Lovelace: Decluttering Card
Hi - failing at the first hurdle here, installation! I found the card as an item in HACS and tried to download it from there but just got an infinitely spinning circle. (I have previously installed several other things from HACS). I note on the github page, installation notes, there is reference only to using wget and not HACS to install.
Am I missing something?
moving some stuff over to the decluttering card, and now I can’t find out how to get the variable payload_down to function.
I guess I have to figure out what the correct escape sequence is, but so far I haven’t. So any help is welcome!
the card in the UI
type: custom:decluttering-card
template: termostat
variables:
  - entity_climate: climate.tv
  - payload_down: '{"entity_id": "climate.tv", "action": "down"}'
and the corresponding part in the template
               tap_action:
                  action: call-service
                  service: mqtt.publish
                    topic: silverapple/termostat
                    payload: '[[payload_down]]'
This is a very special case - not everyone can simulate it.
So, probably you have to try&test yourself.
First, try this:
payload: [[payload_down]]
yeaht, got it to work!
found this site:
yaml-multiline info and of cource I have to escape the "…
  - payload_down: '{\"entity_id\": \"climate.tv\", \"action\": \"down\"}'
Hello all, first day trying the decluttering card. Hoping to get some help with custom button card custom_fields.
Here is my template
decluttering_templates:
  light_card:
    card:
      type: custom:button-card
      entity: '[[light]]'
      show_state: true
      hold_action:
        action: more-info
      double_tap_action:
        action: fire-dom-event
        browser_mod:
          service: browser_mod.more_info
            entity: '[[temperature_sensor]]'
      custom_fields:
        th: |
            return Math.round(states'[[temperature_sensor]]'.state)+"°"+"/"+ Math.round(states'[[humidity_sensor]]'.state)+"%"
      state:
        - value: 'off'
          styles:
            img_cell:
              - background: '#CDFAD5'
            icon:
              - color: black
      styles:
        grid:
          - grid-template-areas: '"i n" "i s" "i th"'
          - grid-template-columns: 60px 1fr 10px
        img_cell:
          - background: '#FF7676'
          - border-radius: 515px
          - width: 50px
          - height: 50px
        name:
          - justify-self: right
          - font-size: 17px
          - font-weight: 500
        card:
          - margin: 0
          - border-radius: 20px
          - padding: 5px 5px 5px 1px
        state:
          - font-size: 15px
          - color: black
          - opacity: '0.7'
        custom_fields:
          th:
            - font-size: 15px
            - color: black
            - opacity: '0.7'
This is the card.
template: light_card
variables:
  - light: light.kitchen_light
  - name: Kitchen
  - temperature_sensor: sensor.livingrmth_96a3_temperature
  - humidity_sensor: sensor.livingrmth_96a3_humidity
and my error message
states['[[temperature_sensor]]'].state
Thank you! That worked. Another newbie question. Most of my cards all use the exact same format, however a few of them have some minor adjustments to them. For example, one of the icons I apply transform: rotateX(180deg). Is it possible to add these slight modifications to the declutter card, while still using the same template for all.
Here is an example of what I would look like in my mind, but of course does not work.
variables:
  - light: light.living_room_lights
  - name: Living Room
  - icon: mdi:outdoor-lamp
card:
  styles:
    icon:
      - transform: rotateX(180deg)
Depends on a particular case. But in some cases it is possible to have ONE template:
my_template:
  default:
    - COLOR: green
    - PADDING: …
  card:
You have some variables with default values; in some particular case you use a custom COLOR=red, but in other cases it is green by default.
Hi
I had this all working but changed some stuff and now none is working, so i need the help from the experts here.
In my setup i have in my includes folder a notification.yaml file
This contains stuff like
- type: conditional
  conditions:
    - entity: binary_sensor.co_techniek
      state: "on"
  card:
    template: notification_template
    variables:
      - name: CO gesignaleerd in de technische ruimte!
I have 2 dashboards, one that is my default one (editing in yaml mode) and a second dashboard for mobile (not in editing yaml mode)
I want these notifications in my second mobile dashboard
I have this in my ui-lovelace.yaml
  notification_template:     # This is the name of a template
    card:
      show_state: false
      show_label: false
      layout: icon_name
      tap_action:
        action: none
      hold_action:
        action: none
      styles:
        card:
          - --ha-card-background: rgba(0,0,0,0.0)
          - box-shadow: none
          - height: 10px
        name:
          - font-size: 18px
          - font-family: Helvetica
          - justify-self: start
          - font-weight: normal
        grid:
          - grid-template-areas: '"i n"'
          - grid-template-columns: 2% 1fr
          - grid-template-rows: 1fr
I assume this isnt correct? since it should be in my thing for the second dashboard???
