Lovelace default home view page
hello everybody, i want to show my lovelace page as the default view in my home assistant resume but when i go to the configurator window and go back to the resume it shows the normal view without the lovelace interface, i also want to show the url xxx.duckdns.org:8123/lovelace as the default view in my phone and when i tried to add the url to my main screen as an app it redirects me to the normal view with no lovelace
This is covered in the introduction documentation:
Here’s the blurb about it in the doc:
Setting Lovelace as the Default UI
Once you are ready to start using Lovelace UI as your main user interface, click on info, the ā€œiā€ icon under ā€˜Developer Toolsā€ in the home assistant side-bar. Next, locate Ā»Set lovelace as default page on this deviceĀ« under the home assistant version information and click it.
Note that this is a per-device setting and will need to be changed on each device you access the UI from.
thank you very much
