Lovelace: Decluttering Card
That wouldn’t be possible. But you can define default values in the template and if you don’t want any value, you can use undefined as the default value.
i want to use this card, but I do not bring it working.
Also i do not find the “decluttering-card.js” file in the repository.
Thermostat is only a .ts file.
Please provide a actual description to install this card.
kind regards,
gerald
The file is in the release part of the github repository, but you should consider using HACS to install it
I think I’m beginning to understand the decluttering card but I have a slight problem with spacing as seen below. I’m building up the card variable by variable to ensure it all works, but I’ve noticed that the top, decluttering card version, has a lot of extra padding, whereas the original bottom button doesn’t.
Decluttering Code:
decluttering_templates:
  remote_device_dtemplate:
    default:
      - icon: raspberry-pi
    card:
      type: custom:button-card
      template: remote_device_btemplate
      entity: '[[entity]]'
      icon: 'mdi:[[icon]]'
      styles:
        custom_fields:
          cpu:
            - '--text-color-sensor': '[[[ if (states["[[cpu_used]]"].state > 80) return "red"; ]]]'
          ram:
            - '--text-color-sensor': '[[[ if (states["[[ram_used]]"].state > 4000) return "red"; ]]]'
button_card_templates:
  remote_device_btemplate:
    show_icon: true
    styles:
      card:
        - background: 'linear-gradient(rgba(255,255,255,0.1)16%, rgba(0,0,20,0.3)84%)'
        - border-radius: 15px
        - border: 'solid 1.5px rgba(57,128,228)'
        - color: ivory
        - font-size: 11px
        - text-shadow: 0px 0px 5px black
        - text-transform: capitalize
        - height: 132px
        - width: 132px
        - padding: 4%
      custom_fields:
        cpu:
          - padding-bottom: 2px
          - align-self: middle
          - justify-self: start
          # - '--text-color-sensor': '[[[ if (states["sensor.dhass_cpu_used"].state > 80) return "red"; ]]]'
        ram:
          # - '--text-color-sensor': '[[[ if (states["sensor.dhass_ram_used_percent"].state > 4000) return "red"; ]]]'
        sd:
          - '--text-color-sensor': >-
              [[[ if (states["sensor.dhass_disk_used_percent"].state > 80) return
              "red"; ]]]
        speed:
          - font-size: 14px
          - justify-self: end
          - margin-top: '-5px'
        temp:
          - font-size: 14px
          - justify-self: end
      grid:
        - grid-template-areas: '"i temp""speed speed"  "n n" "cpu cpu" "ram ram" "sd sd"'
        - grid-template-columns: 1fr 1fr
        - grid-template-rows: 1fr min-content min-content min-content min-content
      icon:
        - color: |
              if (entity.state < 60) return 'dodgerblue';
              if (entity.state >= 60 && entity.state < 80) return 'orange';
              else return 'red';
        - width: 70%
        - margin-top: '-5%'
      img_cell:
        - justify-content: start
        - align-items: start
        - margin: none
      name:
        - font-weight: bold
        - font-size: 13px
        - color: white
        - padding-bottom: 4px
    custom_fields:
      cpu: |
          return `<ha-icon
          icon="mdi:cpu-64-bit"
          style="width: 12px; height: 12px; color: deepskyblue;">
          </ha-icon> <span>CPU: <span style="color: var(--text-color-sensor);">${states['sensor.dhass_cpu_used'].state}%</span></span>`
      ram: |
          return `<ha-icon
          icon="mdi:memory"
          </ha-icon> <span>RAM: <span style="color: var(--text-color-sensor);">${states['sensor.dhass_ram_used_percent'].state}MB</span></span>`
      sd: |
          return `<ha-icon
          icon="mdi:harddisk"
          </ha-icon> <span>SSD: <span style="color: var(--text-color-sensor);">${states['sensor.dhass_disk_used_percent'].state}%</span></span>`
      speed: |
          return `<ha-icon
          icon="mdi:pulse"
          style="width: 14px; height: 14px; color: deepskyblue;">
          </ha-icon> <span> <span style="color: var(--text-color-sensor);">${states['sensor.dhass_cpu_hz_current'].state} GHz</span></span>`
      temp: |
          return `<ha-icon
          icon="mdi:thermometer"
          style="width: 14px; height: 14px; color: orange;">
          </ha-icon> <span>${entity.state}°C</span>`
  - title: test
