Lovelace Default UI Device Order
Hi There,
I noticed that the order of my devices under the default groups in the Lovelace UI are no longer the same as in Polymer. Previous all entities under the lights group were ordered by name. Now there appear to be ordered in the order they were discovered by the system.
Is there a quick way to always order by type or will we need to ‘Take control’ which is not what I am currently looking for.
I’m new to Lovelace and I’m using yaml mode. From my early work on my UI they seem to be listed in the order provided in the yaml file if it’s relevant for your case.
My system is over a year old. The order appears to be that of the entity registry. So as I added devices to my system that is the order they are showing in the Lovelace UI. With the previous ui they were listed in alphabetical order.
