon: mdi:sofa
      active: true
    - action: navigate
      navigation_path: /dashboard-new/kitchen
      icon: mdi:countertop
      active: true
    - action: navigate
      navigation_path: /dashboard-new/bedroom
      icon: mdi:bed-king
      active: true
    - action: navigate
      navigation_path: /dashboard-new/studio
      icon: mdi:waveform
      active: true
    - action: navigate
      navigation_path: /dashboard-new/server
      icon: mdi:server
      active: true
    - action: navigate
      navigation_path: /dashboard-new/energy
      icon: mdi:flash
      active: true
    - action: navigate
      navigation_path: /dashboard-new/security
      icon: mdi:security
      active: true
  bottomCard:
    type: custom:vertical-stack-in-card
    cardOptions:
      cards:
        - type: custom:mushroom-person-card
          entity: person.george_fokianos
          icon: mdi:human-male
          entity: person.liberty_matsou
          icon: mdi:human-female
    cardStyle: |
      :host {
        width: 100%;
  style: |
    :host {
      --sidebar-background: #000;
      --sidebar-text-color: #fff;
      --sidebar-icon-color: #fff;
      --sidebar-selected-text-color: #fff;
      --sidebar-selected-icon-color: #fff;
      background: center/cover no-repeat fixed url('/hacsfiles/themes/backgrounds/bg_sidebar_grey_wood.jpg');
      box-shadow: inset -38px -3px 11px -28px #000;
    #customSidebar {
       z-index: 9999!important;
    .sidebarMenu {
      border-top: 3px solid rgba(255, 255, 255, 0.2)!important;
      border-bottom: 3px solid rgba(255, 255, 255, 0.2)!important;
    .sidebarMenu li {
      line-height: 20px!important;
      font-size: 16px!important;
    .sidebarMenu li.active {
      font-weight: bold!important;
    .sidebarMenu li.active::before {
      border-radius: 30px!important;
    h1 {
      text-align: center!important;
    h1.digitalClock {
      font-weight: normal!important;
    h2 {
      font-size: 20px!important;
Can you spot anything wrong? Maybe the location of the image??
It may be the image url. From my understanding, /hacsfiles is a link to /config/www/community but I’m not sure if there is any authentication required for that path. The path /local is a link to /config/www and does not require authentication. To get the image to load properly I added the /images/background directory structure under the www directory and was able to load the background images from there.
Using the /local url is discussed in the HA HTTP documentation under Hosting Files.
I created a folder called images inside the www folder and changed the path to
      url('/local/images/bg_sidebar_grey_wood.jpg');
But still no luck…
Interesting, I see nothing obvious that would prevent that from working. Have you cleared your cache or forced a resource update on your browser (ctrl-refresh on Windows cmd-refresh on Mac)?
Is this a UI-configured dashboard or are you writing the YAML?
Yes I’ve done all that but still no luck… The dashboard is a mix some things are configured through the UI and others with YAML. Still I don’t see how that could affect the sidebar. I read all 500 post here but couldn’t find a solution.
At some point in the thread I saw a pic from someone that had transparency in the sidebar but used the dashboard’s background image instead of a dedicated image for the side bar. That could also work for me if someone could help.
EDIT: I found it, its this post from @heartkingz
No one ?:frowning:
Can you please share the code?
George, sorry it has taken me so long to get back to you.
I haven’t tried this yet but I wonder if changing where the sidebar is defined would make any difference. Currently I have my sidebar defined in the root of the dashboard. (Same level as the views: tag.)
What I’m thinking of trying is moving the sidebar config to a separate file then mapping an !include: statement in each view. Time to do some research and see if anyone has done this successfully yet. Perhaps then the sidebar container could be set to a transparent background and you would see the background image defined in the view. :thinking:
Hi All!
Is there a way to show different content on the sidebar depending on the device where I load the dashboard?
For example I put weather card onto the sidebar and limit the sidebar widht depending on the device (table, desktop, mobile).
When the dashboard is loaded on the desktop the weather card shows 5 days forecast, but in the tablet this weather card is too big so it’s broken.
