Hi guys.
I’m not into frontend development, so I need your assistance.
I want to do 2 simple things:
- Modify the original lovelace thermostat card so it allows me to set custom operation mode.
- Change the more info dialog of the PTZ camera, so that clicking on the image edges rotates the camera
ad.1. I’ve tried to move src/panels/lovelace/cards/hui-thermostat-card.ts to ~/config/www/ directory however it won’t work, as hui-thermostat-card.ts is using some imports with relative paths… How can I easily modify the card so I can use another operation_mode? It would even work if instead of ‘Heat’ operation_mode I could use my custom mode.
ad.2. I’ve tried some time ago with creating ~/config/www/custom_ui/more-info-onvif.html and giving it the same content as the original camera more-info panel, however it was not working. How to make it with lovelace?
Am I the only one thinking that frontend dev documentation is missing many important topics?
