Lovelace: Decluttering Card
Just a quick follow up - I tested card-loader as you suggested and the end result was even worse than I expected. When I add card-loader to my decluttering-card template, the aforementioned gap would always show up. No amount of refreshing, cache purging, or private browsing would make the gap disappear. I also tested card-loader directly in the card declaration itself but the cards wouldn’t load at all, often times showing the Red Card of Fail and stating “Still waiting on decluttering-card” or Still waiting on conditional card’.
Ok I don’t know what wrong with my config this is what I trying to duplicate.
  - type: custom:banner-card
    background: "#1F8A3C"
    heading: "\U0001F6CB Green House"
    link: /lovelace/0
    entities:
      - entity: automation.green_house
        name: Green House Water
        value: mdi:water
#########   timer  ########
#      entities[].action: automation.green_house
      - entity: input_number.sprinkler_timer_slider_1
an this what I got…
  - url: /community_plugin/decluttering-card/decluttering-card.js
    type: module
decluttering_templates:
  test:     # This is the name of a template
    card:
      link: /lovelace/0
      value: mdi:water
      heading: '[[heading]]'
      entities:
        - entity: 'automation.[[enity_1]]'
        - entity: 'input_number.sprinkler_timer_slider_[[enity_2]]'
and
  - type: custom:decluttering-card
    template: test
    variables:
      - heading: green house
      - enity_1: green_house
      - entiy_1_name: green house
      - enity_2: 1
Thanks :slight_smile:
You have a typo here. It should be enity_1_name.
And put quotes around the '1'
probably not of practical necessity (we can call variables any name we want) but shouldn’t you use entity_xxx_xx, instead of enity_xxx_xx throughout. Seems a typo being propagated…
i fix and made the code better for me to read and I got it work but the icon not show just an on.
  sprinkler:     # This is the name of a template
    card:
      link: /lovelace/0
      value: mdi:water
      entities:
        - entity: '[[sprinkler]]'
        - entity: '[[sprinkler_timer_slider]]'
    template: sprinkler
    variables:
      - sprinkler: automation.green_house
      - sprinkler_name: Green House
      - sprinkler_timer_slider: input_number.sprinkler_timer_slider_1
Your config is wrong for banner-card.
value: mdi:water should be with the entity, not at the top level.
oh was just looking at that sorry
one more
    card:
      link: /lovelace/0
      heading: '"\U0001F6CB [[heading]]"'
have I miss something trying to get the little house next to green house
I don’t know if the emoji code is correct but can strart by deleting the outer single quotes from your heading and see what happens.
it work
heading: "\U0001F6CB [[heading]]"
thanks you
p.s do we need outer single quotes on any of them???
Yes, when the first characters are [[ and last are ]]
ok got ya
so I would do this
to
        - entity: automation.[[sprinkler]]
I don’t know if this belongs here or in the button card? and there is a lot of code in this post so please bear with me. It is two versions of the same thing. One works using the button card the other doesn’t using the de-cluttering templates. (I stole the idea from someone else a long time ago but can’t remember who).
So…
This works to give a nice header with a ‘settings’ button at the side:
cards:
  - type: vertical-stack
    cards:
      - type: horizontal-stack
        cards:
          - type: custom:button-card
            label: "-- Hall --"
            show_name: false
            show_icon: false
            show_label: true
            styles:
              card:
                - height: 50px
      #                - background: linear-gradient(to right, rgba(255,255,20,0.45) 0%,rgba(255,255,20,0.3) 60%,rgba(255,255,20,0) 85%)
                - background: linear-gradient(to right, var(--paper-card-background-color) 0%, rgba(255,255,255,0.55) 70%, rgba(255,255,255,0) 90%)
                - --ha-card-box-shadow: 'none'
              label:
                - justify-self: start
                - padding-left: 10px
                - font-size: 18pt
            color_type: blank-card
            styles:
              card:
                - width: 2px
            icon: mdi:settings
            show_name: false
            tap_action:
              action: call-service
              service: homeassistant.turn_on
              service_data:
                entity_id: entity
            styles:
              card:
                - border-radius: 50%
                - height: 40px
                - width: 40px
                - background: rgba(255,255,255,0.45)
                - top: 5px
              icon:
                - color: gray
                - width: 35px
            styles:
              card:
                - width: 2px
        background: "#EDE7B0"
        heading: "\U0001F6CB Hall"
        link: /lovelace/0
        entities:
          - entity: group.hall_lights
          - entity: binary_sensor.front_door
          - entity: sensor.hall_temperature
But this doesn’t work, using the de-cluttering templates:
First the view itself,
cards:
    cards:
        cards:
            template: simple_header
            variables:
              - label: -- Hall --
            styles:
              card:
                - width: 2px
            template: simple_header_options_button
            styles:
              card:
                - width: 2px
then the de-cluttering templates,
  #=== Simple Header
  simple_header:
    card:
      label: '[[label]]'
      show_label: true
      aspect_ratio: 9/1
#      color_type: label-card
      styles:
        card:
          - height: 50px
          - background: linear-gradient(to right, var(--paper-card-background-color) 0%, rgba(255,255,255,0.55) 60%, rgba(255,255,255,0) 90%)
#          - background-color: var(--paper-card-background-color)
        label:
          - padding-left: 20px
          - font-size: 24px
  #=== Simple Header Options Button
  simple_header_options_button:
    default:
      icon: mdi:settings
      lock: false
      lock_color: var(--primary-text-color)
      tap_action: more-info
    card:
      icon: '[[icon]]'
      show_name: false
      tap_action:
        action: '[[tap_action]]'
      lock: '[[lock]]'
      styles:
        card:
          - height: 50px
          - width: 50px
        lock:
          - color: '[[lock_color]]'
        icon:
          - color: gray
          - width: 35px
For bonus points, why does the options button have a lock when the default is ‘false’?
