Lovelace: Decluttering Card
My statement was a bit hasty, actually.
It depends:
– a template for a “default” value of some variable cannot be resolved BEFORE using this variable;
– it may be resolved WHEN using this variable: if an option supports templates - then the template is resolved, otherwise - no.
Consider this decluttering-template:
  decl_test_var_template_2:
    default:
      - VALUE: >-
           {{ states('sun.sun') }}
    card:
      type: vertical-stack
      cards:
        - type: markdown
          content: '[[VALUE]]'
        - type: entities
          title: '[[VALUE]]'
          entities:
            - zone.home
where the variable is used for the “content” option (does support jinjia) and for the “title” option (does not support jinjia).
cards:
  - type: custom:decluttering-card
    template: decl_test_var_template_2
    variables:
      - VALUE: xxx
    variables:
      - VALUE: >-
          {{ states('device_tracker.iiyama') }}
Check this long read also.