I’d like to show this weather card on the tablet with dfferent CSS styles and different parameters (i.e. show only 3 days or none).
How do you think it could be done?
Thank you!
question: how can add it to new dashboard if I have several already? mushrooms and minimalist?
I am French and a novice. I try to configure my sidebar, but I have big problems.
1 : I have installed sidebar-card directly with HACS, but I don’t understand what I have to put in the configuration.yaml file
here is mine :
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
#duckdns
http:
  ip_ban_enabled: true
  login_attempts_threshold: 5
  ssl_certificate: /ssl/fullchain.pem
  ssl_key: /ssl/privkey.pem
#google_assistant
google_assistant:
  project_id: !secret project_ghome
  service_account:
    private_key: !secret privatekey_ghome
    client_email: !secret email_ghome
  report_state: true
  exposed_domains:
    - switch
    - light
    - sensor
    - script
    - camera
frontend:
  extra_module_url:
    - /hacsfiles/lovelace-card-mod/card-mod.js
    - /hacsfiles/sidebar-card/sidebar-card.js
  themes: !include_dir_merge_named themes
# telegram #
telegram_bot:
  - platform: polling
    api_key: 618259
    allowed_chat_ids:
      - 2 # example: 123456789 for the chat_id of a user
# Example configuration.yaml entry for the notifier
notify:
  - platform: telegram
    chat_id: 2
 ### TIME ###
   - platform: time_date
     display_options:
      - "time"
      - "date"
      - "date_time"
      - "date_time_utc"
      - "date_time_iso"
      - "time_date"
      - "time_utc"
      - "beat"
do I have to manually add all the HACS theme/ lovelace I upload into it? Is my frontend correct? Because everything I put in my dashboard does not appear:
I don’t have the information, “hello”, “good afternoon” depending on the time, and especially I can’t get a bottomCard
if I put at the top of the configuration dashboard :
resources:
  - url: /local/sidebar-card.js?v=0.0.1
    type: module
sidebar:
  title: "Sidebar title"
I get an error message informing me that the resources must be put in the configuration.yaml file
sidebar:
  width:
    mobile: 0
    tablet: 25
    desktop: 20
  breakpoints:
    mobile: 768
    tablet: 1024
  style: |
    :host {
      –sidebar-background: #00FF00;
      –sidebar-text-color: #FFF;
      –face-color: #FFF;
      –face-border-color: #FFF;
      –clock-hands-color: #000;
      –clock-seconds-hand-color: #FF4B3E;
      –clock-middle-background: #FFF;
      –clock-middle-border: #000;
     background-color: rgba(0, 0, 0, 0)!important;
     icon-size: 225px;
    .digitalClock {
        text-align: center;
        padding-bottom: 1px;
        padding-top: 20px
        font-size: 205px;
        line-height: 95px;
    .date {
        text-align: center;
    .title h1{
        text-align: center;
    .bottomCard {
     background-color: #00FF00;
     icon-size: 225px;
  digitalClock: true
  date: true
  dateFormat: dddd DD-MMM-YYYY
  clock: false
  hideOnPath:
    - /lovelace-testing/bedroom2
  hideHassSidebar: false
  hideTopMenu: false
  template: >
    <li>
      {% if now().hour  < 5 %} Goede nacht {{'\U0001F634'}}
      {% elif now().hour < 12 %} Goedemorgen {{'\u2615\uFE0F'}}
      {% elif now().hour < 18 %} Goedenmiddag {{'\U0001F44B\U0001F3FB'}}
      {% else %} Goedenavond {{'\U0001F44B\U0001F3FB'}}{% endif %}
    </li>
    {% if "Vandaag" in states('sensor.blink_gft') %} <li>Vandaag groenebak aan
    de straat</li> {% endif %}
    {% if "Vandaag" in states('sensor.blink_papier') %} <li>Vandaag oudpapier
    aan de straat</li> {% endif %}
    {% if "Vandaag" in states('sensor.blink_pmd') %} <li>Vandaag plastic aan de
    {% if "Vandaag" in states('sensor.blink_restafval') %} <li>Vandaag grijzebak
    {% if "Morgen" in states('sensor.blink_gft') %} <li>Morgen groenebak aan de
    {% if "Morgen" in states('sensor.blink_papier') %} <li>Morgen oudpapier aan
    {% if "Morgen" in states('sensor.blink_pmd') %} <li>Morgen plastic aan de
    {% if "Morgen" in states('sensor.blink_restafval') %} <li>Morgen grijzebak
    {% if states('sensor.current_lights_on') | float > 0 %}
    <li>{{states('sensor.current_lights_on')}} lampen aan</li> {% endif %}
    {% if states('sensor.current_media_players_on') | float > 0 %}
    <li>{{states('sensor.current_media_players_on')}} speakers aan</li> {% endif
  sidebarMenu:
    - action: navigate
      navigation_path: /nasz-dom/default_view
      active: true
      icon: mdi:home-account
    - action: navigate