    icon: mdi:run
    panel: false
    path: test
    cards:
      - type: 'custom:decluttering-card'
        template: remote_device_dtemplate
        variables:
          - entity: sensor.dhass_cpu_temp
          - name: HASS
          - cpu_used: sensor.dhass_cpu_used
          - ram_used: sensor.dhass_ram_used_percent
Original version code:
  remote_device_btemplate_two:
    show_icon: true
    styles:
      card:
        - color: ivory
        - font-size: 11px
        - height: 132px
        - width: 132px
        - padding: 4%
      custom_fields:
        cpu:
        ram:
        sd:
              "red"; ]]]
        speed:
          - font-size: 14px
          - justify-self: end
        temp:
          - font-size: 14px
          - justify-self: end
      grid:
      icon:
        - color: |
              else return 'red';
        - width: 70%
        - margin-top: '-5%'
      img_cell:
        - margin: none
      name:
        - font-weight: bold
        - font-size: 13px
        - color: white
    custom_fields:
      cpu: |
          return `<ha-icon
      ram: |
          return `<ha-icon
          icon="mdi:memory"
      sd: |
          return `<ha-icon
          icon="mdi:harddisk"
      speed: |
          return `<ha-icon
          icon="mdi:pulse"
      temp: |
          return `<ha-icon
  - title: test
    icon: mdi:run
    panel: false
    path: test
      - type: 'custom:button-card'
        template: remote_device_btemplate_two
        icon: 'mdi:raspberry-pi'
Am I doing anything obviously wrong?
Thanks in advance.
I’ve solved it by using advice given in an earlier post to put everything into the decluttering card: :smiley:
    default:
    card:
      type: horizontal-stack
      cards:
        - type: custom:button-card
          show_icon: true
          styles:
            card:
              - color: ivory
              - font-size: 11px
              - height: 132px
              - width: 132px
              - padding: 4%
            custom_fields:
              cpu:
              ram:
              sd:
                    [[[ if (states["[[disk_used]]"].state > 80) return
                    "red"; ]]]
              speed:
                - font-size: 14px
                - justify-self: end
              temp:
                - font-size: 14px
                - justify-self: end
            grid:
            icon:
              - color: |
                    else return 'red';
              - width: 70%
              - margin-top: '-5%'
            img_cell:
              - margin: none
            name:
              - font-weight: bold
              - font-size: 13px
              - color: white
          custom_fields:
            cpu: |
                return `<ha-icon
                </ha-icon> <span>CPU: <span style="color: var(--text-color-sensor);">${states['[[cpu_used]]'].state}%</span></span>`
            ram: |
                return `<ha-icon
                icon="mdi:memory"
                </ha-icon> <span>RAM: <span style="color: var(--text-color-sensor);">${states['[[ram_used]]'].state}MB</span></span>`
            sd: |
                return `<ha-icon
                icon="mdi:harddisk"
                </ha-icon> <span>SSD: <span style="color: var(--text-color-sensor);">${states['[[disk_used]]'].state}%</span></span>`
            speed: |
                return `<ha-icon
                icon="mdi:pulse"
                </ha-icon> <span> <span style="color: var(--text-color-sensor);">${states['[[cpu_ghz]]'].state} GHz</span></span>`
            temp: |
                return `<ha-icon
  - title: test
    icon: mdi:run
    panel: false
    path: test
    cards:
        variables:
          - name: HASS
          - disk_used: sensor.dhass_disk_used_percent
          - cpu_ghz: sensor.dhass_cpu_hz_current
@RomRider is there any possibility to add a support for picture-elements?
Good day gents, does this card work if you have split lovelace yaml(s)?
i.e. if variables are set at the root of the ui-lovelance.yaml do they transponse onto the other files?
Thank you
I’ll have a look. Can you tell me what happens when you try to put it in a picture element please?
It works, but you have to define style outside the template. Additionally I had issues with overflow: when decluttering cards size was different then size of image inside of it (solved by adding overflow: hidden).