Cause when i add this as a card in my second dashboard:
- type: custom:swipe-card
        parameters:
          allowTouchMove: true
          grabCursor: true
          autoplay:
            disableOnInteraction: false
        cards:
          !include ../../includes/notifications.yaml
Its not working and i get:
Configuratiefouten ontdekt:
unknown tag !<!include> (1006:53)
1003 | …
1004 | … teraction: false
1005 | …
1006 | … ./includes/notifications.yaml
Any help?
Thx
  1. Always post a formatted code. Otherwise it cannot be analysed.
  2. The “!include” may be used in yaml mode only.
Oh i didnt know that !include can only be used in yaml.
So what do i do then? Turn it into yaml? I loved the none yaml mode, since now its evolved.
Or do i have other options?
  1. Yaml mode: create 5 dashboards, store all decluttering templates in a separate folder (1 file per 1 template - or per several related templates) or in 1 file (all templates together) - then use these templates in all dashboards.
  2. Storage mode: create 5 dashboards, open a “raw yaml editor” for EACH dashboard and paste all your decluttering templates. Now try to sync changes in 1 template between all dashboards ))). Also, try editing all your 100500 templates in that “raw yaml editor” ))).
Storage mode - for testing only.
? i dont need 5 dashboards lol
I just need 1 template also
So i should go into yaml for it to work?
You have 2 dashboards and 1 template.
If you need to share the template in both places (yaml & storage) - you need to keep & maintain it in 2 places.
Sorry for being a noob. but im lost.
  • I installed thru HAC.
  • I dont have the lovelace-ui.yaml file.
I did a card with this info
template: test
variables:
  - entity_climate: climate.liveac
and I get this erro
Cannot read properties of undefined (reading 'test')
template: test
variables:
In your dashboard you called a decluttering-card with “test” template.
Have you defined this template?
If you are a beginner and using a dashboard in “storage mode” (i.e. not “yaml mode”) - then you need to paste your templates in “raw configuration editor”:
before a “views” option (i.e. before a definition of your views):
So what do i do now?
Do i have to get in yaml or not?7
I need to use !include so.
It doenst work in storage?
You decide yourself which mode you prefer - yaml or storage.
It was already explained - no “include” in storage.
@RomRider what a cool and time saving card. Many thanks for it.
I just stumbled upon it. and used it immediately for my shutters/covers.
I combined a shutter card and an entity card for the input_boolean to toggle the automatic mode in a vertical stack.
Adding a shutter to my dashboard now takes seconds! :slight_smile: :partying_face:
grafik
Thanks again :pray:
Got some help and modified my shutter card:
grafik
If anyone is interested, please find the code for the template:
  rolladen_template:
    card:
      type: custom:stack-in-card
      cards:
        - type: custom:mushroom-cover-card
          entity: '[[cover]]'
          show_position_control: false
          show_buttons_control: true
          double_tap_action:
            action: none
          hold_action:
            action: none
          card_mod:
            style: |
              ha-card {
                border: none !important;
          primary: Automatik
          secondary: |-
            {% if is_state('[[automatik]]', 'on') %}
              ein
            {% else %}
              aus
            {% endif %}
          icon: |-
              mdi:window-shutter-auto
            {% else %}
              mdi:window-shutter
            {% endif %}
          hold_action:
            action: none
          tap_action:
            action: toggle
          double_tap_action:
            action: none
          entity: '[[automatik]]'
          icon_color: |-
              green
            {% else %}
              grey
            {% endif %}
          card_mod:
            style: |
              ha-card {
And here the the code in the dashboard:
square: false
type: grid
cards:
  - type: custom:decluttering-card
    template: rolladen_template
    variables:
      - name: Rolladen links
      - cover: cover.rollladen_wohnzimmer_links_eg
      - automatik: automation.rollladen_wohnzimmer_links_cca
    variables:
      - name: Rolladen rechts
      - cover: cover.rollladen_wohnzimmer_rechts_eg
      - automatik: automation.rollladen_wohnzimmer_rechts_cca
columns: 2
I cant install…the link doesnt work:
wget https://raw.githubusercontent.com/custom-cards/decluttering-card/master/dist/decluttering-card.js
mv decluttering-card.js /config/www/