      navigation_path: /nasz-dom/parter
      icon: mdi:sofa-outline
    - action: navigate
      navigation_path: /nasz-dom/pietro
      icon: mdi:chef-hat
    - action: navigate
      navigation_path: /nasz-dom/media
      icon: mdi:bed-double-outline
    - action: navigate
      navigation_path: /nasz-dom/ogrzewanie-phone
      icon: mdi:cctv
    - action: navigate
      icon: mdi:music
  bottomCard:
    type: grid
    cardOptions:
      columns: 1
      square: false
      cards:
        - type: weather-forecast
          show_current: true
          show_forecast: true
          entity: weather.maison
          secondary_info_attribute: humidity
    cardStyle: |
      :host {
        width: 100%;
        background-color:#FFF;
  - theme: Backend-selected
    title: Home
    layout:
      grid-template-rows: null
      grid-template-columns: 25% 37.5% 37.5%
    badges: []
    cards:
      - type: grid
        cards:
          - type: light
            entity: light.mur_tv
          - type: light
            entity: light.chevet
On several themes I’ve seen here, I’ve seen codes to display the number of lights on. Can you explain me with the example of code I have to do?
Thanks so much for your help
I’m with you…I’m stuck on the proper setup of this.
If someone can give a dumb-ed down setup explanation…
that would be great.
Can i use browser mod pop up on the side bar menu?
This is my dashboard until now. When I resize it on the desktop, it work well, but when open it on the tablet the sidebar is over the panel. Someone have any idea how can I avoid it ?
Still a work in progress, so is not completed yet.
title: Home
sidebar:
  active: true
  width:
    mobile: 20
    tablet: 25
    desktop: 25
  breakpoints:
    mobile: 768
    tablet: 768
    desktop: 1024
  style: |
    :host {
        --sidebar-background: #1C1C1C;
        --sidebar-text-color: #FFF;
        --face-color: #FFF;
        --face-border-color: #FFF;
        --clock-hands-color: #FFF;
        --clock-seconds-hand-color: #FF4B3E;
        --clock-middle-background: #FFF;
        --clock-middle-border: #000;
     icon-size: 255px;
    .digitalClock {
        text-align: center;
        padding-top: 20px
        font-size: 205px;
        line-height: 95px;
    .date {
        text-align: center;
    .title h1{
        text-align: center;
    .bottomCard {
     icon-size: 185px;
  digitalClock: true
  hideHassSidebar: true
  hideTopMenu: true
  date: true
  clock: false
  sidebarMenu:
    - action: navigate
      navigation_path: /lovelace-home/0
      active: true
    - action: navigate
      navigation_path: /lovelace-home/1
      active: true
      icon: mdi:robot-vacuum
    - action: navigate
      navigation_path: /lovelace-home/2
      active: true
      icon: mdi:disc-player
    - action: navigate
      navigation_path: /lovelace-home/3
      active: true
      icon: mdi:weather-cloudy
    - action: navigate
      navigation_path: /lovelace-home/4
      active: true
      icon: mdi:white-balance-sunny
    - action: navigate
      navigation_path: /lovelace-home/5
      active: true
      icon: mdi:window-shutter
    - action: navigate
      navigation_path: /lovelace-home/6
      active: true
      icon: mdi:calendar
  bottomCard:
    type: grid
    cardOptions:
      columns: 1
      square: false
      cards:
          show_current: true
          show_forecast: true
          entity: weather.forecast_home_hourly
    cardStyle: |
      :host {
        width: 100%;
  - title: Home
    theme: Google Dark Theme
    panel: true
    cards:
      - config:
          defaults:
            tap_action: more-info
          image: /local/floorplan/painel_principal.svg
          rules:
            - name: Luzes
              entities:
                - element: light.luz_casal
                  entity: light.luz_casal
                - element: light.luz_escritorio
                  entity: light.luz_escritorio
                - element: light.luz_visita
                  entity: light.luz_visita
                - element: light.luz_banheiro_tom
                  entity: light.luz_banheiro_tom
                - element: light.luz_tom
                  entity: light.luz_tom
                - element: light.luz_banheiro_entrada
                  entity: light.luz_banheiro_entrada
                - element: light.luz_porta
                  entity: light.luz_porta
                - element: light.luz_sala
                  entity: light.luz_sala
                - element: light.luz_mesa