  - type: custom:decluttering-card
    template: dimmer_light_slider_popup
    variables:
      - entity: light.fibaro_dimmer_2_level_2
      - name: "Kanapa"
    style:
      top: 65.5%
      bottom: 19.5%
      right: 12%
      left: 75%
      transform: translate(0%, 0%)
      overflow: hidden
      opacity: 0
dimmer_light_slider_popup:
  card:
    type: custom:hui-image-element
    image: /local/images/floorplan/hitbox.png
    tap_action:
      action: toggle
    hold_action:
      action: call-service
      service: browser_mod.popup
      service_data:
        title: '[[name]]'
        card:
          type: custom:vertical-stack-in-card
          cards:
            - type: entities
              entities:
                - entity: '[[entity]]'
                  secondary_info: last-changed
                  style: |
                    ha-card {
                      z-index: 5
            - type: entities
              entities:
                - type: custom:light-slider-card
                  persist_features: true
                  header: false
                  style: |
                    ha-card {
                      z-index: 0
              show_header_toggle: false
        deviceID:
          - this
Hi @RomRider
I use picture-elements inside decluttering templates to show presence of people in the home, works perfectly up to 0.105.5 but I’ve upgraded a test system to 0.106.0b and now all I get are thin red bars with no text showing the error.
I know there are changes in 0.106 that affect custom-cards, is this what’s affecting my setup?
This is the template code;
default:
  - entity: device_tracker.brad_g7
  - image: sunset-water.jpg
card:
    type: picture-elements
    style: |
        ha-card {
            border-radius: 5px;
            font-family: var(--font-family);
            font-size: 14px;
            font-weight: bold;
            color: rgba(250,250,250,1);
    image: '/local/[[image]]'
    elements:
      - type: state-label
        style:
          top: 90%
          left: 20%
Could you please check the javascript console and report the error please?
:tada::tada: Version 0.4.0 :tada::tada:
Bug Fixes
  • Support for >= 0.107
Hi, first thanks for your work again and again
I’m using decluttering with many cards, one of then are with mini-graphic-card, with this latest update show this error
Cannot read property ‘states’ of undefined
Could be for this update?
Anyone more having troubles with latest update?
I’m working on it, I have the same issue :slight_smile:
Thanks again
ah, i also had the issue wit mini-graph-card :slight_smile:
thnx for the update and the work!
:tada::tada: Version 0.4.1 :tada::tada:
Bug Fixes
  • Really fixed for >= 0.107 (Sorry…)
:tada::tada: Version 0.4.2 :tada::tada:
Bug Fixes
  • Fixes some problems with vertical-stack-in-card and stack-in-card
Is there a way to use the same decluttering template to my 3 diffrent types of service_data?
If i leave out ‘[[muted]]’ or ‘[[source]]’ i will get an error, and i cant include them either.
It would be nice if you could make a
service_data:
  '[[service_data]]'
and then somehow include the 1, 2 or 3 lines of variables to that.
# Button for remote icon and text
  button_icon_and_text:
    default:
    card:
      type: "custom:button-card"
      show_name: true
      tap_action:
        service: '[[service]]'
        service_data:
          entity_id: '[[entity]]'
          is_volume_muted: '[[muted]]'
          source: '[[source]]'
      styles:
        card:
          - background-color: rgba(56,60,69,1)
          - border-radius: 20px
          - border-style: solid
          - border-width: 3px
          - border-color: rgba(80,120,140,1)
          - height: 75px
          - padding: 5px
# button_icon_text (sonos)
      - type: horizontal-stack
        cards:
          template: button_icon_and_text
          variables:
            - entity: media_player.sonos_living_room
            - name: 'MUTE'
            - icon: volume-mute
            - service: media_player.volume_mute
            - muted: true
          variables:
            - name: 'VOLYM'
            - icon: volume-plus
            - service: media_player.volume_up
          variables:
            - name: 'NRJ'
            - icon: youtube
            - service: media_player.select_source
            - source: RIX FM
You should be able to do that already:
#Template
template:
  card:
    tap_action:
      action: xxx
      service_data: '[[service_data]]'
#Card
variables:
  - service_data:
      entity_id: xxx
      other_param: xxx
