to my configuration.yaml but I can see the filename it is then looking for in Configuration>Lovelace Dashboards>Dashboards under Overview2 is frontenddashboardsoverview2.yaml instead of navigating to the overview2.yaml file and reading it from there I get the default lovelace generated ui. It would definitely help keeping things organised! Thanks for making HA possible!
it most likely does but you’d need to whiltelist the directory or place it in the www folder and idenfity it as /local. I can’t verify at the moment, but most of HA works this way.
I.E.
drop it in config/www/dashboards/overview2.yaml
call it out
Hey petro! Thanks for the quick reply on my feature request.
The overview2.yaml loads correctly if I place it in config/ but not at all if I put it in my own folder i.e. config/frontend/dashboards/.
I tried placing the overview2.yaml in config/www/dashboards but still getting the default generated UI
I’m going out on a limb and say why have it at all?
All that the file in question really needs to have at the moment is:
title: Test
views: !include_dir_list ./lovelace/test
You could just as easily add views: as part of the dashboard object and rename the title to something like name: (because the dashboard object already has a title property)