                  entity: light.luz_mesa
                - element: light.luz_pia
                  entity: light.luz_pia
                - element: light.luz_linda
                  entity: light.luz_linda
              state_action:
                action: call-service
                service: floorplan.class_set
                service_data: entitystate-${entity.state}
              tap_action:
                service: homeassistant.toggle
            - name: Exaustores
              entities:
                - element: fan.exaustor_banheiro_entrada_button
                  entity: fan.exaustor_banheiro_entrada
                - element: fan.exaustor_banheiro_tom_button
                  entity: fan.exaustor_banheiro_tom
              tap_action:
            - name: Exaustores girando
              entities:
              state_action:
                service_data: fan-${entity.state}
            - name: Televisoes
              entities:
                - element: media_player.samsung_7_series_55
                  entity: media_player.samsung_7_series_55
                - element: media_player.samsung_7_series_43
                  entity: media_player.samsung_7_series_43
              state_action:
                service_data: tv-${entity.state}
            - name: Pessoas
              entities:
                - element: person.junior
                  entity: device_tracker.sm_g990b
                - element: person.cintia
                  entity: device_tracker.redmi_note_9s
                - element: person.linda
                  entity: device_tracker.iphone_de_linda
                - element: person.tom
                  entity: device_tracker.sm_g570m
              state_action:
                service_data: device-${entity.state}
              hold_action: hover-info
          stylesheet: /local/floorplan/painel.css
          style:
            width: 100%
            height: 100%
        full_height: true
        type: custom:floorplan-card
  - title: Aspirador
    panel: true
    cards:
      - config:
          defaults:
          image: /local/floorplan/aspirador_mapa.svg
          rules:
            - name: Status
              entities:
                - element: bar.status
                  entity: vacuum.roborock_s5_max
              tap_action: none
              state_action:
                service: floorplan.text_set
                service_data:
                  text: ${entity.state}
            - name: Gentle
              entities:
                - entity: vacuum.roborock_s5_max
                  element: button.slow
              hold_action:
                action: none
              tap_action:
                service: vacuum.set_fan_speed
                service_data:
                  entity_id: vacuum.roborock_s5_max
                  fan_speed: Gentle
            - name: Medium
              entities:
                  element: button.medium
              hold_action:
                action: none
              tap_action:
                service_data:
                  fan_speed: Medium
            - name: Turbo
              entities:
                  element: button.full
              hold_action:
                action: none
              tap_action:
                service_data:
                  fan_speed: Turbo
            - name: Locate
              entities:
                  element: button.locate
              hold_action:
                action: none
              tap_action:
                service: vacuum.locate
                service_data:
            - name: Base
              entities:
                  element: button.base
              conditions:
                  value_not: docked
                  value_not: returning
              hold_action:
                action: none
              tap_action:
                service: vacuum.return_to_base
                service_data:
            - name: Start
              entities:
                  element: button.play
              conditions:
                  value_not: cleaning
                  value_not: error
              hold_action:
                action: none
              tap_action:
                service: vacuum.start
                service_data:
            - name: Pause
              entities:
                  element: button.pause
              conditions:
                  value_not: docked
                  value_not: idle
                  value_not: error
                  value_not: paused
