Hello.
I’ve used the add-on lovelace migration
Add-on
https://github.com/hassio-addons/addon-lovelace-migration
Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 10-run: applying...
[fix-attrs.d] 10-run: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: Lovelace Migration v0.3.0
Automatically convert your existing UI to the new Lovelace UI
By: Franck Nijhof <[email protected]>
amd64 / Ubuntu 18.04.1 LTS / HA 0.85.1 / SU 141 / stable
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-auto-backup.sh: executing...
[cont-init.d] 10-auto-backup.sh: exited 0.
[cont-init.d] 11-cleanup-old.sh: executing...
[cont-init.d] 11-cleanup-old.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
INFO: Output file is set to: /config/ui-lovelace.yaml
INFO:__main__:Lovelace UI successfully written to: /config/ui-lovelace.yaml
[cmd] /usr/bin/run.sh exited 0
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
ui-lovelace.yaml
# This file was automatically generated by lovelace_migrate.py
# https://github.com/dale3h/python-lovelace
title: Casa
- title: Casa
icon: mdi:home
cards:
- type: entities
title: Luci
show_header_toggle: true
entities:
- light.yeelight_color2_04cf8c7caa65
- light.yeelight_color2_7c49ebae84a6
- type: media-control
entity: media_player.sony
entity: media_player.te_stesso
but I still can’t use as default ui. I have the ui-lovelace.yaml and i’ve setted
>> Remove lovelace as default page on this device <<
i’m running hassio on an ubuntu 18.04 and i’ve installed following this guide, the install on generic linux server
Installation
if i make change in the configurator.yaml i can see the change even if lovelace is the default ui
thanks for the help.