So, there are multiple things here:
  • the lock thingy seems like a bug with booleans on decluttering-card :sweat_smile: it should work, but apparently not… Could you open a bug on github please?
  • the second problem is that button-card’s fixed width feature (specifying width: 50px) is a hack and it doesn’t work inside a decluttering card, it only works if the button-card's direct father is a horizontal-stack (when using decluttering-card, the father is a decluttering-card card and its father is a horizontal-stack card) .
What I’d suggest is to put everything inside 1 decluttering-template which would then work:
simple_header_with_button:
  default:
    icon: mdi:settings
    lock: false
  card:
    cards:
        label: '[[label]]'
        show_label: true
        aspect_ratio: 9/1
        styles:
          card:
            - height: 50px
          label:
            - font-size: 24px
        styles:
          card:
            - width: 2px
        icon: '[[icon]]'
        show_name: false
        tap_action:
        lock: '[[lock]]'
        styles:
          card:
            - height: 50px
            - width: 50px
          lock:
          icon:
            - color: gray
            - width: 35px
        styles:
          card:
            - width: 2px
And you’d use it like this:
  template: simple_header_with_button
  variables:
    - label: -- Hall --
Wait, what!!! Decluttering card can template more than one card in one template??
That is exactly what I wanted to do but just didn’t try it.
My fault… But thank you!
I will open an bug for booleans
It can template all the things :tada: :stuck_out_tongue:
Another question…
Can this card be used as an element in picture-elements because I can’t make it work?
The error I get is a simple, “Error in card configuration.
Here is my view:
title: home
icon: 'mdi:home'
panel: true
cards:
  - type: custom:layout-card
    layout: horizontal
    column_num: 1
    max_columns: 1
    max_width: [100%]
    cards:
      #=== TOP PANEL
        cards:
          - type: picture-elements
            image: /local/top_panel.svg
            elements:
Some working elements in here...
      #=== CENTRE PANEL
        cards:
            image: /local/centre_panel.svg
            elements:
...then DECLUTTERING CARD, not working
                template: hall_panel_conditional
                variables:
                  - state: Good Service
                  - type: state-label
                  - entity: sensor.bakerloo
                  - prefix: 'Bakerloo - '
                  - top: 65%
                  - left: 60%
                  - font-size: 22px
Here is my decluttering template
  hall_panel_conditional:
    default:
      type: state-label
      color: '"#A1A1A1"'
      font-family: Quicksand
      font-size: 22px
      font-weight: normal
      pointer-events: none
    card:
      type: conditional
      conditions:
        - entity: '[[entity]]'
          state: '[[state]]'
      elements:
        - type: '[[type]]'
          prefix: '[[prefix]]'
          style:
            top: '[[top]]'
            left: '[[left]]'
            color: '[[color]]'
            font-family: '[[font-family]]'
            font-size: '[[font-size]]'
            font-weight: '[[font-weight]]'
            pointer-events: '[[pointer-events]]'
No this doesn’t work unfortunately :frowning:
That’s a real shame. Picture elements cards get huge!
I’m attempting to create a template from the sample button code available with the ESXI Custom Component. By itself, the button code works fine. However, when I drop the code into decluttering-templates: and replace the hostname field with a variable name located inside of the IF statements, the button doesn’t actually render.
The variable I suspect is problematic is '[[vm_hostname]]'.
Is this the expected behavior or am I doing something wrong?
  dc_esxi_vm_status_card:
    card:
      entity: sensor.esxi_stats_vms
      template: esxi_stats_vm
      styles:
        icon:
          - color: >
                if ( states['sensor.esxi_stats_vms'].attributes.'[[vm_hostname]]'.status == "green")
                  return "green";
                if ( states['sensor.esxi_stats_vms'].attributes.'[[vm_hostname]]'.status == "warning" )
                  return "yellow";
                return "red";
      custom_fields:
        uptime: >
            return `<ha-icon
              icon="mdi:arrow-up"
              style="width: 12px; height: 12px; color: deepskyblue;">
              </ha-icon><span><span style="color: var(--text-color-sensor);">
              ${states['sensor.esxi_stats_vms'].attributes.'[[vm_hostname]]'.uptime_hours}</span></span>`
        cpu: >
            return `<ha-icon
              icon="mdi:server"
              </ha-icon><span>CPU: <span style="color: var(--text-color-sensor);">
              ${states['sensor.esxi_stats_vms'].attributes.'[[vm_hostname]]'.cpu_count}</span></span>`
        ram: >
            return `<ha-icon
              icon="mdi:memory"
              </ha-icon><span>Mem: <span style="color: var(--text-color-sensor);">
              ${states['sensor.esxi_stats_vms'].attributes.'[[vm_hostname]]'.memory_allocated_mb} MB</span></span>`
        state: >
            return `<ha-icon
              icon="mdi:harddisk"
              </ha-icon><span>State: <span style="color: var(--text-color-sensor);">
              ${states['sensor.esxi_stats_vms'].attributes.'[[vm_hostname]]'.state}</span></span>`
