nickma
(Nick)
May 7, 2019, 11:09am
1
I’m looking for a way to reduce the vertical spaces between elements on an entities card , to get a more compact feeling. Something like the following:
- cards:
- type: entities
entities:
- entity: sensor.pv_prod
- entity: sensor.pv_self_consumed
show_header_toggle: false
style:
font-size: 9px
padding: 0px
padding-bottom: 0px
I saw the thread Lovelace - Space between enteties? where they were trying to add additional spaces between elements - which is the opposite from what I want.
What I found too on home-assistant.io/lovelace/ are hints about themes, but nothing more.
Any ideas are highly appreciated!
Best
cyn
May 7, 2019, 11:54am
2
I used a picture-elements card to accomplish this. My picture is a very small transparent image, in other words no image. I have 48 elements being displayed in a small area on the screen. Adjust the spacing with the top parameter. Here’s how I started it. Hope that helps
card:
type: picture-elements
image: /local/icons/transparent.png
elements:
- type: state-label
entity: input_text.room
style:
top: 11%
left: 20%
font-size: 140%
font-weight: bold
- type: state-label
entity: input_text.lr
style:
top: 20%
left: '20px'
font-size: 100%
Gluwc
(Lucas Bramlage)
May 7, 2019, 12:11pm
3
I use card-modder for this. Not sure how this works with multiple entities in a single card though.
- type: custom:card-modder
style:
padding-top: 0px
padding-bottom: 0px
card:
type: entities
entities:
- input_select.living_room_state
Can we see a screenshot of what it looks like?
nickma
(Nick)
May 9, 2019, 6:40pm
5
I had no luck with the card-modder so far, tried a couple of hours.
I didn’t try the picture-elements card yet.
cyn
May 9, 2019, 7:14pm
6
sure, Room Status is the picture element card
jvaillant
(Jean-Luc Vaillant)
February 14, 2020, 8:00pm
7
also using card-mod but with the following style:
style:
#states > * {
margin: -1px 0px !important;
you can play with the -1px up or down until you get the look you want (by default, in lovelace, this value is 8px)
example with default:
with -1px margin:
ianadd
(ian)
May 4, 2020, 1:23am
8
My solution is to use multiple-entity-row, in a way it was not intended I expect ! :
entities:
- entity: sensor.your1
icon: nothing
style: |
state-badge {
height: 17px;
type: 'custom:multiple-entity-row'
- entity: sensor.your2
icon: nothing
style: |
state-badge {
height: 17px;
type: entities
The key is you need to hide the icon as it gets cut-off as you shrink the row height.
Can you show me what it ended up looking like. I have done a bunch of stuff with this merging multiples cards across each other to form this below. Be interested what you have come up with.
ianadd
(ian)
May 4, 2020, 7:31am
10
My smallest card showing the spacing.
duncan86
(Duncan Bloom)
September 21, 2020, 3:24pm
11
Can you share your config to show how you did this? The solution from @jvaillant doesn’t work for me…
jvaillant
(Jean-Luc Vaillant)
December 19, 2020, 9:14pm
12
Sorry, did not see your question:
group.kitchen_lights:
title: "Kitchen Lights"
card:
type: entities
style:
#states > * {
ha-card {
box-shadow: none;
entities:
- type: custom:slider-entity-row
entity: light.kitchen_ceiling_lights
toggle: true
hide_when_off: true
entity: light.kitchen_island_lights
toggle: true
hide_when_off: true
entity: light.kitchen_counter_lights
toggle: true
hide_when_off: true
entity: light.kitchen_sink_lights
toggle: true
hide_when_off: true
entity: light.kitchen_nook_chandelier
toggle: true
hide_when_off: true
but I also have mod-card in my configuration.yaml
lovelace:
mode: yaml
resources:
- url: /hacsfiles/lovelace-card-mod/card-mod.js
type: module
hope this helps…
duncan86
(Duncan Bloom)
December 19, 2020, 9:50pm
13
That’s ok. Im gonna try it out. Thanks for sharing.
Edit: Works like a charm. Probably put it in the wrong place the first time. Thank!