              hold_action:
                action: none
              tap_action:
                service: vacuum.pause
                service_data:
        full_height: true
  - title: Alexa
    cards:
      - title: Echo Linda
        type: custom:mini-media-player
        artwork: full-cover
        entity: media_player.echo_linda
        tts:
          platform: alexa
          enity_id: media_player.echo_linda
      - title: Echo Cozinha
        artwork: full-cover
        entity: media_player.echo_cozinha
        tts:
          platform: alexa
          enity_id: media_player.echo_cozinha
      - title: Echo Tom
        artwork: full-cover
        entity: media_player.echo_tom
        tts:
          platform: alexa
          enity_id: media_player.echo_tom
      - title: Echo Visita
        artwork: full-cover
        entity: media_player.encho_escritorio
        tts:
          platform: alexa
          enity_id: media_player.encho_escritorio
      - title: Echo Casal
        artwork: full-cover
        entity: media_player.echo_master
        tts:
          platform: alexa
          enity_id: media_player.echo_master
  - title: Weather
    panel: true
    badges: []
    cards:
      - current: true
        details: true
        forecast: true
        tap_action: none
        style: |
          :host {
            left: 61.5%;
            top:  38%;
            width: 70%;
            overflow: hidden;
            height: 63%;
            background: #1C1C1C !important;
            box-shadow: none !important;
          .current {
            margin-bottom: 7vw;
          .variations {
            margin-bottom: 4vw;
          ha-card {
            height: 100%;
            font-size: 1.2vw !important;
          .forecast{
            padding: 1 2.5%;
            width: 95%;
          .forecast .day:first-child{
            border-left: 0.1em solid #d9d9d9;
          .forecast .day:last-child{
            border-right: 0.1em solid #d9d9d9;
        type: custom:weather-card
  - title: Verao
    panel: true
    style:
      background: '#1C1C1C'
    cards:
      - config:
          defaults:
          rules:
            - name: Status
              entities:
              tap_action: none
              state_action:
                service_data:
        full_height: true
  - title: Estores
    background: false
    panel: true
    cards:
      - type: custom:layout-card
        square: false
        panel: true
        cards:
          - type: custom:shutter-card
            entities:
              - entity: cover.estore_sala
                buttons_position: left
                title_position: top
            entities:
              - entity: cover.sonoff_100155acc4
                title_position: top
            entities:
              - entity: cover.sonoff_100155c8ac
                title_position: top
            entities:
              - entity: cover.sonoff_100155c903
                title_position: top
            entities:
              - entity: cover.sonoff_100155d407
                title_position: top
            style: |
              :host {
                left: 61.5%;
                top:  38%;
                width: 70%;
                overflow: hidden;
                height: 63%;
              ha-card {
                height: 100%;
                border-radius: 0px;
  - title: Calendario
    panel: true
    cards:
      - config:
          defaults:
          rules:
            - name: Status
              entities:
              tap_action: none
              state_action:
                service_data:
        full_height: true
Hello! I’ve gone over and over in circles and just can’t seem to get this to work, any help for a noob setting it up for the first time?
Same problem here. Has the syntax perhaps changed? I can’t use this code in the dashboard resources. For me it starts like this:
  - theme: noctis
    title: Home
    icon: mdi:home
    path: home
    type: sidebar
    badges: []
    cards:
      - square: false
        columns: 1
        type: grid
        cards:
But where do these blocks come into play? They cannot be inserted as a card.
title: Home
sidebar:
  active: true
  width:
    mobile: 20
    tablet: 25
    desktop: 25
  breakpoints:...
I do have two columns, the left one a little narrower. But I can’t change them via the code and can only edit elements via the GUI.
Nice, but project seems to be dead.
On Mobile you can see it well but, how can I adapt the 2-column cards on Desktop and Tablet?
