I have a Lovelace dashboard in which some of the controls are included in configuration.yaml
using !include_dir_merge_list
, for example:
input_number: !include_dir_merge_list input_numbers/
The directory input_numbers
is a subdirectory of config/
and the template file is minotairInputNumbers.yaml
If I do that, the Lovelace dashboard controls are greyed out. But if I include the file directly in config/
, the controls are active.
The control for the switch:
key is also located in a subdirectory and defined that and it is active, as are the sensor:
displays.
Why should Lovelace have a problem with certain controls but not others?
Any suggestions?