… thanks
title: Home
background: center / cover no-repeat fixed url('/local/casa/nuvole.webp')
sidebar:
  active: true
  title: null
  style: |
    :host {
        --sidebar-background: 'rgba 50, 50, 50, .5';
        --sidebar-text-color: #ffffff;
        --border-radius: 5px;
     background-color: #000000!important;
  width:
    mobile: 0
    tablet: 25
    desktop: 20
  breakpoints:
    mobile: 768
    tablet: 768
    desktop: 1024
  date: true
  dateFormat: dddd, DD MMMM
  digitalClock: true
  twelveHourVersion: false
  hideTopMenu: false
  showTopMenuOnMobile: true
  bottomCard:
    type: vertical-stack
    cardOptions:
      cards:
        - type: custom:simple-weather-card
          entity: weather.casa
          primary_info:
            - humidity
            - precipitation_probability
          style: |
            ha-card {
            background-color: transparent;
            box-shadow: none;
            font-size: 12px;
        - type: custom:bar-card
          severity:
            - color: rgb(204,40,20)
              to: '30'
            - color: rgb(255,185,40)
              to: '65'
            - color: rgb(40, 204,20)
              to: '95'
          columns: 0
          height: 20
          title_position: inside
          align: split
          rounding: 3px
          unit_of_measurement: '%'
          width: 100%
          entity_row: true
          animation:
            speed: '1000'
          filter:
            include:
              - entity_id: sensor.*_battery*
                state: <=35
          show_empty: true
          sort:
            method: state
            ignore_case: true
            numeric: true
            reverse: false
        - type: custom:mini-graph-card
          style: |
            ha-card {
            box-shadow: none;
            font-size: 6px;
          entities:
            - sensor.corrente_electric_consumption_w
          icon: mdi:flash
          hours_to_show: 24
          points_per_hour: 60
          hour24: true
          smoothing: false
          upper_bound: 3500
          lower_bound: 0
          line_width: 1
          height: 120
          show:
            icon: false
            points: false
            labels: false
            state: true
            extrema: false
          color_thresholds_transition: smooth
          color_thresholds:
            - value: 1000
              color: green
            - value: 2000
              color: yellow
            - value: 3000
              color: red
          tap_action:
            action: navigate
            navigation_path: /plancia-telefono/energia
        - type: grid
          cards:
              entity: person.bologni
              fill_container: false
              primary_info: name
              icon_type: entity-picture
              style: |
                ha-card {
                box-shadow: none;
                font-size: 6px;
              tap_action:
                action: fire-dom-event
                browser_mod:
                  service: browser_mod.popup
                    content:
                      type: map
                      entities:
                        - entity: person.bologni
                      dark_mode: false
                      hours_to_show: 2
                      class: border
                      style:
                          ha-card {
                            border: solid 1px var(--primary-color);
                            border-radius: 25px;
              use_entity_picture: true
              layout: vertical
              entity: person.elena
              primary_info: name
              style: |
                ha-card {
                box-shadow: none;
                font-size: 6px;
              tap_action:
                browser_mod:
                    content:
                      type: map
                      entities:
                        - entity: person.elena
                      dark_mode: false
                      hours_to_show: 2
                      class: border
                      style:
                          ha-card {
              layout: vertical
          columns: 2
          square: true
        - type: picture-entity
          entity: camera.videocitofono_sub
          camera_view: live
          class: border
          show_state: false
          show_name: false
        - type: custom:auto-entities
          card:
            severity:
                to: '30'
                to: '65'
                to: '95'
            columns: 0
            height: 20
            align: split
            rounding: 3px
            width: 100%
            entity_row: true
            animation:
              speed: '1000'
          filter:
            include:
                state: <=35
          show_empty: true
          sort:
            method: state
            ignore_case: true
            numeric: true
            reverse: false
    cardStyle: |
      :host {
        width: 100%;
        position: absolute;
        bottom: 0;
        left: 0;
      .state {
        font-size: 8px;
Bottom card not showing
Hi
I cannot get the bottom card to show on the computer, however in the Android app, it shows fine. I am now trying to use the simplest possible code and the basic example from github. Same issue on different PCs and browsers. To make it even stranger, it does show up occasionally when going back and forth in the browser.
I would really appreciate some ideas how I could troubleshoot this…
Sad, but apparently true.
grafik
